Rigging Line for Winch Rope - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-29-2008, 05:24 AM   #1 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
Not my idea, wanted to see what Pirate thought - rigging line used for winch rope:
http://www.wesspur.com/rope/stable-b...nths-rope.html
In the 9/16 diameter, Samson stable Braid has a breaking strength of 13,300 lbs. Stable Braid is a double-braid, %100 polyester rigging rope that is exceptionally low stretch, abrasion resistant,
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 05:49 AM   #2 (permalink)
comeonstart's Avatar
Member # 49939
Send a message via AIM to comeonstart
Pretty sure 3/8 winch rope is at least twice that strong. I wouldnt put it on my rig.
________
Prilosec withdraw
comeonstart is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 06:13 AM   #3 (permalink)
Member # 99437
Send a message via Yahoo to CTD NUT
Yikes, 9/16" is getting huge - and it isn't even very strong. That would eat up way too much drum capacity. I think 3/8" eats up enough. That is the wrong rope for the job - too large and too weak.
'80 CJ7-MPFI 454, 60's, linked, locked, C/O'd, bagged, tubed, Doublered, 111" WB, 44" TSL/Boggers
CTD NUT is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 07:51 AM   #4 (permalink)
Member # 1889
If you don't need much reach, sure, rope isn't rocket science, almost anything can be used. But 3/8" Amsteel Blue has a break strength over 20k pounds, and 5/16" is 13.7k break. Stepping from 5/16 to 9/16, you'd divide your drum capacity by about 3-1/4 (cross sectional area of 9/16" is 3-1/4 times as much as that of 5/16) so a winch that used to hold 100 feet of 5/16", would now hold ~30 feet of 9/16". I'm using 5/16 as a comparison rather than 3/8 because the break strengths are much closer.
Edit to add:
If you go bigger than 7/16" in synthetic rope, you better be planning on only ever single-line pulls, or you'll waste all the "savings" on the rope, on giant blocks, shackles, etc., to deal with the big stuff. Not that I think too many people will be double-lining a 30' long rope anyway, but ya never know.
Scott@Rockstomper is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 10:24 AM   #5 (permalink)
Member # 15992
and runs best though an arborist block for false crotch rigging.
i'd buy it just for that line alone.
i can go everywhere everyone else does -- the new england mantra
kjp98TJ is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 06:18 PM   #6 (permalink)
Member # 54522
i have used a 1in fire rescue rope but not on a winch. it was used with two shackles in an emergency to pull a truck out of a mud hole so thick you could stand on the mud. i would say no on a winch.
breaking stregth is about 2/3 more than working load i think.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 08:12 PM   #7 (permalink)
bigtoy302's Avatar
Member # 36440
Find A local rigging supply place and see if they have Yale Ultrex. It's 3/8" and 20,000lbs breaking strength. I piad $1.34 a foot at a local rigging supply. Me and several other local people run it with no problems.
bigtoy302 is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 08:58 PM   #8 (permalink)
that guy
MAD MAC's Avatar
Member # 10887
Send a message via AIM to MAD MAC Send a message via Yahoo to MAD MAC
this stuff is awsome we have several sailboats locally rigged with it
MAD MAC is offline   Reply With Quote Quick reply to this message
Old 10-30-2008, 03:48 AM   #9 (permalink)
Member # 108457
Take the amount of stretch into consideration when you shop for rope. It's usually published as percent of elastic elongation at percent of MBS. Amsteel Blue(as an example) 5/16's is plenty strong for most rigs, but 3/8' has a higher MBS which equates to less elongation in the line under the same load. I'm not saying to only buy amsteel, just that you should get something with the least amount of stretch as possible under your predicted loads. A rope with 13K MBS pulling my POS buried up to its frame is going to stretch more than I'd care to witness.
MrH8 is offline   Reply With Quote Quick reply to this message
Old 10-30-2008, 11:17 AM   #10 (permalink)
Member # 12225
FWIW...I tried some 11mm Static caving/rescue rope rated at 8K break just to try it out.My buggy weighs 3K and I run an old 6K Warn cut down to 4" drum used mostly to suck down the front end.Long story short.....The rope didn't work.......when the car was REALLY wadded up and STUCK.....the caving rope broke.......meh
jeepmauler is offline   Reply With Quote Quick reply to this message
Old 10-30-2008, 05:38 PM   #11 (permalink)
Member # 54522
static rope wont work for winching. you want a dynamic, non static rope. 11mm is just a thick rock climbing rope with that any sort of abrasion and it shreads like butter.
