high steer dana 50/60 unit bearing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-04-2008, 08:10 AM   #1 (permalink)
Hosejockey's Avatar
Member # 26577
any one have pics of how they have done this. my steering sucks and i need to atleast high steer one of them
dana 50 knuckles ball joint and unit bearing
Hosejockey is offline   Reply With Quote Quick reply to this message
Old 11-04-2008, 08:37 AM   #2 (permalink)
Member # 97519
Is this what your looking for
http://www.offroadunlimited.com/orus...idproduct=8268
HumboldtNick is offline   Reply With Quote Quick reply to this message
Old 11-04-2008, 08:58 AM   #3 (permalink)
Hosejockey's Avatar
Member # 26577
i was more looking for ideas of madifying your own that didnt cost 600 bucks a piece
Old 11-05-2008, 06:25 AM   #4 (permalink)
Hosejockey's Avatar
Member # 26577
no one has done this?
Old 11-05-2008, 08:15 AM   #5 (permalink)
Member # 50628
We took our knuckles to a local machine shop to machine it down smooth and flat on top, it was a $75 charge. We would build a steering arm out of 3/4" or 1" flat stock, weld it to the knuckle (pre-heat and post-heat since its cast) then we took the knuckle back to the machine shop and had them drill and tap for (3) 3/4" bolts.
Aggie007 is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 08:32 AM   #6 (permalink)
Member # 23035
I havent seen any high steer in this thread.. Only standard cross over. Thats the easy one!
[B]Kyle Prettyman[/B]
[B][COLOR="Red"]AzUndertakers[/COLOR][/B]
el ranger loco is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 09:01 AM   #7 (permalink)
dobsogj's Avatar
Member # 16561
Do it to both sides, then you have high steer.
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...
Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s.
dobsogj is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 11:28 AM   #8 (permalink)
Member # 36444
You can get high steer arms and knuckles from Currie
See link http://www.currieenterprises.com/ces...t.aspx?id=2936
kihm is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 11:50 AM   #9 (permalink)
Member # 50628
My point exactly, didn't know I had to spell it out.
Old 11-05-2008, 12:12 PM   #10 (permalink)
Member # 15461
hoser, just mill a flat into it and if it looks like there is enough material for a dana 44 high steer arm then put in the pattern or you'll have to make your own arms maybe.
and thanks for reminding me to get a kingpin axle when I redo the geo.
95geo is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 12:31 PM   #11 (permalink)
Hosejockey's Avatar
Member # 26577
i would get a unit bearing balljoint axle any day over king ease of taking apart and cleanliness is way worth it. i had alot of trouble keeping bearings clean in my chevy 60
Old 11-05-2008, 01:19 PM   #12 (permalink)
Member # 15461
it doesnt sound like the trade-offs are worth it considering you need $700 in knuckles to get high steer. that's a lot of wheel bearings!
Old 11-05-2008, 03:21 PM   #13 (permalink)
Hosejockey's Avatar
Member # 26577
not really saying i have access to two different lathes and mills
and wheel bearings are 100 bucks
Old 11-05-2008, 04:17 PM   #14 (permalink)
Master of none.
skipped_Link's Avatar
Member # 37865
Contradict much?
As already stated the unit bearings are stupid simple to work on & easy to keep clean on the trail.
Project: Monster Buggy
Axletech 4000 support parts available, PM me for details
skipped_Link is offline   Reply With Quote Quick reply to this message
Old 11-06-2008, 04:33 AM   #15 (permalink)
Member # 15461
Originally Posted by skipped_Link View Post
Contradict much?
read much?
Old 11-06-2008, 07:07 AM   #16 (permalink)
Member # 21938
I have tera 60 knuckles that use dodge 1 ton unit bearings.
northjerseyjeepclub
Save tellico #112
[I]origionall posted by entropy I'm so jealous, my penis just left me with a note telling me I'm a loser and he is going to find a cooler guy to hang with...[/I]
[I]Originally Posted by TrojanMan
It's on another non-4x4 related site too... jeepsunlimited.com[/I]
rokspydr is offline   Reply With Quote Quick reply to this message
Old 11-06-2008, 07:13 AM   #17 (permalink)
Hosejockey's Avatar
Member # 26577
read much?
i dont get what your trying to say
first you say mill it flat its easy
then you say buy 700 dollar knuckle
then you say buy a chevy 60 its much more practical.
so is it easy or should i buy a chevy 60 which i wont do because i like the unit bearings
Old 11-06-2008, 11:58 AM   #18 (permalink)
Member # 15461
you wouldnt get it, would you?
just stick to your unit bearing outers that you must to have because wheel bearings suck and live with the fact that you cant easily convert them to high steer.
because of the position that unit bearing knuckles put you in (bent over) I have decided to put a kingpin axle in it so I wont be in your situation where you have to spend $700 to get high steer as easily as with a king pin axle..... if you had just ignored the last part of my first reply you wouldnt have gotten so confused in the first place.
Old 11-06-2008, 03:35 PM   #19 (permalink)
Hosejockey's Avatar
Member # 26577
dont you have spider trax stuff. isnt that unit bearing
