NP231J vs. NP231C - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2008, 11:05 AM   #1 (permalink)
Member # 120434
NP231J vs. NP231C
anyone know if the cases are the same? I am looking into swapping in a chevy drivetrain into the TJ but I am gonna keep the 231. I was told that you can swap a np231C front casing and it will fit up to a TH350 (shaft wise)
b_rine is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 05:29 PM   #2 (permalink)
Member # 102365
all i know is that the j is built in japan
MOLON LABE
urbanmuddboger is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 09:15 PM   #3 (permalink)
Member # 37403
http://www.high-impact.net/transmiss...case_NP231.htm
NOPE! Input shafts will be different.
CrashKnott is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 09:56 PM   #4 (permalink)
Member # 65637
I think you need to swap the input from the Chevy to the Jeep.Jeep 6cyl is 23 spline 4cyl 21 spline.I think Chevy is 26 or plus spline.Look into as Im not totally sure.
[SIZE="1"]Jeep w things and stuff
My1stNiceJeep is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 09:32 AM   #5 (permalink)
Clemsonkrawler's Avatar
Member # 26940
Send a message via AIM to Clemsonkrawler
You will need the entire 231c. You CAN reuse your slip yoke eliminator kit from your 231j to save some money though.
'12 JKU trail cruiser.
Clemsonkrawler is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 11:30 AM   #6 (permalink)
Member # 38568
The differance between the C case and the J case are the mounting bolts. The J has 6-bolts the C has 5-bolts. The C case should have a 6-gear planitary. The case halves are swappable. But if your using a chevy motor just stick with the C case. The slip yoke eliminators will work with both.
rocknutyj is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 12:16 PM   #7 (permalink)
Member # 120434
well I already have a NP231J with the 4:1 teralow kit and a SYE. can I just transfer the "guts" to the 231c case? Also, what transmissions will the 231c mate with, without using an adapter?
Old 12-04-2008, 06:27 PM   #8 (permalink)
Member # 38568
Then you just need to change the front case half onto the np231J You will need an adapter to mount it to any trans. the adapter is differant depending on what trans you use. The output shaft might be a differant length depending on the trans. What did the chevy case come off of? I run a 700r4 attached to a np231c with a stock adapter.
Old 12-05-2008, 07:19 AM   #9 (permalink)
Member # 120434
I dont have a chevy case. I have a 231J case. and a SBC. I am just looking for the best way to run the SBC and the 231. I would like to run a 700r4. Will that trans bolt up to a 231c?
Old 12-05-2008, 07:27 AM   #10 (permalink)
Member # 38568
Yes pick up a trans and t/c from a 87-91 s10-s15 blazer with a 4.3 in it. The 4-cylinder version of the 700r4 will not bolt up to a SBC The later model s10-s15 blazers used a electronic shift np233c T/C
Old 12-05-2008, 07:38 AM   #11 (permalink)
It's bent. #ttb
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
NO.
The 4:1 kit uses a different ring gear for the planetary which isn't a 'serviceable' item on the 231 cases. It's a shrink fit into the aluminum housing and it's not removable without messing it up. You're kinda SOL on that one. You also won't be able to use the 6-pinion planetary carrier with it as the gears will be different.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is online now   Reply With Quote Quick reply to this message
Old 12-06-2008, 07:43 AM   #12 (permalink)
Member # 120434
so there's no way to adapt the 231J to the th350?
Old 12-06-2008, 09:28 AM   #13 (permalink)
Member # 30659
No. 231Jeep 231Chevy
http://advanceadapters.com/index.php...1+(23+spline)+[AX15]
http://www.novak-adapt.com/catalog/kit_131.htm
96 ZJ 5.2 with some stuff
97 K2500 Suburban 6.5 tow rig
bullitt9350 is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 11:50 AM   #14 (permalink)
Member # 38568
Check advance adapters. They might have something
Old 03-17-2009, 07:55 AM   #15 (permalink)
Member # 125253
Bump this
chadroc is offline   Reply With Quote Quick reply to this message
