Please help me identify a dana 60 front axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-20-2009, 06:16 PM   #1 (permalink)
Banned
Member # 115877
OK im trying to track down a dana 60 front axle chevy or dodge.
My friend that knows alot about this stuff told me that every dana 60 has the 4 bolts that bolt the tie rod to the axle on each side like this
did they ever make a dana sixty with a different style kinda like a DANA 44 with the C shaped deal and the 3 bolts on the drivers side where it mounts to the knuckle
I hope this all makes sense thanks guys
jokergerm is offline   Reply With Quote Quick reply to this message
Old 01-20-2009, 06:19 PM   #2 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
You're in luck! Today is Tuesday.....
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote Quick reply to this message
Old 01-20-2009, 06:20 PM   #3 (permalink)
Member # 86685
it will have 60 cast into the pumpkin on the bottom gusset
/thread
s10er8 is offline   Reply With Quote Quick reply to this message
Old 01-20-2009, 06:21 PM   #4 (permalink)
Member # 86685
the axle in your picture is a dana 63.5 anyway
Old 01-20-2009, 06:29 PM   #5 (permalink)
Banned
Member # 115877
ok but do all the dana 60's have the 4 bolts on the knuckles on each side?
Old 01-20-2009, 06:29 PM   #6 (permalink)
Banned
Member # 115877
oh really.............thanks ass
Old 01-20-2009, 06:34 PM   #7 (permalink)
Banned
Member # 115877
/thread
i know that but when im talking to people on the phone that dont know what they have, how can i explain to them what to look for
Old 01-20-2009, 06:53 PM   #8 (permalink)
jnau99's Avatar
Member # 18907
go here... Happy tuesday.
http://www.pirate4x4.com/tech/billavista/60_front/
jnau99 is offline   Reply With Quote Quick reply to this message
Old 01-20-2009, 07:36 PM   #9 (permalink)
Banned
Member # 115877
Originally Posted by jnau99 View Post
thanks
looks like they all have kingpin knuckle deals
Old 01-20-2009, 08:43 PM   #10 (permalink)
Member # 44136
Originally Posted by jokergerm View Post
thanks
looks like you can't read or search.
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 07:59 AM   #11 (permalink)
Member # 99437
Send a message via Yahoo to CTD NUT
thanks
You have failed to not suck and have been pwned by the lack of search. Couple that with the strong Tuesday feel you give off, and you will always get responses like you have received from this site.
There are tons of ball joint D60's out there. King pin 60's have been out of production since the mid 90's from the big 3. From my own experience, most people are tools and either don't have a clue or will mislead you on the phone - the ONLY way I know that you can be 100% certain about the axle you are trying to buy is to see it for yourself or get the seller to take good pictures and send them to you.
'80 CJ7-MPFI 454, 60's, linked, locked, C/O'd, bagged, tubed, Doublered, 111" WB, 44" TSL/Boggers
CTD NUT is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 08:11 AM   #12 (permalink)
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
All that is most certainly true. BUT. I bet the OP is about to buy a D44 on the assumption (hope) that it is a D60.
You will submit to your benevolent government and you will like it.
rustywagoneersdotcom is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 08:19 AM   #13 (permalink)
Member # 84970
Send a message via AIM to Xjcrawler736
HP and Drivers side drop.
Let me think
SEARCH NOOB...
Andy~
Ultra4 #4343 Co-driver -
Xjcrawler736 is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 08:48 AM   #14 (permalink)
Member # 13786
Nice photo chop from Foothill Offroads old website. I built that axle about 8 years ago. Ford HP 60, 5.13's, ARB, 35 spline thru out with chevy outers. Got sold to a guy in Chico. Ca. along with a van 14 bolt.
AND to answer your queation......yes they did, It's called a ball joint 60. No steering arm like the 44 though
KWTMECH is online now   Reply With Quote Quick reply to this message
Old 01-21-2009, 12:26 PM   #15 (permalink)
Banned
Member # 115877
thank you thats what i was saying. every one i have talked to has the c shaped steering arm on the drivers side with the 3 bolts. IE dana 44
And i am so sorry for trying to learn something on here. I was not blessed with knowing everything about axles from the day i was born, like some of you on here.
Now im going to kill my self for sucking at life and not automaticlly knowing everything about a dana 60
also that link says all GM AND CHEVY HAVE KINGPIN STYLE KNUCKLES
GM
1977-87 K30 1 ton 4wd
1984-88 CUCV
1988-91.5 V30
All GM / Chevy versions were passenger side differential, regular rotation (low pinion) gears, disc brakes, 35 spline inners, 30 spline outers, internal style hubs, and kingpin knuckles.
Dodge
1975-89 D-600
1992-93 D-600
1981-89 D-700
1992-93 D-700
All these Dodge versions were passenger side differential, regular rotation (low pinion) gears, disc brakes, 35 spline inners, 30 spline outers, and kingpin knuckles. 1979
Old 01-21-2009, 12:52 PM   #16 (permalink)
Member # 99437
1) GM = Chevy. And you are correct, they are all KP 60's and 91 was the last year a GM truck was offered with a D60 or a solid front end for that matter.
2) Dodge 60's were only KP up to 93. 94-02 is BJ. The 94-02 D60 front is just about the worst incarnation of all D60 frontends - it has the worst of all the combinations of parts - run, don't walk away from these axles.
3) Ford D60's were only KP up to 91. 92-97 were BJ. 98 and up Superduties frontends are also BJ and aren't much different than the 94-02 Dodge - they suck. Also beware that some Superduties have a D50 frontend that does look similar to the 60 if you aren't paying attention.
4) "My friend that knows alot about this stuff told me that every dana 60 has the 4 bolts that bolt the tie rod to the axle on each side like this" Obviously your friend does not know much about 60's. There is no factory D60 that has the tie rod bolted to high steer arms that are fastened by the king pin bolts and obviously you have learned that many D60's don't have have 4 bolts on the knuckles (KP only). The picture you tried to use to illustrate your point clearly shows the tie rod attached directly to the knuckles - sans high steer arms.
Old 01-21-2009, 01:56 PM   #17 (permalink)
Banned
Member # 115877
i guess i ment to say all dodge and GM d60 have kin pins
Old 01-21-2009, 02:01 PM   #18 (permalink)
Member # 13786
That would be correct, to a point. Look at the info above
Old 01-22-2009, 06:20 AM   #19 (permalink)
Member # 99437
You are getting pwned by your reading comprehension, again.
Old 01-22-2009, 08:39 AM   #20 (permalink)
Member # 42809
what could be simpler than having them look for a two digit number on the centersection?
YJ on Tons with Stickies
[QUOTE=robbybobby;9644636]duh bro- momentium.....i have my own special technique- haul Mother F-ng balls at the hill till i am standing alone at the gawd danged top.....[/QUOTE]
muddy_xj is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 10:19 AM   #21 (permalink)
Member # 99437
1) Lots of tools out there in this world that won't look for it, can't look for it or will lie to you. Comes down to how much you trust the person on the other end of the phone to properly identify the axle.
2) Not absolutely every pattern for these castings had a "D60" marking.
3) Rust, gunk, mud and whatever other combo of gonja that forms on an ancient axle housing can cover and/or deteriorate the marking. Couple that with a tool that doesn't know where to look and you can see where there is plenty of room for inconsistencies.
Old 01-22-2009, 11:00 AM   #22 (permalink)
Member # 65100
...did they ever make a dana sixty with a different style kinda like a DANA 44 with the C shaped deal and the 3 bolts on the drivers side where it mounts to the knuckle
Anyone EVER seen a ball-joint 60 that had a FACTORY steering arm bolted down like a D44?
If this is a pass-drop axle with steering as described... then... NVM...
Old 01-22-2009, 11:17 AM   #23 (permalink)
Member # 42809
You make good points, I just have always felt it was easier to have said tool look for the 60F casting, rather than describing some other characteristic of the axle that he probably doesn’t fully understand or can't locate despite your best efforts on the phone. The hunt for the D60 in the hands of an uneducated guy is an elusive one
Old 07-26-2011, 04:24 PM   #24 (permalink)
Member # 165933
Confused bout this axle ?
I have a dana 60 F as it says on the pumpkin. It has a C40386 on the front of the pumkin, and a clock looking thing on the rear ? I brushed the tube to see if I can see anything, but to my surprise, can't seem to find anything ? Is this clock an indication ?
homeboez is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 04:40 PM   #25 (permalink)
Member # 34281
Send a message via Yahoo to keller
Tusday again.
Shop build
My buggy build
keller is offline   Reply With Quote Quick reply to this message
