Married to divorced Tcase Conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2009, 08:53 PM   #1 (permalink)
Member # 121645
This may have been asked before but I did not find anything on a search of the forum. Can you take a married transfer case and convert it to a divorced transfer case? Say like a married NP 205 or NP 203 to a divorced unit. Thank for the help.
HMMike
HOWLINMADMIKE is offline   Reply With Quote Quick reply to this message
Old 01-23-2009, 08:55 PM   #2 (permalink)
Corey Young's Avatar
Member # 21622
Yes, but it would be better to start with a divorced unit. Only Ford used a divorced NP203. Ford, Dodge and IH used divorced NP205s.
Old 01-24-2009, 08:23 AM   #3 (permalink)
Member # 121645
Yes I know that would be the ideal thing to do, but it seems that married transfer cases are easier to come by than divorced one. So in order to complete the conversion, what would have to change?
Old 01-24-2009, 09:46 AM   #4 (permalink)
NorthWestFab's Avatar
Member # 40695
Input shaft change, find a way to mount the case, and find a way to seal the input yoke.
Married ford can not be converted to dfivorced, the input bore is too large.
The Little BIG Guys.
250-248-6024
NorthWestFab is offline   Reply With Quote Quick reply to this message
Old 01-24-2009, 01:00 PM   #5 (permalink)
Member # 121645
So you you at Northwest fab have the parts I would need to do a conversion like that? P/S I got a eeror page when I went to you web site
Old 01-24-2009, 01:39 PM   #6 (permalink)
Member # 40695
They're just moving my server ...
I'll check if I have any divorced stuff ..
250-248-6024
Old 01-24-2009, 09:15 PM   #7 (permalink)
Blazr77400's Avatar
Member # 7228
Here is what I did with the internals of a Divorced ford 205 and the case of a 10 spline chevy case. As NWF said, the divorced ford uses a small bearing (the same as the 10 spline case). So all the shafts swapped right over.
Then I just waterjetted and milled some bearing retainer/seal holder/mount plates for the 205.
84 K30 Crew Cab short bed
HP Tuned and Cammed LS 6.0, 4l80e
NP208 range box and divorce mounted 205,
Dana 60, 14 bolt, Hydraulic Assist
4 inch 52s, 3 inch 64s with 4" shackle flip
20x12 Forged Centerlines on 41x14.50 Irok radials
Blazr77400 is offline   Reply With Quote Quick reply to this message
Old 01-24-2009, 09:57 PM   #8 (permalink)
Member # 49108
Nice work on the divorced 205!
suprdave737 is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 05:13 PM   #9 (permalink)
Member # 121645
Very nice. So use a ten spline input shaft from a divorced 205? Will this also work on a 203? Also how did you seal the new input shaft?
NWF did you find any parts?
HMMike
Old 01-25-2009, 06:08 PM   #10 (permalink)
Blazr77400's Avatar
Member # 7228
HMMike
No, all the ford shafts were 32 spline. I think the only ones that are not 32 spline are the 31 spline married for the C6.
Not sure about the 203.
I sealed the input shaft with the bearing retainer, seal holder plate in the pictures.
Old 01-27-2009, 07:06 PM   #11 (permalink)
Member # 121645
Ok thank you I appreciate all of the help.
Mike
Old 01-27-2009, 07:18 PM   #12 (permalink)
Member # 23452
Blazr77400 is 100% right, the divorced 203 has a the same 32 spline input as the popular 32 spline outputs on the 205. so a 32 spline 1350/1410 will fit onto the 203 divorce input. i know this becasue the one i have i put a 1350 on it for mock up.
i found one on a 76 F-250 with an auto. i looked up the specs in a old ford book and ford called it the fulltime package. only was offerd in the F-250 and only with the auto.
jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote Quick reply to this message
