under hood wiring (ecu also) in buggy pics needed please
im wiring up my buggy and i need some pics for ideas of where to put my ECU, and how you guys did your wiring to make it look not so hacked up. I want to keep it realyl clean and simply but cant figure out a nice way to mount my ecu. Its a chevy LS1 ecu. Thanks for the help
2009 Twisted Customs buggy (sold :C) -----2001 Donzi 38zx -----2004 Duramax 2500 CC |
Member # 63680
Put the ECU under the dash. As for as the wiring hook everything up at the engine. Strip all the wire loom off and work your way back to the ECU. Cut all the wires to length and solder back together and heat shrink(one at the time).
It takes a long time but it comes out very clean. |
Sorry no pics, but my chassis is very similiar to the TC's (Rich Schmaus SP? built). The ECU on mine was bolted on a plate on the top of the truck intake all the way to the back by the dash bar. I flipped it over, and drilled the fins on either side and bolted it through the fins on the back of the truck intake.
The ECU upsidedown seems like it was made to fit on the back of the intake like that, I dunno, but it works so far for me. It dropped the height at the back of the hood by 3". I would have liked to have mounted over above the footwells (eitherside) but there just isnt enough harness to stretch that far.
Triple Nickel Racing, Lead Foot Syndicate & TGTW Lemons Racing 555race on TWITTER |
Member # 14455
I did the wiring for this truggy. I relocated the ECU to the top plate. I had to lenghted the wiring harness.
http://www.evolutionmachine.com/inde...8&hl=dash+help It was a holley projection ECU. I also mounted the MSD ignition modual, and Nitrous window switch all on the roof panel.
[URL="http://www.pirate4x4.com/forum/showthread.php?t=805235"]My new chassis build. 406SBC, 416 Mog axles, and 46's.[/URL] |
Member # 101932
Here is mine,
Street legal LS1 Bluetorch Buggy 12 volt guy switch panel, self canceling turn signals on timers, hazard flashers, running lights, brake lights, horn, high low beams, computer is mounted in a modified factory plastic bracket from a Vette. ![]() Most everything is on relays one fuse block for the engine another for everything else. ![]() Gauges and Switches ![]() ![]() Headlights with LED turnsignals ![]() Fan Wiring
Member # 101932
The lights are made by a company called Autonik that sells to the streetrod crowd you can find knockoffs on ebay for a lot less money but most of them are not LED. You also have to do a little cutting on the TJ buckets to make them fit.
