Rockwell: how much backlash is normal? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-22-2009, 01:36 PM   #1 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
I just bought a 2.5 ton truck. I have been studying the rockwell links on here for a while, and I just spent about 10 minutes searching, so here goes:
How much should the input yokes be able to twist (by hand)?
When pulling this thing home today, the front driveshaft was clanging a bit and upon investigation, the yoke will turn about a half inch or so, kind of like my Lock Rights in my other rig and the Detroit I had in a Toy once....
Could it have a Detroit? this is on the front axle although who knows what somebody put in there
Or am I fawked with a broken axle shaft?
Also, is the T case full time 4x4? It looks like it just has high and low?
TIA
BTW good grief that is a heavy truck!!!
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote Quick reply to this message
Old 02-22-2009, 04:19 PM   #2 (permalink)
Member # 5306
Ok, update: I just took the front driveshaft out and the T case was in 2wd. Also, the rear U joint was bad, so that was the clanging I heard.
But the yoke still has a lot of backlash. No up/down or back/forth play though.....
Old 02-22-2009, 04:27 PM   #3 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
That is a little more lash then mine have but your not dealing with just one set of gears there.
I am normally only a danger to myself don't make me include you!!
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote Quick reply to this message
Old 02-22-2009, 04:31 PM   #4 (permalink)
Member # 5306
What's strange though is the rears seem really tight, though I don't have the rear driveshafts out yet....
Old 02-23-2009, 07:31 AM   #5 (permalink)
Member # 5306
I guess I will just find out when I take it apart
Old 02-23-2009, 08:05 AM   #6 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Its hard to tell what you're calling "backlash" but if by backlash you mean the amount that the pinion yoke will turn before taking up the slack in the geartrain, the amount that it may have I would define as "a lot." I would say, in my experience, that what you are describing is normal and run with it.
J. J.
Like Patooyee's Parts on Facebook!
Old 02-23-2009, 08:51 AM   #7 (permalink)
Member # 5306
Yup, that's what I call backlash
Thanks for the replies y'all
Old 02-23-2009, 09:49 AM   #8 (permalink)
EOR MFG's Avatar
Member # 27228
Alot is normal... even up to an inch or so I have seen is common
[COLOR="DarkOrange"]
Your Offroad supplier for over 12 Years!
EOR MFG is offline   Reply With Quote Quick reply to this message
Old 02-23-2009, 02:06 PM   #9 (permalink)
Member # 68839
My rocks pinions can move 1/2" or so before taking up the slack in all the gears. I have run some fairly high RPM's with em like that and no issues. Sounds fine to me for rocks.
'79 F250, Rocks, 460, NP205, T18 and PSC 4-Wheel Steering
'99 F250, PSD, Rocks, BTS Tranny and PSC Hyd Ram Assist Steering
[B]Project Sarge build thread:[/B]
Ag4x4 is offline   Reply With Quote Quick reply to this message
