Welding 14 bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2009, 06:13 PM   #1 (permalink)
Member # 123940
Question Welding 14 bolt
Getting ready to weld up a 14 bolt and looking for some advice. I have read a few articles on here about it. Any good, better and best ways to do it?
Thanks
tenforty_2 is offline   Reply With Quote Quick reply to this message
Old 03-03-2009, 06:17 PM   #2 (permalink)
Member # 67882
clean all 14bolts and turn your welder all the way up! what you talking about? welding what?
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 03-03-2009, 06:23 PM   #3 (permalink)
Member # 33427
Seriously, there a hundred-plus threads on here if you search. I'll toss out my fav here
http://www.pirate4x4.com/forum/showp...2&postcount=30
myjeepsbigger is offline   Reply With Quote Quick reply to this message
Old 03-03-2009, 06:23 PM   #4 (permalink)
Member # 100284
He's talking about welding the spider gears to "Lock" the Chevy 14 bolt rear end.
I have not welded my 14 bolt but have seen several diffs welded up. Need to get really heavy beads in the contact area of the gears where the teeth mush together.
I'd like to see some picks when your done. I'm still in the debate stage between welding the diff and getting a detroit.
Silver '06 'X'
"The Pirate Boat!":skull:
KennyTJ is offline   Reply With Quote Quick reply to this message
Old 03-03-2009, 06:34 PM   #5 (permalink)
Member # 123940
Thanks for the reply! I am undecided on weld or spool. Due to $ I am getting closer to weld. I have read some stuff about the amount of stress it puts on the spiders if you just weld the gear valley. I will do pics when I decide what to do.
Old 03-03-2009, 07:12 PM   #6 (permalink)
Member # 123940
I like this one! Man I searched and could not come up with one specific to a 14 bolt! I hate it when people ask a question on a forum without searching first.
Old 03-03-2009, 08:36 PM   #7 (permalink)
Member # 88127
I made this one for my 14 bolt.
'92 XJ with add-ons
Tellico #625
Ratrace is offline   Reply With Quote Quick reply to this message
Old 03-03-2009, 08:54 PM   #8 (permalink)
Corey Young's Avatar
Member # 21622
http://pirate4x4.com/forum/showthrea...light=lift+48s
Post #19
Corey Young is online now   Reply With Quote Quick reply to this message
Old 03-07-2009, 07:49 PM   #9 (permalink)
Member # 123940
Quick Update:
I still don't have any pictures, but when I got it apart it has the gov loc system (only three spider gears). Not real happy about that, but I guess it will be as good as any since I will be welding it.
Old 03-08-2009, 04:27 AM   #10 (permalink)
GMCTruxrule's Avatar
Member # 51243
Get the Detroit. The most inexpensive Detroit for an axle too, I might add.
Especially if its DD, youll thank yourself later.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote Quick reply to this message
Old 03-08-2009, 01:13 PM   #11 (permalink)
Member # 1792
For a trail rig.I like to just weld it up.For street rig a detroit can be better for tire wear.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 03-09-2009, 02:58 AM   #12 (permalink)
Member # 131386
definitly go with the locker. once again, you
will regret it if your street drivin if you just weld up
the spidey gears.
swhite is offline   Reply With Quote Quick reply to this message
Old 06-06-2011, 03:44 PM   #13 (permalink)
rcfatcat's Avatar
Member # 181244
if your going to weld a gov lock make sure you turn out the actual hex locking system so it is spread as if the gov lock was engaged. it will tighten up the spider gears and make it a bit stronger. i made the mistake of not doing that when i welded my first one and it blew easily!.
Cool Meadows motor sports.
rcfatcat is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 02:11 PM   #14 (permalink)
Member # 212480
I know this thread is a few years old but I have a question. When welding up the 14 bolt why concern yourself with saving the carrier? They are a dime a dozen. Why not just weld the spiders to the carrier through the ports in the carrier instead of tearing it all apart?
frenum49 is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 02:19 PM   #15 (permalink)
Member # 94400
Because that isn't very much weld surface. Might work if you drive like a pussy and were going to run 31" tires.
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 02:23 PM   #16 (permalink)
Member # 212480
hmm
I just found this article. BillaVista agrees with me.
http://www.pirate4x4.com/tech/billavista/14b_bible/
Old 02-24-2012, 02:41 PM   #17 (permalink)
Member # 94400
If you trust it then that's all that matters right?
03 CTD toe rig
Texas Trail Buggy
Old 02-24-2012, 02:48 PM   #18 (permalink)
Member # 212480
yup
Thats a good point. Peace of mind is priceless. However, his theory here does make sense if you think about how the spider gears work in relation to the carrier. Filling the areas between the spiders and then continuing onto the carrier would share the loading stress between the carrier and the spiders instead of leaving all that up to spiders alone. Make sense to you?
Old 02-24-2012, 04:14 PM   #19 (permalink)
Member # 21240
Hoss50 is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 07:48 PM   #20 (permalink)
Member # 1792
The reason I only welded up the spiders only was so I could put a detroit in later if wanted without have to buy another carrier.Why spend cash if you don't need to.
Old 02-27-2012, 06:47 PM   #21 (permalink)
battlebuddy618's Avatar
Member # 101938
I welded up the spiders and welded them to the case and broke them with 4d's and a jeep 2.5. Had to buy a new install kit because the broken welds filled my diff up with metal and ruined the bearings.
This time around I'm putting in a grizzly locker and hopefully I'll be done messing with my 14b for a long while!
I'm Mike Scott
MAIL TO:
MY OLD RIG:
MY FB PAGE: (pics and stuff)
battlebuddy618 is offline   Reply With Quote Quick reply to this message
Old 02-27-2012, 07:21 PM   #22 (permalink)
kwrangln's Avatar
Member # 6971
Not mine.
I'm the "tack tack tack" welding nazi.
:flipoff2:
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote Quick reply to this message
Old 02-27-2012, 07:23 PM   #23 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
You guys are doing it all wrong.
/forum/general-chit-chat/763645-welded-dif-what-hell.html
MNorby is offline   Reply With Quote Quick reply to this message
