Dana 60 date code, is it on the board...? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-04-2009, 11:19 AM   #1 (permalink)
Member # 12164
Trying to look up my Chevy Dana front 60 and cant find the code in the bible.. Is there a listing here some where..........?
here are the numbers....610295 AHC ZFX
Looking for new rig to buy..1968-78 blazer or truck..$$ Thx
PLANE-SANE is offline   Reply With Quote Quick reply to this message
Old 03-04-2009, 11:48 AM   #2 (permalink)
The Mac's Avatar
Member # 21507
Used in '88-'91.5 V30
you would need to know if it a -1,2,3,4,5 or 6 to give you the ratio,
610295-1&-3 are 4.10
610295-2&-4 are 4.56
610295-5&-6 are 3.73
it does have an open diff 35 spline
LH axle part #907967-6 RH 907967-5
Hope that helps
Mac
Mac McMillan
The Mac is offline   Reply With Quote Quick reply to this message
Old 03-04-2009, 12:02 PM   #3 (permalink)
Member # 12164
here are all the numbers I could find
610295 4HC ZFX or 610295 AHC ZFX ......?? ( not sure if the 4 is an A or four)....?
C40386 (on pumpkin)
211B (on pumpkin)
Old 03-04-2009, 12:03 PM   #4 (permalink)
Member # 12164
Hope that helps
Mac
where is this I cant find it......? LH axle part #907967-6 RH 907967-5
Old 03-04-2009, 12:07 PM   #5 (permalink)
Member # 12164
here is a pic if it helps......................?
Old 03-04-2009, 12:16 PM   #6 (permalink)
Member # 129728
this might help ...
http://www2.dana.com/pdf/XGI.pdf
(thanks to reptillikus on FSB)
'85bronco,5.13s,60's,spool/detroit,2001cummins505/1032,2006cummins,KFX700-TRX 450r-RZR 900 XP
wv85bronco is offline   Reply With Quote Quick reply to this message
Old 03-04-2009, 12:23 PM   #7 (permalink)
The Mac's Avatar
Member # 21507
This is the book we use
Just type the 610295 in the "surch" box at the top and hit enter and it will find it for you, you will have to hit enter a couple times as it will find the number as it is used couple times and each time you hit enter it will got to the next spot it finds the number
http://www2.dana.com/pdf/X510-9.pdf
Mac
Mac McMillan
Old 03-04-2009, 12:24 PM   #8 (permalink)
The Mac's Avatar
Member # 21507
Originally Posted by wv85bronco View Post
this might help ...
XGI only gives you part numbers not where used or listings by BOM
MAc
Mac McMillan
Old 03-04-2009, 12:25 PM   #9 (permalink)
The Mac's Avatar
Member # 21507
Yep that's a Chev D60 like all the rest.
Mac
Mac McMillan
Old 03-04-2009, 12:32 PM   #10 (permalink)
Member # 12164
Mac
I could not find these numbers, and is this the four you where asking about...?
C40386 (on pumpkin)
211B (on pumpkin)
Old 03-04-2009, 12:44 PM   #11 (permalink)
The Mac's Avatar
Member # 21507
C40386 (on pumpkin)
211B (on pumpkin)
"610295 4HC ZFX "
If that the number than I would say it's got 4.56 gears in it.
The rest really don't mean much, the 610295 tells all..
Mac
Mac McMillan
