Member # 130484
Coilover Shock Angle?
I was wondering if any one has angled there rear coil overs to the rear of the vehicle instead of the typical forward lean? I have a 52' willys wagon and the coil overs need to lean rearward to clear my rear seat. But I have not seen a rig with this setup.
52 Willy's Wagon TBI 350, NP 435, Jed's 203-205 doubler,NWF Cable Shifter, HP Dana 60 Front/spooled, FF 14 Bolt Rear/Detriot, 5.13 gears, Full Hydro, One Link Front and Rear w/ 2.5 x 18" SAW's 39.5 Boggers on DIY Beadlocks |
Member # 3547
I used to.
It has exactly the same effect no matter which angle you lean them. Others will try and tell you different, but I can't figure out the reason it would be. Angle from vertical is angle from vertical - even compound (in AND fwd, for example) |
Member # 20394
You are correct, but there is one difference, you will lose travel mounting them to the rear of the rig. As the axle swings it will travel away from the shock instead or towords it. The difference may be nothing to care about, or may be a lot, epending on how it is mounted and how short your links are.
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#4 (permalink) | |
Member # 44416
I don't think it's the angle that matters per se, but if the angle from the shock is less than 90, and in some point in the travel goes past 90 the shock loses efficiency since the axle is more or less pivoting on it at that point. If that makes sense. |
Member # 130484
Thanks for the info my problem is I went with 2.5 coil overs and I want to put my shocks at some angle to make up for the fact that all the 16" and 18" x 3.0 springs are pretty heavy. And I don't want to be stuck with to heavy of springs. So I was hoping by angling them I would decrease the there rating enough to provide a lighter spring rate. I could mount the shock vertical with 10 degrees of inward lean but I don't know if that will be enough. Does any body have some #'s on what they are running in the rear just to get some ideas ( vehicle,angle,spring rate) I know every ones different but just trying to get some ideas. Don't want to build it twice
Member # 3547
Sorry, I should have clarified - I meant in terms of the effect the angle has on wheel rate, independant of the link geometry (and therefore the arc described by the axle as it travels) as that wasn't a variable given.
Good pick up guys, thanks. |
#7 (permalink) | |
Member # 3547
Try some calcs using the calculator here: http://www.pirate4x4.com/tech/billav...lovers/Part_1/ you can put in your available spring rates then vary the angles for mounting and observe the effects on the wheel rate. |
#8 (permalink) | |
Mr. DJ
Member # 85595
MY BUILD ![]() http://pirate4x4.com/forum/showthread.php?t=748821 BUY MY JEEP!!! http://www.pirate4x4.com/forum/vehic...tml?highlight= |
#9 (permalink) | |
Member # 20394
