Light powerful little engines ... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2009, 02:04 PM   #1 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Help me think ... what light-weight little 4-cylinders can be built to put out 200+ hp with decent torque numbers and can be adapted to an SM465?
Ecotec comes to mind but I think there is some issue with starter placement vs the manual trannies??? Can someone confirm?
VW?
J. J.
Like Patooyee's Parts on Facebook!
Old 05-04-2009, 02:14 PM   #2 (permalink)
I brought the beer
JeepRecoveryTeam's Avatar
Member # 10203
Send a message via ICQ to JeepRecoveryTeam Send a message via AIM to JeepRecoveryTeam Send a message via Yahoo to JeepRecoveryTeam
With a little bit of work, you can get a 3RZ toy motor to give you 200HP
Dave
JeepRecoveryTeam is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:19 PM   #3 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
VW?
J. J.
A 200+hp VW motor is going to cost $25,000+
Move to southern Utah! Visit my website
Lance is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:22 PM   #4 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Screw VW then. Didn't know they were that pricey ... hell you see them so often in the sand rails you'd figure they were a dime a dozen! That many people are dropping that much coin on sandrail engines though? Crazy ...
J. J.
Old 05-04-2009, 02:27 PM   #5 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
GTP supercharged v6?
what trannies would mate up/adapt with it?
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:31 PM   #6 (permalink)
513
Member # 121037
Just curious, ever think about the 3400 V6 engine? 325 lbs and some basic upgrades and you can push 240hp 280ft/lbs like the one Jesse used in his comp buggy.
/forum/general-4x4-discussion/576381-my-2007-badlands-comp-buggy.html
Just throwing that out there, not sure if you were looking for something lighter.
Edit: Would that would mate up to the SM465??
513 is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:35 PM   #7 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Lightweight V6's would be an option too. A 4.3 Chevy is too heavy though. Something in the range of Ecotec - 22R weight is what I'm interested in.
J. J.
Old 05-04-2009, 02:48 PM   #8 (permalink)
Member # 15461
either the super or turbo charged ecotec.... if memory serves me correctly ~250hp
http://media.gm.com/us/powertrain/en...2009/09car.htm
95geo is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:53 PM   #9 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I thought about those but I can't seem to find any info on putting the manual tranny behind them. I know you can put an auto but I think there is some sort of problem with the starter placement vs. the manuals. I would appreciate if anyone can confirm this?
J. J.
Old 05-04-2009, 02:54 PM   #10 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
Hell an LS motor is around 400 and some change, hard to beat that power-to-weight and how much lighter can a 4 cyl really be?
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 02:54 PM   #11 (permalink)
Blase's Avatar
Member # 63692
I don't have many specifics for you but My wife used to have a Honda S2000 and it had a 2.0liter four 4-cylinder that stock made 200HP. It was already mated to a six speed manual and was RWD. I have seen these cars dyno at 300 plus RWHP so it would do what you want for sure.
Only bad thing about those engines is the power band. 4K and below it was a normal 4-cylinder. 4K and above it made all of it's power
You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.
Blase is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:07 PM   #12 (permalink)
rotozuk's Avatar
Member # 8965
Hard to beat a new Ecotec with direct injection and forced induction. Also a rear trans is available stock from the Saturn Sky and Pontiac version. Going off memory, I think those were around 275 hp.
Toyota 22R probably weighs about the same as a 4.3. The newer Tacoma 4 cylinder motor is a far better choice then a 22R. It may not have the 200 HP (probably close though) but they have a bunch of low end torque and still rev pretty well. Plus all of the great Toyota drivetrain.
Still the Ecotec will weigh less. Other options are the 2 to 2.4 liter turbo motors from Nissan, Toyota, Mitsubishi, Chrysler etc. All will easily make 300 HP with out much work.
rotozuk is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:08 PM   #13 (permalink)
Member # 15461
J. J.
the sky and solstice are a RWD application so you could just divorce mount a t-case behind that?
do you want a bellhousing pattern? I can get that for you if you want....
Old 05-04-2009, 03:21 PM   #14 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Not so much a bellhousing pattern as confirmation that the starter has no issues with the SM465 bellhousing ...
J. J.
Old 05-04-2009, 03:28 PM   #15 (permalink)
Member # 187
S.C.A.T. V4 all you need to know google it
GearMan is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:29 PM   #16 (permalink)
mjlogan88's Avatar
Member # 23553
2.3 ford. not sure about the adapter, but if you want power and light weight they are a good way to go.
http://www.esslingeracing.com/midget-short-track.htm
http://www.esslingeracing.com/catalog/page32.pdf
my dad runs a 200lb esslinger motor that puts out well over 300 horse in his race car
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:30 PM   #17 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
Tracy Jordon loves his
camo is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:39 PM   #18 (permalink)
Member # 994
I was going to say ford 2.3 as well the turbo mustangs and tbirds can make good paower fairly cheap.
for every mile of road there is 2 miles of ditch!
Chet is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:43 PM   #19 (permalink)
Member # 22064
Let's see...
This:
http://www.jeeps-offroad.com/f41/eng...housings-4740/
And this:
http://www.ottindustries.com/22re-sm.htm
Have a ball...
Greg
Greg55_99 is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:47 PM   #20 (permalink)
Member # 993
Shortstar w/ a GM 60* bell housing. Just a quess.
USMC 0351
Rock Zombie
bagman is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:50 PM   #21 (permalink)
Member # 22301
Nissan V6?
phillyzj is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 03:51 PM   #22 (permalink)
Administrator
Lance's Avatar
Member # 1
Poor guy.
Old 05-04-2009, 03:53 PM   #23 (permalink)
Member # 5306
holyshit that is badass!
Old 05-04-2009, 04:01 PM   #24 (permalink)
DiscoDino's Avatar
Member # 15296
Subaru flat 4s? Mazda Rotary (crappy on Torque)? Rover V8s are a light 8 cyl...you can get 250-300 out of them....
'83 D130: 54" TTCs or 42.5" Boggers, OEM RW2.5s, Stazworks, LQ4, Atlas, dual M8274-50s, mid-mounted 9.5xp-s, dual 16" ORIs, PRP seats, etc...
'91 D110: 36" Iroks, R380, 2wd conv, underdrive, ARBs, 30 spl front, Sal D60 rear, caged, Fox remote reservoirs, M8274-50, and P&P exo-cage, etc...
DiscoDino is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 04:10 PM   #25 (permalink)
dan58's Avatar
Member # 19330
Send a message via AIM to dan58
Shortstar. IIRC, 225-250hp and not terribly heavy.
dan58 is offline   Reply With Quote Quick reply to this message
