Front Shaft Selection? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-13-2009, 12:55 PM   #1 (permalink)
WATERKNIFE's Avatar
Member # 83941
I broke a short side 35 spline,4340 Yukon shaft at the side gear during the collision with this rock. Didn't even realize it at the time because the carrier on my driveline also failed and we drove out rear only. CTM, outer shaft, arb and gearset were unharmed. The inner twisted about 3/16" and sheared clean. If I was to do it all over I would get a complete set of Longfields, but currently am just going to replace the shaft that broke.
From personal experience what MFG's shaft should I get?
Is this what I should expect from any 35 spline hardened shaft?
Thanks for your input.
YouTube - LS2 Buggy Roll
LS2 buggy build in progress.
05 LS2, 60 front 70 rear TH400, 4.3 ATLAS, 16" SAW Coils, 2" SAW Bumps, 44 TSL's
build pics
WATERKNIFE is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 01:07 PM   #2 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
yukons aint a bad choice but a set of Jacks drive Home shafts would probably do the trick for the big set of tires you got on.
BIGELOW MOTORSPORTS EST. 2003
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 01:09 PM   #3 (permalink)
lxh0318's Avatar
Member # 82770
You hit pretty damn hard! I'm not sure any shaft would have held up. How long have you been running those yukon's behind that LS2?
lxh0318 is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 01:15 PM   #4 (permalink)
WATERKNIFE's Avatar
Member # 83941
This was first run I took it on, been building for the past 3 years.
I know the tires are big, kind why I asking.
build pics
Old 08-13-2009, 01:33 PM   #5 (permalink)
onetoncv's Avatar
Member # 2160
ctm- and Possibly a stainless carrier on your 2 piece- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 01:46 PM   #6 (permalink)
lxh0318's Avatar
Member # 82770
Thats exactly what I needed to know. My new buggy has a TK LS2 in it and I have been trying to deceid wether or not to run the Yukons. I think I will be going with the RCV shafts and their 300M rear shafts. Since you already have the CTM's the " drive home shafts" or spidertrax 300M shafts would be your best bet.
Old 08-13-2009, 02:00 PM   #7 (permalink)
jpcrawleram's Avatar
Member # 18734
The best off the shelf shaft IMO Superior / Foote Axle
LetzRoll Offroad / LetzRoll offroad Racing 4493
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon gear and axle, Reid racing, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec), Rock Krawler, Artec Industries, ADS racing shocks, Rugged Radios
jpcrawleram is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 02:09 PM   #8 (permalink)
Pat
Member # 120
you running water in your tires?
Try out a AppleSeed...
Pat is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 02:16 PM   #9 (permalink)
WATERKNIFE's Avatar
Member # 83941
No water, maybe a little to much air at the time. only 7 though. Why?
build pics
Old 08-13-2009, 03:09 PM   #10 (permalink)
Member # 106808
CTM and don't look back.
KOH 2010
[COLOR="Silver"]Advance Adapters[/COLOR], [COLOR="Red"]Aurora [/COLOR], [COLOR="DeepSkyBlue"] Griffin [/COLOR],Baja Designs [COLOR="Blue"]Bilstein, CTM,[/COLOR] [COLOR="DarkOrange"]Currie[/COLOR], [COLOR="Silver"] D.J. Safety[/COLOR], Howe, J.E.Reel, [COLOR="Silver"]P.R.P Seats[/COLOR], [COLOR="Red"]Raceline Wheels[/COLOR], [COLOR="Orange"]Reid Racing[/COLOR], [COLOR="Plum"]Royal Purple[/COLOR],[COLOR="Silver"] Ruffstuff, [/COLOR] custom splice, Warn, 12volt guy
Mr.S is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 03:31 PM   #11 (permalink)
Member # 46785
Was the Yukon shaft a new one or old one? The reason I ask is I have seen a new D60 inner shaft and the design looked significantly changed, anyone else notice that? I say warrenty the shaft and run it till you save up the money or break again. By then you will be ready for one of the customs, CTM, Spydertrax...
Ty2003K is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 03:44 PM   #12 (permalink)
waynehartwig's Avatar
Member # 35700
Yukon does have a new manufacture on their shafts. They are making them tighter to their tolerances. Tighter tolerances, higher qaulity shaft.
Bring that busted one by, Tom and I'll show you how different they look. The new shafts are a lot darker in color. I also have a set of Foote forgings sitting here to compare to. Really you can't see much of a difference.
Yukon should have all of the inventory holes filled with this new shaft over the next few months. Right now they are trying to fill backorders, because the last company just wasn't cutting it and kept sending 'junk' (not to spec) shafts that Yukon kept declining - reason Yukon has been backordered on shafts for like 8-10 months now.
Just as a warning too, the manufacture is selling those 'junk' shafts to others and I've seen them on Ebay, here, etc. No, they do not have the Yukon name on them, but they will 'look' like a Yukon shaft.....
Hartwig Motorsports 4516, Team Yukon Gear and Axle
10% PIRATE COUPON CODE (not valid for harnesses and PCM tuning): pirate4x4
Special thanks to: My Family and Friends, Yukon Gear and Axle, DynoMAX Exhaust, AllTech Motorsports, Radflo Shocks, PAC Racing Springs, JM Rigging Supply, Reid Racing, Rugged Radios, Trail-Gear, Life-Time LED Lights, RuffStuff Specialties, Randy's Racing Transmissions, A1 Performance Converters, Maxxis Tires, Jesse Haines Fab, CBR Performance, PRP Seats, Exhaust Solutions, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 05:57 PM   #13 (permalink)
Danger Ranger's Avatar
Member # 1234
Man I can't believe *that* broke a shaft... I've done some pretty retarded shit in my rig and I've only been able to break a yukon bound up, full lock at full throttle. Even that, turned out to be more of a knuckle related problem than the shaft's fault.
If not today nor yet tomorrow then some other day
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 07:59 PM   #14 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Standard axle.......Long CVs or Branik (Superior)
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 08-13-2009, 09:53 PM   #15 (permalink)
WATERKNIFE's Avatar
Member # 83941
I am the second owner of these shafts. They were new in Nov. 2005. They only have 5 trips on them. I was told I cant warrenty it because I am not the original buyer. It is a stock axle housing. The impact definately forced the full lock position. I was pretty suprised it broke as well. But we did hit really hard.
build pics
Old 08-13-2009, 10:57 PM   #16 (permalink)
Member # 7624
Send a message via AIM to offroadman83
How are they gonna know you aren't the original owner? I don't have my receipt for mine so was wondering
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 08-14-2009, 10:29 AM   #17 (permalink)
Member # 35700
When a Yukon dealer, such as me, sends in for warranty consideration I have to give them the original invoice number the shaft was purchased under. Which means the owner of the shaft needs to go to whomever he bought them from and they need to get the RGA from Randy's. It's kind of complicated and they are strict about it.
Not sure if you've seen this thread:
/forum/jeep-hardcore-tech/585334-well-sucks.html
Where I fixed Wildman's axle. Even though I am one of the largest Yukon dealers, I still had to warranty the gears through the original shop Wildman bought them from - they would not allow me to do it myself.
