UFO teaser. - Page 55 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-24-2011, 04:34 PM   #1351 (permalink)
Member # 8790
Originally Posted by JR View Post
Miraculously, my horn playing is improving. I will have played 34 services at the Hollywood Bowl this summer, all principle horn.
Awesome.
Car looks great.
shaggyk5 is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 07:42 PM   #1352 (permalink)
JR
JR's Avatar
Member # 8524
It's alive!
SDC13765 - YouTube
JR is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 07:49 PM   #1353 (permalink)
JR
JR's Avatar
Member # 8524
The little vibration heard is because the p/s pump still had air in it. Once it was bled, it's vibration free and quiet. Purrs like a stocker and doesn't stink.
I turned it over to get oil presure and them primed the fuel pump set at 55 lbs.
It started right up.
Old 08-24-2011, 07:56 PM   #1354 (permalink)
JR
JR's Avatar
Member # 8524
There is only one oil leak which is somewhere between the pan and block right in front of the flex plate. It seems to come out a fast drip only when the engine is running, which makes me believe it's pressure related. The pan has probably never been off the engine and the bolts are tight. Hard to believe it has a sealing problem. Hope it's not something stupid like a cracked block.
Old 08-24-2011, 08:17 PM   #1355 (permalink)
Member # 8335
Hell yes. Congrats on startup that is a big moment. Motor sounds great at idle!
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 08:25 PM   #1356 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
I'm sure the block is toast. Send it to me and I can dispose of it properly.
Could it be the bypass adapter leaking or crank case pressure buildup?
AccuTune - Shock Tuning
Factor 55 - Recovery Gear
Master Pull - Winch Line
Optima - Batteries & Charging
Rigid Industries - Lighting
SPAL - Fans
Team 208 Motorsports Harness & Tuning
Hydrodynamiccrawler on Instagram
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 08:45 PM   #1357 (permalink)
JR
JR's Avatar
Member # 8524
It doesn't appear to be coming from the bypass adapter, which is the only thing I tampered with on the engine.
It seems to be coming from where the pan and the block meet (or up above it, I can't see above it) right by the bolt with a recess which is by the oil filter.
Wish I knew how to use paint so I could draw an arrow.
It's possible the leak is fooling me as to where it's coming from and could be somehow connected to the bypass adapter. I guess I'll start there.
Just doesn't make sense that the pan gasket would be leaking only when the motor is running.
Old 08-24-2011, 08:51 PM   #1358 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
It's alive!
Awesome!!
BTW, I didn't know you were related to Nolan and Dustin?
'15 F250 Powerstroke
'73 FJ40 Tons, 40s, etc.
'88 FJ62, 100% stock
'94 FZJ80 LS swap in progress
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 08:56 PM   #1359 (permalink)
Member # 94368
Congrats! Can't wait to see it move under it's own power.
Jordan Townsend - JRT Off-Road Racing #4580
Great parts and support:
JRTOffroad is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 09:00 PM   #1360 (permalink)
Beat95YJ's Avatar
Member # 22176
Originally Posted by Arya Ebrahimi View Post
Awesome!!
Dick!
Well he's a PR genius like you're a Camarogenius
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:08 PM   #1361 (permalink)
Methuseluh
Kula's Avatar
Member # 10940
Oil feed and return from the filter go through the oil pan gasket. Mine leaked on first start up. Changed the oil pan gasket and all was good.
Mark Kulachkosky
TLCA no. 2612
Kula is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:37 PM   #1362 (permalink)
I'm back and watchin
Easy Rick's Avatar
Member # 43607
Rear main seal. They don't like to sit.
Rick.
KOH racer #554
Huge thanks to our partners:
Trick Toys Fabrication, NITTO Tires, Longfield Super Joints, PSC steering components, Brian Smith
Easy Rick is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 11:13 PM   #1363 (permalink)
Newbie
hazzardfabworx's Avatar
Member # 143656
Also check where the flex plate bolts to the crank. Those bolts must be sealed. The threaded holes go straight through.
hazzardfabworx is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 12:33 AM   #1364 (permalink)
Member # 73963
That video made me happy. Jeff had a good smile going.
Great work JR. wonder if it still leaks after sitting overnight?
make more videos
IFS build
turbod the Lexus
Tons and 42's on the Lexus
laproscopic is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 05:09 AM   #1365 (permalink)
Member # 7876
Originally Posted by Beat95YJ View Post
Dick!
Old 08-25-2011, 09:07 AM   #1366 (permalink)
Member # 114046
Congrats JR! When's the shakedown run?
Desertbound is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 09:09 AM   #1367 (permalink)
JR
JR's Avatar
Member # 8524
We were about 95% sure that there was nothing wrong with it, but it was nice to hear the eBay motor run
Old 08-25-2011, 09:24 AM   #1368 (permalink)
Roc Doc's Avatar
Member # 20631
Hey JR, congratulations on getting your horn playing back. I don't think a non-musician can really understand what it's like to have that taken away and then get it back.
Oh, and pretty nice work on the car as well.
Pussy!
Suck it up buttercup, pirate takes care of its own. Even when they are post whoring retards!
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 09:32 AM   #1369 (permalink)
Roc Doc's Avatar
Member # 20631
Got some movie dates coming up for work on Mission Impossible 4. Hopefully, the recording work will pick back up.
Maybe we work with some of the same people? We had INXS in The Pearl theater last month and their opener was another Australian band called Andy Clockwise, and they guy they wanted to mix their show is a studio cat from LA that works for Paramount. Anyway this guy had never mixed a live show, so I had to do some handholding. He did fine because we use the Avid live consoles and their real similar to the Pro Tools he's used to.
Pussy!
Old 08-25-2011, 10:55 AM   #1370 (permalink)
BRB
Member # 976
cool story Hansel..
bada$$ f250 lifted on thornbirds
BRB is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 11:18 AM   #1371 (permalink)
Member # 3007
Originally Posted by BRB View Post
cool story Hansel..
Bones is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 12:13 PM   #1372 (permalink)
JR
JR's Avatar
Member # 8524
I think we work on different sides of the glass. I work on the side where all the noise is created.
Old 08-25-2011, 02:47 PM   #1373 (permalink)
whypave's Avatar
Member # 28177
I would also vote that the rear main seal is the culprit based on your description. It may actually work itself out and seal after it gets some run time. It happened the last time i changed my rear main, it had a slight leak and i was pissed but a day or two later it worked itself out If the ls7 block is like the other ls engines the two rear pan bolts are nearly 7 inches apart and only torqued to 17 ft/lbs or less so you may want to check those and the bolts right at the corners too. Congrats on getting it started. Great milestone!
whypave is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 02:56 PM   #1374 (permalink)
Member # 10947
Send a message via Yahoo to Hammer97
Band Geeks with fast rigs. I should have been nicer to you guys in High School. Cant wait to see it at KOH JR. It should be mean out there.
[B]Fly-N-Hi RACING[/B]
09 KOH Fan
10 KOH DNF
11 KOH LCQ
11 Tucson WeRock 3rd
12 KOH 40th, DNF
12 & 13 ADRA Champ
13 KOH DNF
13 Dirt Riot Western 2nd
13 Ultra4 Finals, KOH Qual
14 KOH 51st Start, DNF
14 Dirt Riot Congress 3rd
14 Dirt Riot Tucson 4th
14 Glen Helen 19th KOH Qual
Hammer97 is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 03:58 PM   #1375 (permalink)
Roc Doc's Avatar
Member # 20631
True dat.
Pussy!
