1972 ford f250 lift - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-19-2009, 02:45 PM   #1 (permalink)
Member # 146570
1972 ford f250 lift
I want a 4" lift to run 37 " tires I can buy a lift kit from skyjacker or have custom springs made for about the same price. What would be the better solution and is there any other options.
piney1 is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 03:21 PM   #2 (permalink)
JF
Member # 133890
This belongs in newb or ford section. Ask other people at the mall.
JF is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 04:06 PM   #3 (permalink)
71PA_Highboy's Avatar
Member # 73465
Good luck getting custom rear springs... they are the 'narrow' spring and not easy to find.
Got Ford?
68 &69 Bronco, 69 & 70 Mustang, 94 Ranger, 71 F250 4x4, 2 94 Lincoln Mark VIII - BF RI
This country is trying to childproof the world when they should be worldproofing their children.
71PA_Highboy is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 04:12 PM   #4 (permalink)
Member # 93989
Lift blocks
Lucky_Thirteen is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 06:02 PM   #5 (permalink)
Member # 146570
I don't go to the mall but this will see about half street use but never above 50 mph, only side roads and will see about half of its use on the trail. I will not use blocks. I have talked to two different places that will make springs for it.
Old 11-19-2009, 06:22 PM   #6 (permalink)
Member # 113376
i vote for hockey puck body lift.
co84rc is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 06:51 PM   #7 (permalink)
JF
Member # 133890
Is it pretty? Or is there a reason you couldn't trim to fit?
Skyjacker EZ ride springs are said to be "flexy". Many people pull and replace leaves until they have a "home brew".
Old 11-19-2009, 06:53 PM   #8 (permalink)
Banned
Member # 68805
works fine for me.
TJVigilante is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 07:24 PM   #9 (permalink)
Member # 21180
if you want a cheap lift, just put more air in the tires.
Casey
KC_JoNeS is offline   Reply With Quote Quick reply to this message
Old 11-20-2009, 05:02 AM   #10 (permalink)
Member # 73465
Be very careful when they say they will make springs for ya... 73 and up went to 3" wide and they may be thinking your's are the same... ask them what is the spring width they are making.
BTDT... it gets ugly.
Got Ford?
Old 11-20-2009, 04:57 PM   #11 (permalink)
Member # 104085
I Had a tough time finding the 2 and ahalf inch springs. Most places wanted to start by making stock replacments, rearching and adding add a leafs. Since that was what I was replacing (too stiff) I contacted Deaver spring got a quote and couldn't make that fit my budget. I ended up using used stock springs full length add a leafs and making my own 4" shackle drop brackets. End results are a very flexable spring pack with 4" lift. This is a pic of the spring pack I replaced same brackets.
RKDxpress is offline   Reply With Quote Quick reply to this message
Old 11-20-2009, 05:18 PM   #12 (permalink)
Member # 136617
runnerboyy is offline   Reply With Quote Quick reply to this message
