small lightweight AWD, IFS differential with 2.00-3.00 ratio? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2009, 11:26 AM   #1 (permalink)
inphobic's Avatar
Member # 8422
Send a message via AIM to inphobic
I am building a buggy for my boys and I am using a 3cly metro motor and automatic transaxle. I found out I can save 10" in chassis length by running the motor sideways (like in the metro from the factory) instead of front to back. I was going to use a geo tracker front IFS diff that would work great but the 3.73 ratio really makes the crawl ratio too low. SO...
What I am looking for is possibly a rear axle out of a AWD front wheel drive car that may have a 2.50 or 3.00 ratio. I was thinking maybe something like a CRV or Escape or subaru? I don't want anything big or heavy but will entertain any of your ideas. I don't know anything about this style of car. Thanks, Jake
Jake Good
inphobic is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 11:42 AM   #2 (permalink)
I'm back and watchin
Easy Rick's Avatar
Member # 43607
My dad just pulled one out of an awd astro van. May want to check that out I will find out the ratio if that helps, or you could call a chevy parts counter and ask for the gear set for one, and let them give you the ratios. I like to use GM as a reference kinda like a library, since we taxpayers own it now.
Rick.
KOH racer #554
Huge thanks to our partners:
Trick Toys Fabrication, NITTO Tires, Longfield Super Joints, PSC steering components, Brian Smith
Easy Rick is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 12:00 PM   #3 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
The subarus are a 3.9 or 4.1. They are narrow cv to cv and are very strong. You can weld up the diff easy. They were the best route for the cal poly 1/4 scale tractor. We attached the cv to warn hubs and cut down and welded the axle shaft to length. Those parts have been reused for the last 6+ years. Subaru parts were much easier to find.
AccuTune - Shock Tuning
Factor 55 - Recovery Gear
Master Pull - Winch Line
Optima - Batteries & Charging
Rigid Industries - Lighting
SPAL - Fans
Team 208 Motorsports Harness & Tuning
Hydrodynamiccrawler on Instagram
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 12:00 PM   #4 (permalink)
Member # 69441
Corvete IIRC used a dana 44 center in the indepent rear and you can get 2:73's from a cj
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 12:09 PM   #5 (permalink)
bigdaddylee82's Avatar
Member # 54666
The Metro, Suzuki Swift, and Subaru Justy were all the same thing right?
My thinking out of my arse has me fairly certain that the drive train from an AWD Justy would work with the Metro motor you already have. I don't have a clue about gear ratios though.
Just an idea.
Edit: this I assume would require you to use the Justy transmission with the AWD "transfer case" Or you might be able to get the transfer case to bolt to the auto trans and just use the Justy CV shaft for whatever side the transfer case is on.
I've since learned this probably wouldn't work, since the EF10 and EF12 3 cylinders the US versions of the Justy used were Subaru engines, unlike the Suzuki engines in the other similar models. They all became pretty much the same around '95, but '94 was the last year for the Justy in the US.
- Lee
No Vacancy
bigdaddylee82 is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 12:11 PM   #6 (permalink)
inphobic's Avatar
Member # 8422
Rick.
Yeah I called a buddy who works parts at GM dealer to try and find out what the ratio of my transaxle was for my geo and he couldn't tell ma anything but the part number...
Yeah so in my research so far it appears the rear is powered off of the pinion of the transaxle so it would have the same ratio as the trans. The pinioon is also really long on most of these diffs.
Yeah that would work great. It's alot bigger than what I was looking for but the gear ratio would be perfect.
Maybe I need to be looking at more IFS front diffs like the tracker. but I can't think of a vehicle that would offer a small diff and a high ratio...
Jake Good
Old 12-18-2009, 12:26 PM   #7 (permalink)
Member # 994
check out older BMW's they had IRS and all aluminum thirds. Most are around 3:1
for every mile of road there is 2 miles of ditch!
Chet is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 01:14 PM   #8 (permalink)
inphobic's Avatar
Member # 8422
Thanks chet. that is a good source. I found a 328i diff on ebay that has 2.93 ratio. I will keep an eye out for one of those on craigslist or the pick and pull.
Jake
Jake Good
Old 12-18-2009, 01:52 PM   #9 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
AMC Eagle?
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 02:12 PM   #10 (permalink)
the freeak's Avatar
Member # 41185
Thunderbird/ cougar. 8.8 IFS diff... I have one if you want to pay for shipping...
I THINK it has 3.08 or 2.73 gears.
the freeak is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 02:24 PM   #11 (permalink)
inphobic's Avatar
Member # 8422
There we go! very similar to the corvette stuff only not sought after....
Send me a PM on the axle you have. Thanks, Jake
Jake Good
Old 12-18-2009, 03:00 PM   #12 (permalink)
Member # 113619
Send a message via Yahoo to stjames151
HMMWV diff comes with 2.56, 2.72, 3.08 full IFS and 10k axle shafts are cheap as dirt. Comes with Torsen T-1 4:1 limited slip or you can get E-Lockers, or weld it.
[QUOTE=Roc Doc;11597106]This is so weak it makes Richard Simmons look like he's UFC ready.[/QUOTE]
[QUOTE=ironpig70;13786791]But it renforces the point to kids guns are toys.[/QUOTE]
stjames151 is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 03:15 PM   #13 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
Jake,
are you doing this like Rick deremo's 2 seat moon buggy, engine transverse with factory transaxle welded and running the shaft over to another diff to serve as your "transfer case". If so, the best thing to do there is to take the gearing out of the geo transaxle. rick took the shafts that make the gearing (assuming it isn't a ring and pinion, but more like planets) and made them all 1 so it was a 1:1 and then your second diff made your tcase gearing.
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Your ORI strut dealer along with about anyting else you need!
team Nasty co dog
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 03:22 PM   #14 (permalink)
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
Originally Posted by reddwarf View Post
AMC Eagle?
Eagle is a D30, laid out similar to the track/kick and GM truck diffs.
Available with 2.35:1, (most common) and 2.53:1, 2.72:1, 3.08:1 (next most common), and 3.54:1.
Bmw as mentioned. Mercedes 300D turbo, 300SD, and gas cars would also have a small (300D, 300SD) diff with 3.08's or big (big body gas cars) with 2.47's.
The 8.8 Ford independent also has a little brother 7.5 independent that is usually REALLY cheap to buy, as far as independent rears goes.
If you want diff's in the center, then the BMW/Mercedes/Ford is probably the best bet.
If you want offset diffs, then the S10/Eagle are probably what you want to look at.
You will submit to your benevolent government and you will like it.
rustywagoneersdotcom is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 03:25 PM   #15 (permalink)
inphobic's Avatar
Member # 8422
I am doing the same thing as Rick's old one. I will look into the transmission breakdown and see if there is a way to remove the reduction. I believe it is a GM 140 trans. The lack of an OD doesn't help at all for top speed. Not that I need much. a 2.73 or 3.07 ratio would be prefect on paper.
Jake Good
Old 12-18-2009, 03:28 PM   #16 (permalink)
inphobic's Avatar
Member # 8422
smaller is better. What was the 7.5 ford used in?
Thanks for all the great ideas guys!
Jake
Jake Good
Old 12-18-2009, 03:42 PM   #17 (permalink)
the freeak's Avatar
Member # 41185
Sent you a PM... the one I have MIGHT be a 7.5... it's been a LONG time since I looked at it.
Old 12-18-2009, 03:47 PM   #18 (permalink)
Member # 65100
Jake
I am no expert, but I am familiar with them from a couple 'Locost' builder forums.
IIRC the 7.5 IRS is in V6 t-birds/cougars/later mustangs and the 8.8 IRS is in the V8 ones.
Old 12-18-2009, 03:54 PM   #19 (permalink)
Member # 32069
Send a message via AIM to _peteyg
Jake
E30 style 3-series bmws are dime-a-dozen at any local pick-n-pull (at least, out here on the Left Coast), and you can get some really good stuff in them. However, that 3rd member is not too easy to get out. Bring metric tools and a lot of patience. Plus side: look for one out of a 325is or 5-series 530i or 535i. It'll be a 3.73, but it'll also be a nice LSD unit. You can put the 2.92 gears in the LSD diff. The housings are slightly different between the 3 and 5 series, but the internals are identical.
Minus side: The rear CV axles are practically a press-fit into the wheel hubs and are a real bitch to remove from the hubs, and even harder to get back in. Make sure you get the whole assembly. The hub bearings are not horribly expensive, but can be hard to find, and are hard to install.
_peteyg is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 07:08 PM   #20 (permalink)
inphobic's Avatar
Member # 8422
Thanks again guys for all the great ideas. I think the t-bird diff will meet my needs as far as cheap and easy to find. The 8.8 seems like a good idea for the new rage of IFS go fast cars being built too... JAke
Jake Good
Old 12-19-2009, 06:58 AM   #21 (permalink)
BAMF
Munchies's Avatar
Member # 42606
Cheap as dirt? HMm
Cummins tuning specialist. Small, big, and huge
Big rigs to gensets.
Emissions fixes available.
Munchies is offline   Reply With Quote Quick reply to this message
Old 12-25-2009, 07:16 AM   #22 (permalink)
the freeak's Avatar
Member # 41185
I just remembered that the newer EXPLORERS also have IRS, and I am pretty sure it's an 8.8!
Old 12-25-2009, 12:55 PM   #23 (permalink)
Member # 12714
If you want to add some factor, get a Mazda Miata diff
I struggled with *shut the fuck up, you clueless newb* but opted for nice since I was in a good mood
Patrol is offline   Reply With Quote Quick reply to this message
Old 12-25-2009, 05:16 PM   #24 (permalink)
Member # 41097
You could always go with a TTB chunk out of any of the 80's and newr ford pickups, dana 50, 44, or the little 30 in the rangers and bronco 2's, self sealed unit once you put a cover on it.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
It'll only be bigger, better, & tougher next year
mustange70 is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 05:24 AM   #25 (permalink)
Member # 21282
I'm no help but I'm interested to see what you come up with
good luck jake, post some pics
Recommended Stuff:
91blaze is offline   Reply With Quote Quick reply to this message
