Super 14 Tech - Page 18 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-06-2010, 06:45 PM   #426 (permalink)
KYODER's Avatar
Member # 5952
Originally Posted by lxh0318 View Post
Do you have to run axle seals with Dean's stuff?
Nope. I have no idea why anyone would run seals and grease. Oil is much better than grease for hubs for many reasons.
Need building time, oh ya and MONEY
KYODER is offline   Reply With Quote
Old 10-06-2010, 07:18 PM   #427 (permalink)
Member # 2395
Care to elaborate? I've been running grease simply because it doesn't make a mess when you pull a hub off. If there is enough benefit I would be willing to let them get oily.
2010 CalROCS Supermod Champions
Concept Wraps PRP Seats
Raceline Wheels CKRC Crawlers
Bulldog Winch 12 Volt Guy
Ruffstuff Specialties CTM Racing
Dustin is offline   Reply With Quote
Old 10-06-2010, 08:31 PM   #428 (permalink)
Banned
Member # 124890
I'll throw in my .02$ on this one as I've had my hands full developing the B14R lately anyways. Here is a pretty good comparison
http://www.machinerylubrication.com/Read/923/grease-oil
Both have pros and cons as you can see. Grease has been used extensively in wheel bearings for decades and oil has been as well. As much maintenance as a race car gets anyways I'd say that both are equally as good and is as much mechanic's preference over anything.
Ballistic Eng is offline   Reply With Quote
Old 10-06-2010, 08:38 PM   #429 (permalink)
I'm back and watchin
Easy Rick's Avatar
Member # 43607
I will agree that oil is not neccessary, except to cool for long hauls. But, if its cooling the ring and pinion as well, then go with it! Plus grease does not circulate, so any trapped debris will stay, and get fed back in, as oil will move weight/debris away, allowing the magnets to trap particles.
Rick.
KOH racer #554
Huge thanks to our partners:
Trick Toys Fabrication, NITTO Tires, Longfield Super Joints, PSC steering components, Brian Smith Development.............tricktoysracing@yahoo.com
Easy Rick is offline   Reply With Quote
Old 10-06-2010, 08:40 PM   #430 (permalink)
KYODER's Avatar
Member # 5952
Better lubrication and pulls heat from the bearings for starters. I can see using grease for crawling and it being easier to deal with, for fixes and for prep and inspection. But IMO oil is better for going fast and having it last.
Your rear brakes alone build huge heat that transfers to the hub, when hooking it through the desert, which is what I'm guessing the new car is for...
Old 10-07-2010, 05:33 PM   #431 (permalink)
Member # 2395
Somebody has to give you some VORRA competition...
I hadn't thought about it carrying brake heat away. I'll give it some thought. It would be nice to only have to make one set of axle seals.
Old 10-08-2010, 05:36 PM   #432 (permalink)
laproscopic's Avatar
Member # 73963
which seal would one run to minimize a leak at the hub if one were to fill the housing with oil. a standard dana part type seal at the back of the hub would leak like crazy wouldn't it?
and then to hijak....
and if all this filled-up-with-oil housing stuff is ok then is there any reason i cant just fill my ifs dutchman 9" housing to the brim to account for the flipped 9 im going to run up front? vs needing to run a pump or "scoop" type arrangement to keep it loobed?
laproscopic is offline   Reply With Quote
Old 10-08-2010, 07:18 PM   #433 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
A True Hi 9 takes a lot of oil in the front. It doesn't fill it up, but it does go up past the axle centerline.
The 9" pumps are pretty trick and not too spendy and it puts the oil right where you need it. As a plus you could run it to a cooler and then back to the gears.
Stand on your head to view that pic properly...
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market!
Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers
http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363
Tech Tim is offline   Reply With Quote
Old 10-08-2010, 09:20 PM   #434 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
sure you could... if you don't mind sapping your horsepower.
Lame Sig Line
DEnd is offline   Reply With Quote
Old 10-09-2010, 07:15 AM   #435 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Who makes that pump?
DrVic723 is offline   Reply With Quote
Old 10-09-2010, 07:25 AM   #436 (permalink)
Member # 70555
Tex racing
http://www.circletrack.com/techartic...ech/index.html
clicky---> Facebook Jim's Garage
http://www.mandmfab.com/
rock mafia is offline   Reply With Quote
Old 10-09-2010, 09:51 AM   #437 (permalink)
Member # 73963
i dont like the hp robbing thing. i like the internal pump. just set it and forget it. (and hope its working)
what about he hub seal thing. I know that this application has proam hubs but wouldn't a normal seal on a 14b/dana 60 etc leak if you overfilled the housing with oil instead of using grease?
Old 10-09-2010, 09:59 AM   #438 (permalink)
Member # 5110
14FF, D60FF, and most other full floating axle hubs use oil to lube the bearings not grease.
Is there room to run that 9" pump on a 14FF if you broached the pinion? The pinion isn't that low and the carrier is bigger.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote
Old 10-09-2010, 12:24 PM   #439 (permalink)
Dirt-Fab's Avatar
Member # 138167
You will also need to have the head of the pinion broached and the case machined to accept the pump. Mark Williams does it. May be less of a headache to send your case and pinion out vs. taking your machines down for modding one case.
AKA - Dusty Booger
Jeepspeed 1749 (1719 2008 Baja 1K)
www.dirt-fab.com
e-mail: info@dirt-fab.com
Phone: 510-502-8508
Dirt-Fab is offline   Reply With Quote
Old 10-09-2010, 02:35 PM   #440 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
Doubt it will fit the 14 bolt straight up but with a few mods...
Tim Lund
Old 10-18-2010, 05:19 PM   #441 (permalink)
Banned
DrVic723's Avatar
Member # 46226
A bit of a teaser... working with Jason @ Tubeworks right now to incorporate some of his recommendations, then it's time for production.
Jeff
Old 10-18-2010, 05:37 PM   #442 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
That's pretty bad ass. The only thing i dont like is the countersunk Allen head bolts. Judging from the bottom of our 9" those pockets that the heads are in would quickly be beaten down around the bolt head, and the hex's would also be thrashed, making removal a major pain in the ass. I'd much rather see regular machined faces for standard bolts.
Back when we were running 60's with crane covers we ended up replacing all the allen head bolts they supplied for just this reason. Every time we needed to pull the cover we'd end up welding nuts to the head of the bolts to get them out.
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 10-18-2010, 05:40 PM   #443 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Appreciate the feedback, Jason actually mentioned this same thing to us a few days about and haven't changed it yet.
IMO the skid still looks like crap, but we'll have something nice and pretty for final production.
Jeff
Old 10-18-2010, 05:42 PM   #444 (permalink)
Member # 124182
What material is it going to be made out of?
IrkedCitizen is offline   Reply With Quote
Old 10-18-2010, 06:09 PM   #445 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
Very cool Jeff, keep it going!
That's funny, I just showed this to Zippy7 and that was the first thing out of his mouth too...
Tim Lund
Old 10-18-2010, 06:44 PM   #446 (permalink)
Member # 15461
Awesome to see the progress!
I think a fitting name would be the BA14... Ballistic Apex 14 bolt? or Bad Ass 14 bolt!
Any thoughts to mirror the pinion over the centerline and have high pinion gears cut to fill that area of the market?
95geo is offline   Reply With Quote
Old 10-18-2010, 07:49 PM   #447 (permalink)
Banned
DrVic723's Avatar
Member # 46226
I've had HP gears quoted out and I'm not quite ready (or able) to spend that kind of $$$ at this point, but I've definately thought about it. Maybe offer one or two common ratios just to start with.
Material is A356.
Jeff
Old 10-18-2010, 08:05 PM   #448 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
I think those fillets could be X3 bigger but it looks great.
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 10-18-2010, 08:43 PM   #449 (permalink)
Dirt-Fab's Avatar
Member # 138167
Jeff,
How about something like the skid I built for my Jeepspeed. You could even make the front stick out more to protect the pinion yoke. (I'm not a big fan of the pinion guards as I think they collect rocks in the desert that can damage the shaft/yoke, but I see the use/application for the rock crawlers.)
Scott
AKA - Dusty Booger
www.dirt-fab.com
Phone: 510-502-8508
Old 10-19-2010, 05:32 AM   #450 (permalink)
One Big Zuk's Avatar
Member # 11145
Get one done for sema so I can finger fuc% it there. What is time frame. It would make a great stocking stuffer for my Truck last year he got a lomax 205. LOL He was pissed it didn't come with battery's
TTC 2010 Competitor #48 Thanks for the votes it was a great time.
Thanks to Micky Thompson Tires,King Shocks,Warn,RCV axles,ARB,Viking Winchline, OMF Wheels for the help to make my junk run.
One Big Zuk is offline   Reply With Quote
