Pressure in TH400 Oil cooler Line - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-26-2009, 11:32 PM   #1 (permalink)
Blown7's Avatar
Member # 63754
Like the title says, if I install a pressure gage in the oil cooler line, what should I see for a good pressure in a GM Turbo Hydro 400 transmission??
1977 CJ7, 401 AMC 6-71 GMC Blower, 16 Injector EFI,
[COLOR="Yellow"][SIZE="3"]My Build [/SIZE]
[/COLOR]
2007 Jeep Grand Cherokee SRT8 for the road.
Blown7 is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 11:42 PM   #2 (permalink)
Member # 17896
When? Idling, in gear? in park?? here's the factory spec:
neutral, brakes applied, 1k rpm: 55-70 psi
D, idle (idle "set to spec"): 60-85
D, brakes applied, 1k rpm: 60-90
Intermediate or lo, brakes
applied, engine at 1k rpm: 135-160
R, brakes applied, 1k rpm: 95-150
D, brakes applied, 1k rpm,
downshift switch activated: 90-110
this is for the oil pressure gauge mounted on the test port on the driver's side of the case. Hope it helps. *shrug*
tacoma73 is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 12:31 AM   #3 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
when I was deciding on what size lines to run to my cooler I was looking for the GPM. never did find the data I was looking for an went with a -8 line since the largest fitting with out a step is a 1/4 NTP to -8
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 12:36 AM   #4 (permalink)
Member # 17896
OOPS
I was thinking "what are good line pressures", not what kind of pressure you actually asked about. Sorry... I'll go get the bleach.
Old 12-27-2009, 11:21 AM   #5 (permalink)
onetoncv's Avatar
Member # 2160
Th-400's have a small flaw they build pressure when cold mainly due to the size of the cooler line and the fact they do not have a cooler by-pass like the th-350 built in to the pump , so warming them up is criticle other wise they build pressure and force the converter into the back of the crank and eat the bottom end of the motor . Like Camo said a 8 is a good size . And look for possibly a Wagoneer fitting there huge compared to the stock gm version- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 12:21 PM   #6 (permalink)
Member # 109586
I dont think that you'll see much Cooler line pressure over 10 Psi, and more like 5 psi when warm. Cooler line pressure is NOT the same as Line (regulated pump) pressure.
Kiwi
Kiwipushrod is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 01:29 PM   #7 (permalink)
Member # 31569
Send a message via AIM to hybrid-theory
http://www.jakesperformance.com/TH400_Rebuild_Tech.html If you have any other ques. I would ask this guy. Very helpfull.
2001 chevy 2500hd 8.1 allison auto
Sunfire Offroad (812)623-3473 The best customer service you can get!! Period!
hybrid-theory is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 09:58 AM   #8 (permalink)
Blown7's Avatar
Member # 63754
Yea the manual has that info also but Thanks!
I used -6 braided lines to the cooler
OOPS
No need.
Kiwi
Now thats interesting as I see about 15-20 cold and then it drops to about 5 PSI warm.
Thats why I asked
Thanks ALL
[/COLOR]
