what tire groover is best? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2009, 04:12 PM   #1 (permalink)
gomer pyle's Avatar
Member # 100025
i know that this is a loaded question and that there are multiple answers. i am wanting to get a good tire groover. i have looked at the van alston g-1000 and like it but what other good ones are out there?
427W EFI,C6,atlas, D80s and a whole lot of work left to do
gomer pyle is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 04:15 PM   #2 (permalink)
I LOOOVE ROCKS!
RockMolester's Avatar
Member # 28602
RockMolester is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 04:20 PM   #3 (permalink)
Corey Young's Avatar
Member # 21622
Originally Posted by gomer pyle View Post
van alston g-1000
That is the best one I have seen. Mine is about 8 years old and still like new after grooving 100s of tires. Make sure the tires are clean or the dirt will wear out the teflon and brass head.
Old 12-30-2009, 04:33 PM   #4 (permalink)
Tech Tim's Avatar
Member # 19067
Rema Tip Top 400.
It has 8 heat settings, very adjustable and easy to use.
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Tech Tim is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 04:39 PM   #5 (permalink)
JDunn's Avatar
Member # 33065
Originally Posted by Tech Tim View Post
Rema Tip Top 400.
X2 These work great! I grooved my 39.5 TSL's in under an hour.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 04:41 PM   #6 (permalink)
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
For rednecks like me:
You will submit to your benevolent government and you will like it.
rustywagoneersdotcom is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 05:10 PM   #7 (permalink)
twoslo4five0's Avatar
Member # 87916
this one.love it,wouldnt have it any other way,cuts off as soon as you get out the tire and cuts back on when you make contact with the tire.4 tires,2 hours with about 5 smoke brakes and 2 blades.
http://www.speedwaymotors.com/Instan...vers,2674.html
just read this is the same one you posted about.
19xx- never ending build.
twoslo4five0 is offline   Reply With Quote Quick reply to this message
Old 12-30-2009, 10:53 PM   #8 (permalink)
Tech Tim's Avatar
Member # 19067
Wow, 2 hours? How big are your tires?
Exactly! The Rema 400 makes grooving extremely easy and you can do a set of four on a single blade; about the only time we change blades is to go to a different size cut. And if it takes longer than an hour, you've either got something huge or extremely complicated cut.
Tim Lund
Old 12-31-2009, 05:25 AM   #9 (permalink)
Member # 87916
they were 42s.
Old 12-31-2009, 08:08 AM   #10 (permalink)
Member # 21100
Rema Tip Top 400.
x3. I have clients in the tire biz for 85 years, they have retread plants (Bandag) retail shops, and road service, all they use for grooving is the 400 and they do a lot of grooving.
EDIT: Just spoke to them, theirs' are Rillfit IV's. Same thing they think.
This was already the most interesting thread on pirate, then a tank shows up.
Bondage is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 03:45 PM   #11 (permalink)
Magnum_Willys's Avatar
Member # 25643
x2 on the Rillfit. 44" Bogger in 30 to 45 mins, room temp. Yea - too easy to play with - crazy kids !
51 Willys PU, 502 Chev, 70/80, CTM/CTM, Hydroboost, 44" Boggers, 205, T400.
Magnum_Willys is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 04:02 PM   #12 (permalink)
Member # 101054
MagnumWillys:
I have that exact same groover and I would never think of using a different one!!!
Those Speedway goovers are just fine.......UNLESS you have ever used a real groover! If have ever used a real one, then you will be very disappointed in the spwwedway type, single-heat range irons!
I am not better then anyone But I am just as good as everyone.
dmsFab is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 04:11 PM   #13 (permalink)
Member # 25643
The onetime I could see using those $59 heatup groovers might be siping. I haven't tried it but you can't flip the blade over and groove with the rillfits - with heat anyway. I doubt I can make a 1/16th or 1/32nd groove with the rillfit - haven't tried yet - 1/8 is a piece of cake.
Old 12-31-2009, 04:41 PM   #14 (permalink)
whiteman's Avatar
Member # 54841
This Is the groover I have. They dont make this version anymore but it works awsome. Most tires take 15min ea. with a three cut pattern. I cut some thornbirds with a five cut pattern and it took 1 1/2hrs for all four and they were 33's... I will never waste my time like that again.
whiteman is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 04:57 PM   #15 (permalink)
gomer pyle's Avatar
Member # 100025
a friend of mine is going to let me try his van alston
i will see how i like it.
i have to check with 4wheelparts and make sure this will not void my warranty, i hate to loose a sponsor
Old 12-31-2009, 04:58 PM   #16 (permalink)
Member # 101054
Siping is the only thing(in my opinion) that the "hot iron" style groovers are good for. I have made special blades for my Rillfits to do 1/16th cuts with heat. You have to turn the heat to its lowest setting to keep them from burning the balde up.
To make the 1/16th cut/slits with a Rillfits is that the 3/32" blades and "crimp" them shut. It makes a perfect "blade" for siping. On really soft tires, the 3/32" blades make a 1/8" cut due to the tire deflecting alittle.
Old 12-31-2009, 05:11 PM   #17 (permalink)
Member # 101054
Just for reference, this sipers here are a shit-ton of work!! I do not recommend these if you are trying to sipe road tires(hard compound) more then about 1/16" deep. I have siped race tires with one of these at about 3/16"-1/4" deep and it was a mother! Very good workout!
These sipers here are the way to go!
Old 01-02-2010, 12:13 PM   #18 (permalink)
Brink_'s Avatar
Member # 63901
Are blades still available for these? Where do I find them?
Brink_ is offline   Reply With Quote Quick reply to this message
Old 01-02-2010, 03:20 PM   #19 (permalink)
Member # 25643
They have a new model out RillfitVI. Blades are the same.
http://www.mile-x.com/rillfit-vi-tire-regroover.aspx
Old 01-02-2010, 05:17 PM   #20 (permalink)
Member # 101054
I buy mine Here They are the cheapest and best that I have been able to find. I have bought cheaper ones off ebay but they did not hold an edge very well and dulled very quickly. Good blades make all the difference in the world too.
EDIT: It looks like Poly has them too. Not a bad price at all considering how may blades you get!
But remember, more blades for less money doesnt mean it's a better value!
Old 12-22-2011, 04:33 AM   #21 (permalink)
Member # 109772
I've got this one. I can do a 44 tsl in 30 mins.
http://www.daymotorsports.com/product/403/TIRE-GROOVER
painter66 is offline   Reply With Quote Quick reply to this message
Old 12-22-2011, 09:30 AM   #22 (permalink)
Oregon Bronco II's Avatar
Member # 195250
quick tire groover 2 - YouTube
88/86BII.HP44 LS/9" Spool
Oregon Bronco II is offline   Reply With Quote Quick reply to this message
Old 12-27-2011, 05:49 AM   #23 (permalink)
Member # 109772
That works good !
Old 12-27-2011, 10:09 AM   #24 (permalink)
Member # 47212
From what I've heard...you'd be alot better off with a set of wood chisels and a torch than a freakin sawzall.
Five Nine ZJ..awaiting tons
'97 XJ in progress..awaiting 35" pitbulls on 3.75" lift
EndorphinJunky is offline   Reply With Quote Quick reply to this message
Old 12-27-2011, 03:54 PM   #25 (permalink)
AlxJ64's Avatar
Member # 130031
I have a Van- Alstine now, and it does good work.
But I used to have the old Speedway Motors special... It did okay... Ha ha.
Mal tire groover - YouTube
'42 Dodge WC53 - Cummins, Allison 1000, Eaton HO72 F/R, 38" Michelins
AlxJ64 is offline   Reply With Quote Quick reply to this message
