Wide Open Design build for Team Adam Racing 4467 - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2010, 05:36 PM   #51 (permalink)
Member # 41800
Here is an update of how the drawing is matching up the the actual buggy.
WideOpenDesign.com
615-962-9135
Woodlee is offline   Reply With Quote
Old 03-19-2010, 05:50 PM   #52 (permalink)
believe nothing i sa
blue p.o.s.'s Avatar
Member # 17121
damn doc, you weren't kidding when you said the buggy was unreal! that thing is gorgeous!
if you can't make it, get red labels.
blue p.o.s. is offline   Reply With Quote
Old 03-19-2010, 06:32 PM   #53 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
Buggy looks smokin.
Only question I can come up with is how are you going to stop the rear lower links from rotating with the shocks mounted above the center line and spherical bearings at each end?
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 03-19-2010, 07:08 PM   #54 (permalink)
Member # 11622
That is the shit!!!!!
Kamikaze is offline   Reply With Quote
Old 03-19-2010, 07:09 PM   #55 (permalink)
Stephen's Avatar
Member # 2092
Originally Posted by kwrangln View Post
Buggy looks smokin.
Hmmm?
What are you shooting for as far as front/rear weight? I'm not sure what's "right" but this one sure looks like it's going to be light in front. Awesome in the open to keep the front end up but maybe not so good climbing?
Stephen Watson
www.offroaddesign.com
#4488
KOH '13 1st ever DNF But we were hauling ass before and after it broke.
KOH '12 12th overall
KOH11 28th. It's a finish!
KOH11 Sportsmanship Award.
Friends & partners who helped: Offroad Design, Pacific Fab, King, Baja Designs, TrailReady, Amsoil, PSC, Tom Woods Driveshafts, Bighorn Graphics, Optima
Stephen is offline   Reply With Quote
Old 03-19-2010, 07:09 PM   #56 (permalink)
Member # 134196
Buggy looks smokin.
simple UHMW spacers around the misalignment spacers to keep the links in place
CheckMate Off Road Suspension Tuning
DavidG4x4 is offline   Reply With Quote
Old 03-19-2010, 07:14 PM   #57 (permalink)
Member # 42146
Send a message via AIM to snowdemon Send a message via MSN to snowdemon Send a message via Yahoo to snowdemon
Great job guys. Very well thought out chassis. Really looking forward to seeing this beast done. I love the CAD layout.
snowdemon is offline   Reply With Quote
Old 03-19-2010, 07:23 PM   #58 (permalink)
Stephen's Avatar
Member # 2092
Take this the right way, I'm not shy about learning...
If you put a hard spacer on each side you only get up and down motion around the ball, it can't let the link move side to side. Or does the material move enough to let it move side to side enough?
We use some urethane donuts to keep bent panhard bars from rattling but it's softer. Similar situation with some piggyback reservoirs on shocks, we use a urethane donut to keep the res in one place.
We put a stabilizer link on our rear uppers with the shock mounts on them along with putting the shocks on centerline. At least part of the reason for the stabilizer link is to keep the arms upright when they get hit/dragged too.
Stephen Watson
#4488
Old 03-19-2010, 07:24 PM   #59 (permalink)
Member # 33536
damn, who does your CAD work, that is sweet..
85blue4runner is offline   Reply With Quote
Old 03-19-2010, 07:41 PM   #60 (permalink)
Member # 134196
Originally Posted by KacksterK5 View Post
looks great. Any more bracing for the bump cans in the plans?
The front bump cans are boxed in now knocking out two birds with one stone holding the oil box in place and the rear will be incorporated into a removable cross member for access to drop the belly and pull the engine from top and bottom....
Old 03-19-2010, 07:44 PM   #61 (permalink)
Member # 134196
Don't forget you have two joints on the link itself which takes care of that motion....
Old 03-19-2010, 07:53 PM   #62 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
Simple and light weight, cool deal.
With Woodlee's attention to detail I knew it wouldn't be overlooked, but I almost expected to see something fancy like Poly did for Static's bronco.
Old 03-19-2010, 07:58 PM   #63 (permalink)
Member # 156607
Are you using Rhino CAD?
scott_bob is offline   Reply With Quote
Old 03-19-2010, 07:59 PM   #64 (permalink)
Member # 41800
I did all of it in house.
WideOpenDesign.com
615-962-9135
Old 03-19-2010, 08:08 PM   #65 (permalink)
Stephen's Avatar
Member # 2092
I'm guessing you're using a uhmw donut that takes up the space between the rod end and the mounting tab, is this right? At that point it would keep the link from falling over but at the same time it can only rotate around the bolt, not move laterally along the same direction as the bolt. What am I missing here?
Stephen Watson
#4488
Old 03-19-2010, 08:20 PM   #66 (permalink)
Member # 134196
Your right, it takes up the space between the rod end and the mounting tab.... In turn makes the link rotate in motion with the travel of the shock, it's almost like the lower joint on the shock is eliminated.... That means that the joints at the axle housing and the chassis turn. Doing this gives us better ground clearance at the links because they are flat, rather than running a standard desert style, where the lower shock bolts are lower than the center line.
Old 03-19-2010, 08:45 PM   #67 (permalink)
Stephen's Avatar
Member # 2092
So you're putting the "bushing" or spacer on the shock eye? That would free up the link arm to move side to side with the axle.
Stephen Watson
#4488
Old 03-19-2010, 09:57 PM   #68 (permalink)
Member # 134196
yes, on the shock
Old 03-19-2010, 10:12 PM   #69 (permalink)
Member # 134196
:d
Old 03-20-2010, 04:58 AM   #70 (permalink)
imagineer's Avatar
Member # 50419
What software is that?
Murphy's Law Motorsports #816
Check us out on FACEBOOK
Kessler Machine & Fabricating, Fox Racing, Raceline Wheels, Yukon Axle & Gear, B.F. Goodrich, NEA4WD, PAC Racing Springs, Spiegel Scrap Metal, Griffin Radiators, Baja Designs,AMSOIL, Flexcon Industries, Ruffstuff, HOWE performance
imagineer is offline   Reply With Quote
Old 03-20-2010, 06:30 AM   #71 (permalink)
angry
redneckengineered's Avatar
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Originally Posted by nazir adam View Post
Why is my mail box full of panties...
Bitches must have got my address wrong
redneckengineered is offline   Reply With Quote
Old 03-20-2010, 06:32 AM   #72 (permalink)
Custom Machine Shop
BranikMotorsports's Avatar
Member # 35218
Sick
speechless
www.branikmotorsports.com
extreme angle custom axles, 45-50 degrees!!!!
axle splining, D60, D44, 9",14B,MOG404,406
high steer 44 / 60 arms
custom suspension & steering.7075 LINKS
Patterns, molds, & dies.
TREC@BADLANDS ORP
FOR FAST ORDERING AND TECH
CALL-260-467-1808
PATTERNMAKERS
BranikMotorsports is offline   Reply With Quote
Old 03-20-2010, 09:27 AM   #73 (permalink)
onetoncv's Avatar
Member # 2160
Damn Adam - Lines are to sweet co comment on ! It reminds me of some Older cars the the lines they have , Charachter all the way- Your an artist . Jess
High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote
Old 03-20-2010, 06:38 PM   #74 (permalink)
syko's Avatar
Member # 746
Send a message via MSN to syko
Glad to finally see a build thread....
I can't wait to drive this thing or atleast bump it with my buggy....
Very nice.
#419X
syko is offline   Reply With Quote
Old 03-21-2010, 08:42 AM   #75 (permalink)
RockwelledToyota's Avatar
Member # 25217
Send a message via AIM to RockwelledToyota
Dope!
MUDDEVILS 4x4
North Carolina
RockwelledToyota is offline   Reply With Quote
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
