Member # 156634
offset diff?? which way to offset
Is there a preferred direction to off set a diff. Lets say the left front wheel lifts with torque when going up a sloop under a heavy load. Would you want to off set the diff to the side that lifts, or to the opposite side. Example would be: There would be a short axle on the left and a long axle on the right if the diff was offset to the left side. I just can't figure it out. Thanks in advance.
Member # 98189
For the most part, we just offset the diff to the side our transfer case is on. If you're buying an Atlas or Stak and trying to decide which side, then it seems to come down to what you're used to.
Member # 107883
My stock CJ-5 has both diffs on the passenger side, nice because if you miss it with the front, then the rear clears....
[URL=http://www.pirate4x4.com/forum/showthread.php?t=871614]Plasma Table Build / Torchmate 2x2[/URL] Chevy Build with 5TonRocks......Coming Soon.....:flipoff2: |
Member # 98189
Having both offset the same is nice that way, but unless you're willing to either stay with the dana 18 or put up with some pretty good driveline angles, there's not many t-case options.
"All Whee Drive!"
Member # 6450
Nice first post.
![]() If a corner lifts under load, something is wrong. Try changing the muffler bearing, that should help. You guys are slackin. Last edited by MochaMike; 03-20-2010 at 06:21 AM. |
skullfuckery
Member # 29016
you never said what drive train or axles you are useing.
there are lots of options and lots of ways to acheive offsets to both sides. d18 being about the worst possible way to do it. fwiw, i can not think of a single vehicle that had the rear offset to the drivers side.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP Last edited by trkklr77; 03-20-2010 at 08:58 AM. |
Member # 66858
On the front you generally wont have much choice. If this is a full frame, I'd be most concerned about keeping the drive shaft out of the transmision.
Member Deep Woods Extreme 4X4 Club Of Southern NH. |
#12 (permalink) |
After converting my TJ to 1 tons/40s and pass drop front, I am forced to run a super skinny front driveshaft and minimal uptravel w/ about 4" of lift to clear the bellhousing starter area...
I've found that there aren't too many engine/trans/t-case combos(worth swapping in) that will give a ton of room on the passenger side if you want to keep a low ride height.
-Tony |
#13 (permalink) | |
Pirate is KING!
Member # 12217
Methinks you bashed too soon! ![]() To the OP, if you're not competing at the highest levels, don't overthink it...it's a major tweaking thing that gives SOME results, but yes, you are right, it DOES make a difference, especially when climbing.
. Dustin Webster Red Bull RockCrawling Team RockHer 1 - SOLD |
#14 (permalink) |
StinkyFab Racing
Member # 4946
The RockHer2 has both diffs offset to the drivers side. I know there are others, I just cant think of them. I can think of a lot of cars with both diffs offset to the same side, just cant remember which side they are offset to.
Dallas Ashley StinkyFab Racing (SFR) - Custom Fabrication Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more! Overall Winner, 2012 KOH EMC. Gettin it done in a stocker! Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008 |
#15 (permalink) | |
Member # 46175
I am having troubles seeing the differences in the leverage forces with the dif on either side.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
