#26 (permalink) | |
![]() The Tie rod is plenty heavy enough.
nothing but a bunch of pipe and cast off parts. |
#30 (permalink) |
Member # 142394
First two pics are My first attempt on my old ramcharger cabtruck, worked awesome and never had an issue..Had to upgrade the tie rod to 2 1/4" 1/4 wall dom..But I never had a binding issue.Just a shame this was on a 44
![]() Last pics are the new setup. Hated to rig it up like that but the truck was wedged between a metal rack and a drain pipe.It doesn't bind but the pins loose the slight slop they have at full lock..Just had it out for 6 hrs and it did pretty well.
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools |
#31 (permalink) |
playinwithit
Member # 97574
Playin' with my Willys buggy build |
#32 (permalink) |
AZ Undertaker
Member # 51580
Nothing special on the axle end, but I got sick of 1/8" tube pinch clamps stretching and coming loose.
![]() ![]() 3/8" ram mount tabs, 1/2" pinch plates, 2.25x.250wall tube, 1.75" 7075 tierod ![]() ![]()
MILLER RACING #26 2012 Dirt Riot Modified Trail Class Champion ADS SHOCKS * ARTEC INDUSTRIES * SOUTHWEST FASTENER * HOWE PERFORMANCE * RUGGED RADIOS * SDHQ * BLACK N BLUE RACING * RIGID INDUSTRIES * CAMPBELL ENTERPRISES * LETZROLL OFFROAD |
#33 (permalink) |
Creepy
Member # 71034
Here's what I came up with
Eric Amato Amato Motorsports #099 4x4Play Clothing, Justice Racing Engines, Black Hat Fabrications, East Coast Gear Supply, Inner Air Lock, Cut Throat 4x4, SteelMX Optics |
#34 (permalink) |
Essentially Offroad set up this for me - 2" aluminum tie rod with a .25" step machined to accept a 1.75" tube clamp - simple mount welded to the truss for the fixed end
2012 KORE Defender Buggy, 14 bolts, 6.0, PTC 400, atlas 3.0 Special thanks to Essentially Offroad |
#35 (permalink) |
107
Member # 39660
Thought about starting this thread myself, interested to see more.
Big Boned Toyota Build The collective writing skills of the PBB is equivalent to a blind down syndrome-afflicted monkey with no hands and epilepsy. |
#37 (permalink) |
107
Member # 39660
#39 (permalink) |
Member # 23452
Kinda hard to see the axle end, but its juts a box secxtion made from 1/4" plate.
![]() Rod end ![]() Rear was simple just used a low steer right off the tube and cover. ![]() ![]() Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money. |
#40 (permalink) |
Member # 18734
[IMG]http://i143.photob
LetzRoll Offroad / LetzRoll offroad Racing 4493 www.letzrolloffroad.com 480 797-0469 All your Hardcore Crawling / Racing needs! PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon, Reid racing, Trail Ready, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec) |
#43 (permalink) |
I started out with a clamp on the tie rod but the tie rod would work it self loose and then the ram would drop down lower. I also lost some ram travel with the pivot of the heims through the steering cycle.
The fix: ![]()
S&N Fab Bravo #1 Build Thread: http://pirate4x4.com/forum/showthrea...900&highlight= |
#44 (permalink) |
Member # 47730
so do you think it is better to mount the ram to the tie rod or to the high steer arm? have seen them both ways. seems like if you mount to the high steer arm you can adjust it to make it faster or slower depends on how far out you mount it on the arm.
a bunch of tube.a v8 and other stuff.. |
#48 (permalink) | |
Member # 6170
![]() Kevo |
#49 (permalink) | |
Member # 96153
DD:09' V8 Colorado Toy:The Blazer Build Ultra4 #818 Old tow:92' Dodge Build Sold ![]() New tow:05' Dodge Crew 4x4 CTD (stock for now) 18th at Glen Helen 13' ![]() Complete 465/203/205 For Sale |
#50 (permalink) |
AZ Undertaker
Member # 51580
I like mounting to the arms, was just gonna be a ton of work on my rig. BJ knuckles machined, arms made, finding out how to clear the leafs with the ram, etc. I was always worried about the pinch clamp slipping, not anymore with the new one I built.
