Member # 74576
Are your 20" wheels TOO big?
Unfortunately wheel sizes jump from 17s to 20s. We all know 17s work great, but sometimes brake clearance is an issue and it seems like a lot of tires are going towards 20" wheels.
In just the last few years everything has jumped from 15s to 17s....so what will be next? The sidewall on a 42" with a 20" wheel looks awfully small. Haven't heard much on how 20" inner beads are holding, either. Looking at 41-43" tires. Iroks are available in a 20" already. SX and SXIIs are available in 20s. The new 42" Krawlers are ONLY available for a 20" wheel. Maxxis doesn't seem to have moved to 20s yet however I don't know what their plans are. Those of you that have 20s...do you love or hate them?
Member # 95513
I have been running 20's for a long time on various buggies and really like them. There seems to be a lot less sidewall roll at high speeds and handle really well. The only down side is until recently , you couldn't find a tire that had enough sidewall flex to really contour to rocks when aired down and crawling. Now there are a ton of tires available that work great in the rocks and at speeds with a little air adjustment !! I cought a ton of flak for running 20"'s back in the day and now with everyone wanting to go faster and faster their starting to catch on ! I predict a large number of rigs on 20's next season for ultra 4 events !!
Curling your toes every time you slide behind the wheel !! www.tanner4x4.com Check out www.RMXmotorsports.com for all your used hardcore offroad parts !!ORI STRUTS available now !! KOH specials [B]FINANCING AVAILABLE ON TURN KEY RIGS!![/B] Turn key buggies starting at 34,995.00 |
#4 (permalink) | |
XJ Based Buggy: 42's, Tons, Full Hydro, ORI's and a fukkton of tube... [url]http://pirate4x4.com/forum/showthread.php?t=856928[/url] |
Pirate is KING!
Member # 12217
They bend more due to the rim edge itself not only being closer to the ground, but the radius is larger, therefore weaker. Some situtions they will perform better with a given tire size, in other situations they would perform worse...there realy is no "magic" size that fits every situation. As mentioned above, anything less than a 40 and you're going to be sad. You will lose performance due to sidewall and really pushing the damage issue.
FYI, softer tires on larger rims have more "pinch cuts" as well. There is not enough rubber to dissipate the tire being pinched between the ground and the rim edge in certain tire loading moments so the tire gets cut from the pinch.
. Dustin Webster Red Bull RockCrawling Team RockHer 1 - SOLD Last edited by RedBullJeep; 08-03-2010 at 09:29 AM. |
Member # 95513
I have not had any failures in the 8 years I have been using the 20" Trailready beedlocks. However , I have always run them on 40" plus sizes.
I have run them on 2 seaters , 4-seater and even a couple bodied rigs. These rigs have been wheeled hard and even competed in. it would make sense that the larger diameter would be weaker , but i haven't had any problems with it ! Maybe a plus for the wheel manufacturer !!
Member # 73963
If ultra 4 is to be a reference point:
then the argument that a smaller sidewall offers better handling may be legit BUT would this benefit be negated by the extra weight of the 20 inch wheel? How much heavier is a 20 inch locked wheel vs a 17 incher? (and how many more bolts?)
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
StinkyFab Racing
Member # 4946
The wheel may be heavier, but the tire has less rubber, so it's lighter. I think it's gonna vary a lot with wheel and tire brands, but overall the weight is not gonna be a huge difference.
Dallas Ashley StinkyFab Racing (SFR) - Custom Fabrication Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more! Overall Winner, 2012 KOH EMC. Gettin it done in a stocker! Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008 |
#9 (permalink) | |
Pirate is KING!
Member # 12217
![]() DAYUM those were HEAVY! 1/2 thick beadlock rings that could absolutly take a beating. Oh yeah, that reminds me...the wheel opening is larger so you get hung up a bit more often on things that may slip into the rim...hence the photo above with the wide rings to counter that.
. Dustin Webster Red Bull RockCrawling Team RockHer 1 - SOLD |
#10 (permalink) | |
Member # 73963
from the interco websight: a 41/14.5/17 radial irok weighes 101lbs a 41/14.5/20 radial irok weighes 99lbs I run low profile tires on me porsche and they hold the road tight but love having a big ballooning sidewall on the crawler
#13 (permalink) | |
Pirate is KING!
Member # 12217
#14 (permalink) |
Piggin' Ain't Easy
I run them on my "stock" f350 summer trail beater (A/C blows ice cubes)
Seem too work fine. I run 35s on 16" wheels on my crawler, and the 40s have more sidewall on 20s.
Nick Cooper StockRunner build (stock height link suspension) turned firewall buggy Gremlin build - small ugly linked beater truck |
#15 (permalink) | |
Member # 84454
[QUOTE=-Dex-;13278433]You're the kind of guy who isn't happy with just sticking a finger up his ass while jacking off, you have to pull it out and smell it afterwards too don't you?[/QUOTE] |
#16 (permalink) | |
Member # 11684
I was hoping that by the time my current tyres wore out there would be more options in a 40" or 42" x18", but it's not looking that way
#17 (permalink) |
snatch cannon
Member # 11745
Naaah its not too big!
In fact my 1965 truck came with 20's stock and other models had them stock 20 years before that! Rollin Dub's for Fitty Years!
Later, Ken 1 Mercedes Benz Unimog 404s |
#18 (permalink) | |
Member # 21211
Now back on topic...
buggy with 404's 5.0 HO and a 4-speed [quote="Poohbair"]...because I am white trash I think I actually did say "fuck... look at that..."[/quote] |
#19 (permalink) | |
Member # 11684
They are the perfect size other than the choice of tyres available, I don't want to go to 20"s for pretty much all of the reasons listed in this thread. |
#20 (permalink) |
Member # 2395
I ran the 39.5 Iroks on some 20" Stazworks rims for a while. I really liked the setup, it was surgical. The only problems were the weight of the rims @ 85lbs each, the decreased ride comfort, and the lack of tire choices.
If you think about it, a 42" Krawler on a 20" rim is going to have ~ 1" more sidewall as a 37" Krawler on a 17" rim. The new 42" Krawlers are at the top of my tire wish list. Last edited by Dustin; 08-05-2010 at 01:42 PM. |
#22 (permalink) |
RockWild Racing
Member # 118508
20's with 42" SXII's. love my 20's. BUT I have bent a couple of them pretty bad in a couple races. If you get the 20's definatly look at a inner beadlock or a stiffener ring in you go aluminum. Never broke an inner bead but thats were they always seem to bend.
Team Rockwild Moroc Super Mod #528 Rrock Legends Spotter #619 |
#24 (permalink) | |||||
Member # 74576
![]() Quote:
I'm looking forward to the 42 Krawlers too....but I know the price tag is going to hurt.
