Detroit Locker vs Yukon Grizzly Locker for 14Bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-09-2010, 03:09 PM   #1 (permalink)
Member # 146266
I'm planning to run an automatic locker on my rear GM 14b, what you suggest to buy?
Acerni Offroad is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 07:02 PM   #2 (permalink)
noob
Member # 66544
I have been running Yukon lockers on our competition rig all season. I absolutely abuse them and have not had a failure yet. Good quality for the price!
El Destructo! I void warranty's!!!
Team Rock Limo
F-Toy #F002
Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy
noahfecks is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 08:08 PM   #3 (permalink)
Member # 47380
Whats Retail on Each?
:flipoff2:
oakesters is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 10:17 PM   #4 (permalink)
Member # 119605
I Have run both detroits and grizzly lockers, (In a toyota mini-truck though).
I did not notice a difference between the two. Both engaged smooth and worked great. Supposedly with the Grizzly you dont have to worry about hurting the locker when you break a shaft. I would definatly go with the grizzly just because of the smaller price tag.
85ToyotaTom is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 09:52 AM   #5 (permalink)
Go2Guy's Avatar
Member # 12158
The Grizzley is designed to be stronger in the drivers by a signinficant amount giving way more durability if you break a shaft, the weak spot in the Detroit. I've run them both and the Grizzleys are doing just fine, even with some wasted shafts. doesn't Yukon have a pretty decent warranty as well?
In the 9" version it's just under 4x stronger at the drivers.... easy decision for me.
Ken Blume
Rock Rod Racing
Team #192/4192
Thanks to our partners
Maxxis, Trail-Gear, Yukon Gear, Goatbuilt, Tom Woods Custom Driveshafts, Ruffstuff specialties, Warn Winch, Rokit Enterprises, Viair, Edge Perf., Branik Motorsports, PRP seats, 12V unlimited, Bailie built, Alltech, Raceline
Go2Guy is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 10:29 AM   #6 (permalink)
Member # 88939
Looking at Yukons website, I could not find any for a Dana 60. Are these available? Or am I just not looking hard enough?
If off-roading is outlawed, then only outlaws will off-road.
Let us speak courteously, deal fairly, and keep ourselves armed and ready. Theodore Roossevelt
Rekless_Off_Road is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 11:12 AM   #7 (permalink)
Member # 21240
I don't know much about the Grizzly but if it is stronger against shaft breakage then it might get the edge. My Detroit has worked great but I know 2 people who have broken a 14bff shaft and both times the Detroit grenaded at the same time. If the rig is strictly offroad I say weld it, minispool, or spool. If you are onroad then toss a coin. If you are not worried about breaking a shaft then a Detroit is great. If you are in shaft breakage territory then the Grizzly might be a better option.
Harley
Hoss50 is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 12:08 PM   #8 (permalink)
Member # 146266
Thanks guys
My project rig will run two 14B front and rear with ARB front and automatic locker on the rear. I will install RCV 300M shafts front and rear then I think the shafts will not broken. I will use the rig for european race like Romania, Italy, France etc. We have a lot of mud inside forest with lot of trees.
The reason because I don't like weld the differentials is turn fast and close then I need to unlock both axles.
I've run Detroit in some Dana 60 and it work good but I'm curious to try a Yukon..
