i decided to post some pics etc of my buggy build after tim from filthyboy convinced me it would be a good idea,
anyhoo i used to have a D90 that i used for winch challenges & offroading, king cabbed it, cage, 35" simex, ARbs etc etc all the "right" bits for uk competitons, However @ the end of the day it was still a "heavy" 90 & had soft bodywork when it was being rubbed against trees, rocks, the ground etc so over a brew @ work we decided to build a different take on the tube buggys we offer for customers,
So i went from this
to building a buggy like this
but with a few differances
Any how everyone likes a spec, so in no real order here goes
Engine
2.5 TD5 from a D2 with VNT turbo & Bell auto services remap & boost box
will be sticking with the standard DM flywheel till it breaks then going for a solid one
Transmission
Standard 5 speed manual from same D2 doner vehicle, nowt trick
Axles
24 spline axles front & rear fitted with ARB lockers, Rover tracks front shafts & cvs, GKN rear shafts, standard 3.54 ratio, may change gear ratio if required & peg them if they explode, located with D2 radius arms front n rear,
Suspension
fox 2.0 7/8 coilovers non reserviour in 12" travel, simple solution instead of going for air shocks, if needs be can squeeze 14"s in or go to ORi's
Chassis/ Frame
Whitbread offroad standard challenge frame built with a door on drivers side & hop over bar on pass side,takes a standard defender bonnet & remaining panelwork is flat ali sheet
mounted on a tubular chassis with inbuilt winch trays front, middle & rear,
Wheels & tyres
37/12.5/15 maxxis creepy crawlers on 10x15 modulars with weld on beadlocks (still to be done )
anyway, everyone likes pictures so here goes, ill say now if you have 56k gtf,
as it currently sits its all plumbed & 90% wired, have 4/5 panels left to fab & make a roof skin, its getting there at long last
anyhoo
sorry for wasteing your broadband & 10/15 mins of your time
So i went from this
Engine
Transmission
Axles
Suspension
Chassis/ Frame
Wheels & tyres
anyhoo
