Extended front brake lines chevy knuckles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2010, 11:14 AM   #1 (permalink)
Member # 37184
After recent mods to my front suspension, including new, longer travel shocks, my front brake lines are now acting as "limit" straps.
My knuckles are '76 Chevy K10, with high steer arms. They use a 7/16 banjo bolt to attach the flex brake lines. I'm currently using RE1552, 22in lines purportedly for a "CJ '77-'81". The 22's are too short. I need at least 26inches, with 28 preferred. RE has a 28 inch set, RE15555, but it's not clear if they will fit the '76 Chevy caliper. I asked RE but got no response.
I know some of you guys must be running high steer Chevy knuckles, using lines in the 26-28 inch range. The Ford and post '81 Jeeps seem to all use a 3/8 diameter banjo bolt; I need to use 7/16, and don't want to drill out the smaller fittings.
Any help would be appreciated
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote Quick reply to this message
Old 11-13-2010, 01:59 PM   #2 (permalink)
Member # 5110
Run one center flex line from the frame to the axle, hard lines, and then short factory length flex lines to the calipers.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 01:52 PM   #3 (permalink)
Member # 37184
I thought about doing that-- but would be easier to install two 28" lines that match up to my calipers (7/16 banjo), and current hard lines (3/16 inverted flare). Your suggestion would take more fabrication time, but would be "trick", when finished.
There's no easy way to run the hard line to a frame/cross-member location near the center of the axle; I'd have to run the line down one control arm, then across the axle. So I'd need 4 flex lines doing it that way.
Old 11-14-2010, 02:09 PM   #4 (permalink)
Member # 55444
Which would be the best way to go about it. Then you can run cheap 10" flex lines, and be into it for less money than some long ass stick grabbers, and they don't get torn off.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 07:14 PM   #5 (permalink)
Member # 129208
What about making 2 hardline extensions with the fittings and length needed?
Rubicon Express makes some but not sure if the fittings are what you need:
http://www.rubiconexpress.com/JeepPa...BL&part=RE1505
Or these guys will make you anything want:
http://www.crownperformance.com/
97 SAS'd Ranger
DB_1 is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 08:20 PM   #6 (permalink)
Stephen's Avatar
Member # 2092
check our page,i think we have just what you need. We can split kits if necessary.
Stephen Watson
Alpha Base in the quest for fullsize GM offroad world domination.
6 years of KOH/U4 racing
10 Ultimate Adventures
Official Canoeligan
Stephen is offline   Reply With Quote Quick reply to this message
