Project: Playin' with my Willys - Page 17 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-09-2016, 05:53 PM   #401 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Originally Posted by BIG_BLAZER86 View Post
Awesome man ,thanks
Glad to help
On a side note, atlas is ready to go back in. Swapping gears wasn't too bad at all. Can't wait to test out this low range, it'll likely be short lived as I'll probably go from 4.56 to 5.xx this fall in the diffs to get high range dialed in better.
ROXROES is offline   Reply With Quote Quick reply to this message
Old 08-22-2016, 05:12 AM   #402 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Couldn't be happier with how the rig is performing, won the 40+ RBOR class at Twisted Trails last month, and won the 42-44 class and 2nd in the 39-41 class yesterday at Bundy Hill Pit Trash Shootout. Unfortunately, it all comes with a price.
Running the grand finale I managed to break the raceline on the passenger rear, and slit the front passenger Trep front to back which is irrepairable. Gonna make a nice tire swing.
Was able to shove 7 plugs in so I could do the bonus hill timed climb on the staircase, one shotted it twice. Then the third time got a little off the line, came down and broke the front r&p. Time to regear!
Some video of the buggy around the 1:50 mark in this video:
Old 11-10-2016, 04:01 AM   #403 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Haven't posted an update in awhile. Got the buggy regeared to 5.43, and absolutely love it. Thing hits 70 like nothing, low range is back to where I like it with the 3:1 gear swap that happened a few months ago. Got the exhaust high temp powdered, gonna see how it holds up. Headers are the only part I'm concerned with. Split an RCV cage last time out, probably mostly my fault. Got parts in one day like the last time, gotta love RCV!!!
Old 11-12-2016, 07:28 PM   #404 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
Just curious why you say that. Over steering them or just get one really bound up or something? That's great they got ya covered.
MNorby is offline   Reply With Quote Quick reply to this message
Old 11-12-2016, 07:58 PM   #405 (permalink)
Member # 11985
Send a message via AIM to 1TFROT
pretty sure he had one bound up really bad
fawk this, let's go wheelin
M&M Offroad triple threat chassis #27
1TFROT is offline   Reply With Quote Quick reply to this message
Old 11-13-2016, 01:04 AM   #406 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Yep. All the weight on a brand new trep in a hole. It felt like it was gonna climb out then BAM. My bad.
Old 12-02-2016, 06:50 AM   #407 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Trashed another front r&p. Planning on adding a jantz load bolt to the front yukon 3rd and putting in a motive pro series 9310 alloy r&p. If this doesn't hold its going to get painfully expensive.
I'll put installation pics up once it happens. Doing a bunch of prep to take this thing to KOH all week.
Old 12-02-2016, 06:53 AM   #408 (permalink)
WINNAR!
Dookey's Avatar
Member # 23680
Thanks for all the updates. I enjoy reading your progress!!
TRAIL WORTHY FAB
| 316.337.5311
Old 12-02-2016, 08:39 AM   #409 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Thanks, the high temp powder didn't hold up on the exhaust either, so we're doing cerakote inside and out shortly.
Also building a replica th350 so I'll have a backup. Anybody know what the dowel back by the governor holds? It seems to have pushed out.
I also added a second atlas support, buddy cuts them for me and laser etch's the cut line. I have one on the output side, but felt my driveshaft getting hit is why I cracked a trans case a year ago.
Old 12-02-2016, 11:22 AM   #410 (permalink)
slravene's Avatar
Member # 53677
thats interesting - I never thought about having a 2nd one there. I may have missed it...but do you have the adapter between the trans and tcase supported as well?
2017 JK Buggy / LQ9 / Solid Mfg HP60 / 14bolt / 42" Maxxis / Method Wheels / ORI Struts
IG: @partiallycommittedracing
slravene is offline   Reply With Quote Quick reply to this message
Old 12-02-2016, 11:39 AM   #411 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Yep, its on bushing that are flush with the bottom of the chassis. But then there is 11 ga skid and 1/2" UHMW covering the entire belly. If it got hit hard enough there to buckle it, it would deform the skid.
Old 12-02-2016, 11:44 AM   #412 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Here is a picture of the trans dowel that seems to have worked its way out. Everything is working fine, I just noticed this the other night.
I've also attached a picture of the jantz 9" load bolt mod from the other thread. I just ordered two, one for rear and one for front. You pay to rent the jig from them, and return it afterwards and get the rental fee back.
Old 12-12-2016, 05:42 AM   #413 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Got the DIY Jantz load bolts last week. Kit looks very comprehensive and well put together.
I'll be getting these installed in both diffs this week. I bet you could barely egg the fill plug to get it in there, but you'd be slightly above centerline of the pinion. I'm planning on filling in the fill plug hole, hopefully I can grind the fill plug then get it in there then slide the bushing in to reduce the amount of filler I have to use.
Old 12-15-2016, 05:12 AM   #414 (permalink)
cool story
ROXROES's Avatar
Member # 97574
One down one to go, welded really nice actually, no bad noises on cool down either which made my evening.
Pre-heated to 250F, peened each 1/2"ish weld for 30 seconds or so immediately after welding per Jantz's instructions. Used Crown Alloy 220-T on the outside, and tig bronze on the inside. Never used the tig bronze before, pretty cool stuff. I ground the fill plug into a moon shape and took the threads off so I could press it in beside the load bolt sleeve so I didn't need as much filler. Prior to welding I could feel a slight rotation on the spool so I knew nothing was bound and everything was aligned properly with no binding.
My slow cool apparatus worked pretty friggin slick, took it around an hour to come down from 300F to 140F. And it did so pretty uniformly.
Old 12-15-2016, 05:37 AM   #415 (permalink)
knaffie's Avatar
Member # 48084
Well done.
knaffie is offline   Reply With Quote Quick reply to this message
Old 12-27-2016, 09:02 AM   #416 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Going to get this thing going back together and ready for KOH finally.
Jantz load bolts installed nicely, figured what the hell and had a buddy powdercoat the thirds.
New trans will be done soon, going to be nice to have an identical spare. Put new bolts in all the links and struts. New trans cooler line going in as well. PSC rebuilt and shipped the pump back lightning quick, they are always a pleasure to deal with.
LII mirrors are at powdercoat, put a set on a buddies buggy and really liked them.
Old 01-17-2017, 05:52 AM   #417 (permalink)
cool story
ROXROES's Avatar
Member # 97574
One last push, and this thing will be ready for KOH. Hope to have it buttoned up this weekend.
Putting up a comparison pic of the pro series 9310 motive gear (left) to an 8620 standard motive gear (right).
Really looking forward to the mirrors, I've driven my buddies buggy around some that I put them on and they work really nice.
Old 04-28-2017, 07:00 AM   #418 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Haven't posted in awhile. Rig worked great at KOH, toasted a 5 year old chromoly RCV bell at the top of SOS on the last day. So I upgraded that to 300m along with the inner that it stripped.
Had to replace a tube in the cage from taking a dumb line on Backdoor.
Ran the first RBOR race this past weekend and the rig is working great, took 3rd in Unlimited. Missed 2nd by 1 second, and 1st by 4-5 seconds. Have some good competition this year so I'm going to need to do some fine tuning before the next race.
Had the motor retuned as the first tune was super safe as it wasn't really broken in.
It threw down 280 last year with 4.56s and the 40" Treps.
This year is baselined at 296 with the 5.43s and 40" Treps, and finished off at 319 to the wheels. If everything holds together good this year I'll be doing a little intake/TB work and building some custom 1-7/8 headers.
Old 04-28-2017, 08:02 AM   #419 (permalink)
Uncle Buck
danielbuck's Avatar
Member # 229476
nice fix on the cage there, how did it bend on the inside?
Redneck Driveway Fab
If it ain't a flat-fender, it ain't much.
danielbuck is offline   Reply With Quote Quick reply to this message
Old 04-28-2017, 08:21 AM   #420 (permalink)
cool story
ROXROES's Avatar
Member # 97574
From pushing it up at 1am, it was driving me nuts looking at it.
It was pushed down probably around 2".
Old 04-28-2017, 08:24 AM   #421 (permalink)
Wilson's Avatar
Member # 7233
Any outside video to better view the shocks working ?
Old 04-28-2017, 08:53 AM   #422 (permalink)
cool story
ROXROES's Avatar
Member # 97574
I'm at the 45 second mark.
Old 04-28-2017, 10:27 AM   #423 (permalink)
Ehhhhhh...
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Isn't that the waterfall on Wrecking ball?
desertCJ is offline   Reply With Quote Quick reply to this message
Old 04-28-2017, 12:00 PM   #424 (permalink)
Member # 562866
Looks slow
#durangoclan
Alex456123 is offline   Reply With Quote Quick reply to this message
Old 04-29-2017, 05:46 AM   #425 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Yep, we ran that the first day and I was almost ready to pop out the top with a good launch. But everyone was telling me not too as it was our first day and I have a tendency to break things.
Originally Posted by Alex456123 View Post
Looks slow
Maybe it'll be faster with my Trump tires???
