#204 (permalink) | |
So is that a custom Tera 60 then since its Alum? A little too far to save weight.
Mike |
#206 (permalink) |
Member # 957
i notice the picture shows the crack goign right through the bolt hole drilled into the support structure for the skidplate. i didnt see that pig explode, but by lookign at the pictiure, it makes my wonder if the housing didnt flex, and split at that bolt hole, causing catastrophic failure, and a humorous picture.
#208 (permalink) | |
Member # 6588
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#209 (permalink) | |
Member # 5776
has about $1300 in it total. It's going under an 880Hp BBC powered tough truck. Them axles are HUMUNGOUS! People really don't get it until they see them in person. It's like someone made an axleshaft out of something about the size of a jeep rollbar. ![]() I suppose that: 1. The ultra-low pinion 2. ARB, not spool = no 40 spline 3. It's a front axle. Easier to startwith an axle that's common as a front axle. Pretty much sums up why not a 9-inch, eh?
[size=1]ASE Certified Master Automotive Technician Toyota Certified Expert Technician Volvo Certified Expert Technician Suzuki Certified Master Technician IDPA Certified Master Cardboard Killer[/size] |
#211 (permalink) |
Member # 15043
your axle is very impressive- a good example of what can be accomplished with good engineering,good maching,and a little bit of money i think you are correct in assuming the new " weak link"will probably be your pinion stem. there might be another problem area with your axle- your inner 2 piece assembly. splined asseblies like that should be run in a oil bath if possible- running them dry will make the flanks of the splines wear much faster you might be able to eliminate that with a press fit between the inner and outer splines. also the reinforcing web between the "ears" on the yoke has the middle cut out of it to allow internal spline to be broached- this web is there to help keep the "ears" from flexing under severe loading.there are "markings" on the sides of your inner yokes for your 2 piece inner assemblies-are these reworked spicers cut off a o.e.m. axle or are they more 300m machined from bar stock? nice piece of work- next step is to test it on the trails. hopefully sandy is done making parts for you[IMG][img]camo.jpg[/img][/IMG]
rust is a four letter word!!!!! Last edited by stainless steal dave; 12-20-2002 at 09:10 PM. |
#212 (permalink) |
No comment
the inners will be a very tight press fit. more like heat up the yoke and hammer it on.
the inners are made from 300m bar stock and are alot more massive and beefy than a oem piece. jason paule has already run a set of yokes in a comp. they survived just fine. actually they withstood a obstacle that broke other stock axles. no problem. |
#213 (permalink) |
Member # 15043
one more thing you might consider doing before you install your new axles- you already know about painting lines down them to allow you to check them for torsional overloading but it is also a good idea to mount them between centers in a lathe and record run-out with dial indicator at each end and on journal for inner axle oil seal. record these dimensions and save.next time you have it apart for repairs or maintenance check them and compare to original specs you might be surprised at what you find!
rust is a four letter word!!!!! |
#215 (permalink) |
Member # 15043
i was not trying to be a smart-ass i dont need the flip-off sign in your reply back to me if you have been doing all that tech work on your own pics of your shop at your home please . camo 60 nice work camo60 built by camo himself very impressive- and yes i have a machine shop and yes i build dana stuff- there are people on the board that know me and have seen some of the things i have built in my shop.
#216 (permalink) |
DuCaTi MoNsTeR
Member # 2931
dont worry dave, thats the friendly flipoff
ive seen your shop, makes the machinists shop on the aircraft carrier i served aboard look, inadequate, and we could machine 22" haines stellite valve seats at sea for reactor coolant piping ![]()
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com |
#218 (permalink) |
Member # 15043
j.r.-love your bronco liked the pic of your daughter next to it is she single?
booger weldz-now that you have a welder i can carry more beer and less rod looking forward to going out with the gang this summer - saving my money for new toyota project.
#219 (permalink) |
Tin Bender
Member # 294
Okay, I have a question for all the guys that keep asking why he didn't choose a 9 inch... Does anybody in RCAA run a 9? I'm sure there are a few, but not many. 60s far outnumber 9s in any series. The 60 has proven itself over the years to be the most beef for the buck. By starting with a proven-tough component, and pushing the engineering envelope, Camo has build something that SHOULD last a lifetime. But then again, he can break anything!
Mike inthePINKracing would like to thank it's sponsors! Marlin Crawler Griffin Yukon Gear BFGoodrich Artec Industries FOA Hendrix Motorsports Poly Performance RuffStuff Last edited by Jeepskickass; 12-21-2002 at 07:00 AM. |
#221 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
when you start the toy project let me and jon(408) know, well come over and help you turn wrenches! and bring cold beverages of course were both going coiled/links in the rear this winter...
#223 (permalink) | |
in the 9's, Lots of $$$ to make them even 35 slpine.
88 4.0, np435, atlas, d44's arb, on 37 Last edited by dgcooper; 12-21-2002 at 01:51 PM. |
#224 (permalink) | |
Member # 15043
TOBY- I REALIZE THAT IS HIS WIFE JUST KIDDING AROUND WITH HIM- I HEAR J.R. IS A GREAT GUY NEVER MET HIM IN PERSON NO DISRESPECT INTENDED I FOLLOWED THE THREAD HE HAD POSTED ABOUT HIS BRONCO AND HOW HE MAKES HIS LIVING PLAYING THE FRENCH HORN. LOOKS LIKE I CHOSE THE WRONG LINE OF WORK!!! TOBY- HAVE NOT TALKED TO YOU SINCE BARRET LAKE TRAIL RUN- I LOANED YOU ELEC. DRILL AND EASY OUT,DRILL BITS HOW HAVE YOU BEEN?
