Rockwell FDS75 axle tech - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2011, 08:43 PM   #1 (permalink)
tlspeed1's Avatar
Member # 38739
Well my brother works in a heavy truck shop and they had a Chevrolet C70 4x4 come in. The owner wanted the box on the back swapped to another truck and the owner doesn't want the truck back.
Anyways as I said, its 4x4, which got me think what axle is in it. So I had my brother send me pics. My brother said he couldnt find the tag, but didnt look to hard, as I see it covered in dirt/oil in the first pic. He told me it has a rockwell t-case, 1410 yokes, and the diff is out of the front axle.
I am a good distance away, and would love just to go tear it apart to investigate but cant, so from the pics I found that looks to be a Rockwell FDS75. It has what looks like a the rockwell 2.5ton wheel bolt pattern, drum brakes. From my searching I think they have 1.75" diameter shafts but could be wrong. Also searching I found similar axles with disc brakes and a 10 lug pattern.
Anyone have any more info or spec sheet? Confirm shafts size/spline, bearing sizes, u-joint, anything. How do they compare in strength to a 2.5ton toploader?
I can prolly get this axle for little to nothing.....and I am thinking hybrid rear steer axle? Thoughts?
Thanks in advance.
tlspeed1 is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 08:45 PM   #2 (permalink)
Twisty's Avatar
Member # 97798
You say the diff is out of the front axle. Does this mean that the 3rd chunk is missing? Also, are those knuckles open unlike the top loader Rockwells with the rubber booots?
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 42" Iroks, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 08:54 PM   #3 (permalink)
tlspeed1's Avatar
Member # 38739
Thats my problem I cant go investigate this till the weekend!!!
The knuckles appear open but I am not sure.
Here is another pic he sent me. As you can see the 3rd chunk is there, but he just said the diff was out. I am thinking bearings or gears are shot.
Old 02-02-2011, 04:37 PM   #4 (permalink)
tlspeed1's Avatar
Member # 38739
ttt for the night crowd
Old 02-02-2011, 05:56 PM   #5 (permalink)
the glassman's Avatar
Member # 33365
Send a message via MSN to the glassman
marmon hardin
walk a mile in someone elses shoes. then you'll be a mile away and have their shoes.
the glassman is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 06:14 PM   #6 (permalink)
tlspeed1's Avatar
Member # 38739
Originally Posted by the glassman View Post
marmon hardin
Is that drunk for....marmon herrington
From what I see, marmon herrington axles have round tubes
Old 02-02-2011, 08:09 PM   #7 (permalink)
abrogate's Avatar
Member # 31552
I have seen something just like that on a hydroseed truck at work. It was a monster 6x6 truck, just can't think of the MFG. It was three letters, not a word... who knows. it sure looked like a Ford to me. I crawled under it and it was some Rockwell that I had never seen.
edit: it was a FWD truck. not front wheel drive....
DMTFAB.COM
abrogate is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 08:23 PM   #8 (permalink)
abrogate's Avatar
Member # 31552
And it looks like the tag is to the right of the diff on the front of the drivers axle tube.
DMTFAB.COM
Old 02-02-2011, 08:27 PM   #9 (permalink)
tlspeed1's Avatar
Member # 38739
Yeah I asked my brother to find some time and clean the tag off and get some numbers for me.
Old 02-06-2011, 08:20 PM   #10 (permalink)
FJ_Dave's Avatar
Member # 48807
that is most likely a rockwell axle, it has an F106 third member with a square tube housing and rockwell outers. It's 19 spline at the diff, and rated at 3 ton.
Very popular center section with the monster trucks.
Jeeps are cool... BARBIE HAS ONE!
FJ_Dave is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 09:59 PM   #11 (permalink)
tlspeed1's Avatar
Member # 38739
Well found out a little more this past weekend.
Turns out it is Rockwell FDS 75. 680 ratio. Gonna call around and find a parts lists and or manual
Didnt measure the shaft cuz I forgot, but outer looks like 1.75. I didnt count spline as you can see this one is stipped completely. On the other side the snap ring was weld on to the shaft...Nice.
Ears are broken off the longside inner (this is the side with stripped spline on outer. Drive flange is stripped to)
Joint of good side, with snap ring welded on to the outer.
Old 02-07-2011, 12:21 AM   #12 (permalink)
Cotton Farmer
Member # 167491
Send a message via ICQ to jd8420
Performancepros.com sells some bad assed parts for these axles. edit : Sorry it's proformancepros.com
jd8420 is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 01:01 AM   #13 (permalink)
Member # 136471
That cracked rim is sketch!
boardbysled is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 05:39 AM   #14 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
I'm guessin' that it's just the outer layer of paint that's cracked.
$50 Off CrawlTunes Packages:
TAWL_BOY is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 06:29 AM   #15 (permalink)
Member # 115569
for fukksake Lash, just buy the sonovabitch!
bunghole.
"White Whistler"
Turbocharged LQ4
wicked_sten is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 07:00 AM   #16 (permalink)
tlspeed1's Avatar
Member # 38739
Says performancepros.com domain is for sale.....no parts >Edit....see Wicked sten's post...site is proformancepros.com
No the rim is fubar'd bad, cracked and the lug holes are oblonged
bunghole.
Relax bud and go back to your damn homemade (or should I say custom..lol) cummins/zf6 swap. The axle is mine already, just need info and parts as you can see.
Old 02-07-2011, 08:09 AM   #17 (permalink)
Member # 115569
mmkay.
EDIT: i bring forth tech http://www.proformancepros.com/cgi-b...&category=AXEL
"White Whistler"
Turbocharged LQ4
Old 02-07-2011, 09:42 AM   #18 (permalink)
tlspeed1's Avatar
Member # 38739
After researching, Arvin Meritor bought out and carries parts for this axle.
Manual here> http://www.meritorhvs.com/MeritorHVS...nts/pb9151.pdf
