front dana 60 outer axle seals - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2011, 08:05 PM   #1 (permalink)
Member # 20522
I've tried calling Mad 4x4 for the last week with no luck. I bought thesefor my 95 axle. But I don't see how they work. The axle shaft is a considerably smaller diameter than the inner hole of the seal. So it doesn't seal shit. I was going to go with the other rubber seals but these seemed to do the same thing, were an OEM part and were much cheaper. So what am I missing here?
93 Bronco 5.8 Broncoair D60 SAS & Bumpers 40 MTR's 10.25" 5.38's ARB's M12K Owner: Broncoair.com
BoulderBronco is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 09:05 PM   #2 (permalink)
Member # 110063
Seals
The seal you have sandwiches between the stub shaft and the back of the spindle to keep dirt and dust out of the pocket bearing in the back of the spindle.
There should also be another small rubber seal and a poly thrust washer that fit the od of the stub shaft itself. The combination of these does a decent job of keeping crap out of the needle bearing.
broncoguy is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 09:39 PM   #3 (permalink)
Member # 20522
No, it's not that seal. In the diagram on Mads site it shows it as part 42 which appears to go in the end of the axle tube.
Old 03-04-2011, 05:18 AM   #4 (permalink)
Member # 46175
Some inner shafts have a step right next to the yoke that the seal would go on. Most older shafts do not have this step.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 06:07 AM   #5 (permalink)
Member # 43587
Send a message via AIM to TBItoy
I assume you have a 95 Ford Dana 60?
They do not have this seal.
Probably should have looked at your axle to see if it had the seals factory before you bought new ones.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 10:04 AM   #6 (permalink)
Member # 20522
Ok. So why does Mad say these seals are for 88-98 axles and have an OEM diagram showing it?
Also I would have looked at the axle but I bought it all torn down, just the housing.
Old 03-07-2011, 01:38 PM   #7 (permalink)
Member # 43587
Because MAD is wrong.
I've only seen those dust seals on super duty axles.
I have a 95 F350 and it doesn't have those seals.
I looked at the diagram MAD has, and it's obviously for a super duty axle. It clearly shows unit bearing hubs, which the 88-98 dana 60s dont have.
Old 03-07-2011, 08:28 PM   #8 (permalink)
Member # 24859
Look closer at the diagram, #42 goes on the stub shaft up against the back of yoke, then when yoke is put into hub is seals against dirt. There was a thread awhile back where a few vendors posted having the Mad out board seals in stock.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
