#103 (permalink) |
Member # 133593
Cool man, thanks.
So is it just a bolt or is there some kind of roller on it? If it's just a bolt how tight up against the ring gear is it? Just barely touching, a few thousandth spacing? I'll put my newbie name tag back on now.
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
#104 (permalink) | |
Member # 94019
Typically a bolt with a special pad on the end that is touching the back face of the ring gear. The idea is to prevent the few thousands of movement, so you wouldn't want a gap. |
#105 (permalink) |
Member # 46175
I have always tightened them up until I get resistance, and then back it off just a hair.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
#107 (permalink) | ||
Super Willie
Member # 19067
On a load bolt you definitely want to back it off a few thou. Metal sliding on metal contact is not good.
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
#110 (permalink) |
Member # 137265
Here is a few update pictures.
1st fully machined RJ70, load bolt, skid plate, fill and drain plug. Prototype 5.38, 35 spline pinion gears are in and setup really nice!! A little tuneup on the core boxes and will be running some pre-pruduction units for testing!!! ![]() ![]()
#114 (permalink) |
master lurker
Member # 104639
when can i order the gear set.....
--------------------------------------------------- GOT 99-04 UNIT BEARING HI-STEER?? check out the super ranger 86' RANGER-39.5'S-4.0L-M50D-9"-DETROIT-5.14'S 90' RANGER-42'S-BLOWN 302-E4OD-60/10.5-5.38'S-12 BOLT H1'S
#116 (permalink) |
Savvy Off Road
Member # 110540
I need a couple for my new buggy!
THE ULTIMATE LIGHTWEIGHT JEEP PROTECTION AS PROVEN AT THE KING OF THE HAMMERS. TWICE! BACK TO BACK OVERALL EMC WINNER. Click here for: SAVVY OFF ROAD |
#118 (permalink) | |
Member # 73963
But in comparing these 2 pinions, I suspect the top one is the new super RJ70 and the bottom is a d60. it seems from the pic that the rj70 part has beefier gears but has a smaller shaft at the end/less splines. SO less strong???
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#120 (permalink) | |
Member # 73963
I assumed the pinion with the white pattern ink on it (smaller od one on top) went with the white pattern ink ring gear on the new carrier
#122 (permalink) |
Member # 6576
I want
Brian Whitford 711 Dysfunctional Rockcrawlers Rage 4th............ "safety is our #2 concern" |
#124 (permalink) | |
Member # 4375
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club. |
#125 (permalink) |
Member # 45977
I will word my question better.
![]() What is the measurement from axletube centerline to the bottom of the differential housing on the RJ60 and the RJ70. I can try to work the rest out in my feeble little mind. |
