AGR Steering TTB Buggy Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-03-2011, 06:23 PM   #1 (permalink)
Shaffers Offroad's Avatar
Member # 11801
We're building a NEW KOH car for the guys at AGR Steering!!! It's being built to race KOH 2012 as well as some of the other popular races.
The Specs are as follows:
We pulled to motor out of the old yellow AGR TJ ,which is a healthy Ford 302 TCI C4 transmission with a passenger side drop Atlas
Ruff Stuff full float rear housing with their new full float hubs
Ruff Stuff 9" center front housing
Factory Ford TTB-50 outter kuckles and C's
King Shocks
Rear trailing arms built and heat treated by Taylor of Heretic Fab
JAZ 32 gallon fuel cell
Afco Radiator and fan set up
Rodend supply heims and uniballs
Derale transmission coolers
and most important of all................
AGR Ram assist steering
We'll be looking for approimately 18" of front travel and 24" of rear travel. It'll be a typical 4 link rear with trailing arms. TTB front is really simple. The beams are built from 3/16 chromolly and built around the Ruff Stuff housing. We chose to use the factory stamped steel inner C's and the factory knuckles to take advantage of the 15 degree KPI that the factory TTB uses. Also, we did make the passenger side beam longer (diff side) because we felt we would be better off with one side longer than we if we had 2 short sides. We are using uniballs at the pivots and 1 1/4 heims on the radius arms.
Shaffer's Offroad & Performance
Shaffers Offroad is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 07:43 PM   #2 (permalink)
Member # 133812
Lookin sexy...
Trent Blew,
TEAM TNT motorsports -
Pitbull Tires
Poly Performance
Bilstein Shock Absorbers
PSC Steering
Rugged Race Radios
Gear Center Group
2009 JK DD (hell ya' its got a HEMI)
Gracefull is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 07:48 PM   #3 (permalink)
Member # 71529
very nice
dustin_mud is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 07:55 PM   #4 (permalink)
Member # 83657
This should be sweet! I wish I had the cash to build a decent ttb rig.
brent460 is online now   Reply With Quote Quick reply to this message
Old 05-03-2011, 08:42 PM   #5 (permalink)
Member # 111714
Awesome to see another ttb buggy being built, I'll be watching this one. What is the planned track width for the front?
Tyler C is offline   Reply With Quote Quick reply to this message
Old 05-04-2011, 06:47 AM   #6 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
This one was actually in the works to be at roller status by KOH this year but some things pushed it back. It has been in the works for a long time, so it's not another knock off
Be kick ass to see Matt get his ride on the dirt.
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Your ORI strut dealer along with about anyting else you need!
team Nasty co dog
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 05-04-2011, 08:58 AM   #7 (permalink)
Member # 32726
was wondering when another TTB build was gonna pop up. Looks killer!
Toyota buggy - duals + 4.7, 40's, linked rear/fox airs, shift knob
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote Quick reply to this message
Old 05-04-2011, 09:39 PM   #8 (permalink)
Member # 111714
I never said it was a knock off I just like seeing ttb being used in these applications, to me it seems like a great middle ground between solid axle, and a-arm ifs. Mainly because it can be built cheaper than an a-arm setup, and you can pull a ttb setup out of a junkyard. Although this ttb system obviously did not come from a junkyard
Old 05-05-2011, 03:24 AM   #9 (permalink)
Member # 83301
just a question but wat will keep the drivers side axle in the pumkin? A D50 TTB has a c-clip?
'79 chevy k30 vortec 350/sm465/205/205/5.13's with big tars and toob
Old 05-05-2011, 06:19 AM   #10 (permalink)
Member # 80664
Very cool Shaffer's! I like the rolled lines of the chassis. Looks fast already.
Looking forward to seeing what you do with the TTB customization.
"Even if you get to the line first are you really "winning" if you do it in a Toyota?"-raceanything
fuggy is offline   Reply With Quote Quick reply to this message
Old 05-05-2011, 09:55 AM   #11 (permalink)
Member # 693689
You don't need the c-clip. I ran the D44 TTB in my old Bronco without the c-clip on the inner shaft for years due to having to remove it to install the lockright. I never had a problem with it.
DannyK is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 08:55 AM   #12 (permalink)
Member # 32726
any updates on this?
ΜΟΛΩΝ ΛΑΒΕ
Old 06-17-2011, 06:39 PM   #13 (permalink)
513
Member # 121037
Any current progress on this?
Matt - Dreaming of AZ wheeling.
513 is offline   Reply With Quote Quick reply to this message
Old 06-17-2011, 10:34 PM   #14 (permalink)
Member # 41097
Any plans for reinforcement on the factory knuckles/c's? I doubt they'll handle extended abuse times without reinforcement.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
It'll only be bigger, better, & tougher next year
mustange70 is offline   Reply With Quote Quick reply to this message
Old 06-18-2011, 04:45 AM   #15 (permalink)
Member # 46175
Put a spring in the female splined shaft.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 06-21-2011, 01:51 PM   #16 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
More pics!
Mark
welndmn is online now   Reply With Quote Quick reply to this message
Old 06-21-2011, 08:07 PM   #17 (permalink)
Member # 29159
Send a message via AIM to JabNasty Send a message via Yahoo to JabNasty
Wheres the updates?
JabNasty is offline   Reply With Quote Quick reply to this message
Old 06-22-2011, 08:42 PM   #18 (permalink)
Member # 29159
So where are the updates that should have been posted last night?
Old 06-23-2011, 08:59 PM   #19 (permalink)
Member # 29159
Hmm still no updates I don't think u want the Texas crew to make a road trip.
Old 06-23-2011, 09:01 PM   #20 (permalink)
Wilson's Avatar
Member # 7233
Maybe it'll end up at Trout's with a pile 'o cash in the passenger seat
Old 06-23-2011, 09:03 PM   #21 (permalink)
Member # 29159
No it will end up in texas one way or another.
Old 06-23-2011, 09:08 PM   #22 (permalink)
Wilson's Avatar
Member # 7233
I'm pickin' up what you're puttin' down now
Old 06-24-2011, 06:41 AM   #23 (permalink)
I am very salty
FISHMOUTH FABWORKS's Avatar
Member # 43776
Send a message via Yahoo to FISHMOUTH FABWORKS
nope, i have no part in this build. I know Mike is busy with it though
Dan Trout- Dave Halabuk RIP
Rage4th #76
FISHMOUTH FABWORKS LLC
PHONE-(916)-996-1532
WEBSITE
E-MAIL
Check us out on Facebook and Instagram!
FISHMOUTH FABWORKS is offline   Reply With Quote Quick reply to this message
Old 06-28-2011, 10:43 AM   #24 (permalink)
Member # 11801
Sorry it been awhile, Ive had some small jobs that we had to hammer out!
We cut out the the rest of the link mounts and truss caps for the Ruffstuff rear end. The diff side TTB is finished and we are now building the mounts for it. The short side TTD should be finish welded today.
Here are a few pics
Old 06-28-2011, 10:54 AM   #25 (permalink)
Member # 11801
A rear set 20 axle bearing will be pressed on to the axle and the we used a set 20 tube end on the Ruffstuff housing
