Engo Winch? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-19-2011, 09:14 AM   #1 (permalink)
Member # 107265
Engo Winch?
Saw the new issue of fourwheeler, they seem to test out pretty good and looks to be owned by old milemarker ceo. Pretty darn easy on the pocket book, $349 for a 10K. Anybody running one yet?
treemover is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 09:32 AM   #2 (permalink)
Member # 226
New import winch flavor of the month. Yee-HAW!!
Ben W is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 10:21 AM   #3 (permalink)
mwilken03's Avatar
Member # 151416
they called the place i work and wanted us to be a dealer for them. havent sold any yet but if we do ill let you know how they work.
mwilken03 is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 03:07 PM   #4 (permalink)
CLRracer's Avatar
Member # 28134
Send a message via AIM to CLRracer
I think the biggest issue with these new brands of winches isnt going to be how well they work, but how well they work after a few years and a few hard pulls.
Duane
A true friend WILL NOT come bail you out of jail. They will be sitting beside you in it.
There's never enough time or money to do it right, but always enough to do it again!
CLRracer is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 03:02 PM   #5 (permalink)
Member # 33536
buy $300 winch every few years or buy $1000 winch once....
.02
85blue4runner is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 03:06 PM   #6 (permalink)
Member # 80653
.02
this ^
it will end up costing you the same money in the long run (if you really use it off road and not just a show piece on the front of your mall crawler), but a lot less cuss words.
BenE is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 04:13 PM   #7 (permalink)
Will work for beer
Dr.Danger's Avatar
Member # 168243
This. Milemarker was imported crap, I'm sure these will turn out no different.
-Dave
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 07:33 PM   #8 (permalink)
Member # 138168
i read the same article, and thought the same about the engo.
I understand warn has a great reputation and all, and i am not bashing them, but why did they take first place when it did worse than a couple others in the testing?? :flameon:
4x4orbust is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 10:30 AM   #9 (permalink)
Member # 80653
Not sure of the results of the tests, or what the tests consisted of even, but if Warn was beaten by another brand, I would like to see both winches bolted to the front of a couple rigs for 10 years and do the tests again.
Old 05-22-2011, 09:52 AM   #10 (permalink)
Member # 87542
I read the article and had the same thoughts. I ordered the 10K pound and it came to $369 shipped. It will be here this week and even if it works fairly well I'll be happy with it. My pockets aren't deep enough to afford a $1K- 1.5K winch.
http://www.cardomain.com/id/D44Runner
D44Runner is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 11:03 AM   #11 (permalink)
mwilken03's Avatar
Member # 151416
Because they gave ratings on everything all the way down to packaging. How they tested was just part of the overall score.
Old 05-23-2011, 12:33 PM   #12 (permalink)
Member # 92825
You would think that the fact that the warn broke would have factored into the score a little more.
juicywhip is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 02:42 PM   #13 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
The test was, lets just say, a little off. Factor more on packaging and instruction manuals than how well the winch actually performed, by actually pulling something.
BIGELOW MOTORSPORTS EST. 2003
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 04:43 PM   #14 (permalink)
onetoncv's Avatar
Member # 2160
I'd sure hate to find out its not up the job about 1/2 way there- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 05:44 PM   #15 (permalink)
Member # 429
Hmmm,
I have been on two recent trips with Warn winches, one was new and one that recently had the solenoids replaced (because they gave up previously), both failed when needed. So the name Warn doesn't mean as much anymore.
I have had two Warns, one Summit brand and a Milemarker in the past. None of mine have ever failed when I needed them.
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 11:37 PM   #16 (permalink)
Member # 191233
How many people here are giving opinions based on the facts and not just because they are Warn fans.
(buy $300 winch every few years or buy $1000 winch once....) In testing, the winches went through water submerged testing and stall out testing which proved to be the two toughest the Engo made it the Warn did not, that means you are still on one Engo 300$ winch and you will need a second Warn 1000$ winch right out the gate.
(Not sure of the results of the tests, or what the tests consisted of even, but if Warn was beaten by another brand, I would like to see both winches bolted to the front of a couple rigs for 10 years and do the tests again.) No need for the ten year test the Warn had broke after one test and the Engo didnt.
(The test was, lets just say, a little off. Factor more on packaging and instruction manuals than how well the winch actually performed, by actually pulling something.) A little of in the fact that the only reason the warn did take first was because of the better instructions and superior warning labels in which it was the only to score perfect, for those who havent read the article. Last time I checked winches werent to terribly hard to run.
If the results had been based on performance only the warn would not have taken first, the superwinch did not break in a way that made it useless like the warn, was faster than the warn and more energy conserving was only 1000 pounds less pulling power than the warn.The Tmax did not break during testing but was decided heavily against for poor packaging, and was also scored lower for making noise while submerged granted it still worked properly. The Engo lasted through all tests with no problems its the cheapest and although it could not pull the 16000 pound limit the warn could, it still hit 12000 and actually kept working.
The facts are there, I hear crap from my friends (who are die hard warn fans) all the time about my cheap, ugly, Engo winch because its not proven and yet I havent replaced or repaired mine yet while I have to lend a helping hand to them often.
Personally I think its smarter to buy the cheaper Engo winch that does work well with a little less pulling power and take the 1000$ savings and make your truck more off road capable and have to use your winch less thus prolonging the life of it instead of buying the 1400$ warn.
Kruppiak is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 07:16 AM   #17 (permalink)
mwilken03's Avatar
Member # 151416
Engo also matches Warns warranty with limited lifetime on mech parts and 1 yr on electrical. Thats pretty good for a cheap winch.
Old 08-14-2011, 01:47 PM   #18 (permalink)
Member # 5516
The 9,500 lb. capacity Warn winch didn't break until after its test load had gotten well past 16,000 lbs.
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Old 08-14-2011, 06:02 PM   #19 (permalink)
Member # 92825
If I was stuck on a trail, I would rather have my 9500 lb. winch only pull 9500 pounds than pull 16,000 and break.
Old 11-03-2011, 07:53 AM   #20 (permalink)
Member # 200781
Because the clutch didn't dissengage like it should and tore itself up.
I just got my 12k Engo for $349 shipped to my house, that is hard to beat.
goaterguy is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 08:50 AM   #21 (permalink)
Member # 74576
Warranties are only good as long as the company is around to honor it.
tmorgan4 is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 09:05 AM   #22 (permalink)
busyfixin's Avatar
Member # 95131
This is the biggy. I have faith that Warn will be here next week.
thats not how the internet works. i'm an expert on here, not in real life.
When in doubt, throttle out!
busyfixin is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 09:16 AM   #23 (permalink)
Member # 112629
they should throw a 8274 in the mix it would be a shining star
i have A.D.D. it is problem. um wanna go wheelin.
scott037 is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 10:22 AM   #24 (permalink)
Member # 9474
Things people foreget....^^^^^
Former samurai owner........
I AM IN NOW WAY RESPONSIBLE FOR MY SPELLING!!!!!
FLEXYSAMMY is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 10:44 AM   #25 (permalink)
i_eat_glue's Avatar
Member # 112826
warn must have a big set of nuts, because there are alot of people that swing on them.
supporting single mothers, one dollar bill at a time!!!
i_eat_glue is offline   Reply With Quote Quick reply to this message
