#26 (permalink) | |
Member # 41185
#27 (permalink) | ||
Member # 4375
![]() Quote:
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club. |
#28 (permalink) |
Member # 4375
Were you going to tell him that dropping hot welded parts into a bucket of water likely ain't the smartest thing to do with steering parts?
#29 (permalink) |
Member # 4375
Great idea, all you gotta do now is teach me how to do that by hand. I've got some 1 1/4-12 into some lower links we can start with.
#30 (permalink) | |
Member # 41185
#31 (permalink) | |
Seems to be fine. I'll run it and when it fails you guys can tell me you told me so.
88 4 Runner, dual cases w/ 4.7's, Tacoma E-locker rear, 37" PB Rockers and no lift, caged Last edited by jtaco1; 03-22-2012 at 09:39 AM. |
#32 (permalink) |
Dent'n Soup Cans
I never thought of using an old TRE as a tap. I';m going to use that idea if that ever happens to me. Thanks Dan
I don't have much input but your TIGs are DAM NICE! I would say just cut the insert out but that weld is to nice to simply get rid of it. I always use anti seize with the tre threaded into the insert and weld in two 4 passes. (inner weld both sides, finish weld two sides) I always turn the TRE to make sure the insert doesn't get warped. But I'm using a MIG.
N-06177...N-06178... and 63 more to go. KEEP OUR PUBLIC LANDS OPEN TO THE PUBLIC |
#33 (permalink) | |
'SuperDan'
Hell esp on a site like this. Tons of access to a lathe. You can even do it with just a bridgeport with a bit of thinking.
Dan Smith 'physically strong, mentally awake, and morally straight' Fear is not an option! |
#34 (permalink) | ||
Member # 121563
![]() Quote:
Until then continue to be bothered by the fact I don't use taps for this
#35 (permalink) | |
Member # 41185
From Wikipedia (because I was in a hurry) "Extremely rapid cooling can prevent the formation of all crystal structure, resulting in amorphous metal or 'metallic glass'." Further research found the following: "Benefits of heat treating" I'll quote from that article: Martensite Formation & Tempering When austenite is rapidly cooled (i.e. quenched) to room temperature, an unexpected phase transformation can occur. Instead of forming ferrite and pearlite or cementite and pearlite, austenite can transform to martensite, a highly stressed body-centered-tetragonal (BCT) phase. This reaction is not diffusion-controlled but rather takes place by a shear-type transformation and is only a function of temperature and not time. The result is a very hard but brittle microstructure. The hardness of the martensite depends on the carbon content of the austenite. The martensite and the austenite it came from have the same chemical composition. Basically, when you cool a recently welded part that rapidly, you drastically increase the chances of creating a brittle weld. Brittle welds in a steering component are especially bad. |
#36 (permalink) |
the freeak - I appreciate that you provided the above information instead of just telling me I'm a dumbass, eventhough I may be
![]() So lets say that I did cause a brittle weld. Anyway to verify in a home based shop, other than say x-ray? Or just wait for it to boom at the shittiest time on the trail ![]() The welds look just like the other welds I have made before?
88 4 Runner, dual cases w/ 4.7's, Tacoma E-locker rear, 37" PB Rockers and no lift, caged |
#37 (permalink) | |
Member # 4375
I no longer tell folks how to bend pitman arms because it never occurred to me that someone would do that.
#38 (permalink) | |
Member # 4375
Don't get me wrong, I do have some stuff threaded and split, but only when tube OD is an issue.
#39 (permalink) | |
Member # 4375
#40 (permalink) | |
Who took my cake?
Member # 120626
"Opportunity is missed by most people because it is dressed in overalls and looks like work." |
#42 (permalink) | |
'SuperDan'
![]() Yes I get the point, and I KNOW you do. But end of the day its kinda like those tie down points that say 'do not weld' its not because they can not be welded on, but because "you" shouldnt...
#43 (permalink) | |
Member # 41185
![]() I would GUESS that if they haven't broken YET, that you MIGHT be ok. If it's trail only, I'd run it, but if you drive it on the street, swap it out. |
#45 (permalink) | |
Wheel Nekkid!
Member # 112595
1"x8"x16" plate, 8" 3 jaw chuck.... Swing the head over, indicate once and do as many links as you want.....
www.twistedjeeps.net |
#46 (permalink) | |
and Scooby
Could you maybe show a pic for us inexperienced folks? What is the plate for?
She’s got a silk dress, and healthy breasts, that bounce, on his, Ital-ian lea-ther so-fa. My Junk here |
