Teralow 60 Hubs???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-30-2002, 05:52 PM   #1 (permalink)
BadAZYj's Avatar
Member # 6815
Teralow 60 Hubs????
Ok I am building a set of 60s right now, and am going to use 35 spline outers and was going to get some Warn Hubs but then I stumbled on these tera hubs, which are about 50 bucks cheaper than the Warns.
But, I also heard that they are Rebadged Milemarkers and Ive also heard that the 30 spline Milemarkers are very weak So Im wondering how they are holding up?
Thanks
Well this sucks...
BadAZYj is offline   Reply With Quote Quick reply to this message
Old 11-30-2002, 06:56 PM   #2 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
ask bigdude about milemarker hubs
road1will is offline   Reply With Quote Quick reply to this message
Old 11-30-2002, 07:16 PM   #3 (permalink)
Jason R's Avatar
Member # 11598
You are building a set of 60s, don't cheap out. Its only $50, you'll regret it and then spend more on a set of Warn hubs.
Just stick to what is tried and true, especially building an expensive axle to begin with.
This space for rent.
Jason R is offline   Reply With Quote Quick reply to this message
Old 11-30-2002, 07:48 PM   #4 (permalink)
Member # 3547
Why? What do hubs have to do with holding the end of a rope?
Sorry BD....I couldn't resist
BillaVista is offline   Reply With Quote Quick reply to this message
Old 11-30-2002, 08:44 PM   #5 (permalink)
BadAZYj's Avatar
Member # 6815
Exactly I was trying to save some money cuz this chit is expensive I know a couple of guys here have bought them and was looking for first hand experience. And I know about bigdudes experience with MM 30 spline hubs, but I dont know if the 35s are any better, hence the question
Oh, and Billavista Im ROTFLMAO
Well this sucks...
Old 11-30-2002, 09:54 PM   #6 (permalink)
Member # 5162
Location: If you drink enough, you will forget it is Iowa
Maybe they send you a Pink Izod with them.
"26 chicks all tied in a knot. Aint all good but it's what we got"
rodzzilla is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 09:50 AM   #7 (permalink)
BadAZYj's Avatar
Member # 6815
Cmon, anyone break one yet?
Well this sucks...
Old 12-01-2002, 11:28 AM   #8 (permalink)
Member # 466
Send a message via ICQ to Curtis
Don't know about the terra low hubs, but I did break a Warn hub and got a free replacement thanks to the lifetime warranty. Go Warn.
Curtis
Curtis is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 01:13 PM   #9 (permalink)
Member # 3694
I am building a 60 with 35 outters also.....I have a set of WARN hubs but since I'm running a ARB in the front I'm thinking of running the 35 spline Warn "slugs" so I don't have to get out to unlock the front ......anyone have any idea to get a set from.......Thanks in advance guys.........
Need Steering?
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 01:26 PM   #10 (permalink)
Member # 2800
Yea i called a local buddy who is a warn dealer, the warn drive flange part # is 39346, for 35 spl. The kit is actually called like rear 60 FF flange or something crazy like that. It is like 200 buks. Yea thats right more expensive than hubs, but bad ass.
Ian-
Carpe Diem!
COMPLAINE is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 01:36 PM   #11 (permalink)
BadAZYj's Avatar
Member # 6815
Well the teralows are lifetime warrantied too, but Im leaning towards the warns since the teralows arent proven yet.
Well this sucks...
Old 12-01-2002, 01:42 PM   #12 (permalink)
Member # 3694
Ian-
Another reason I'm gonna run the slugs is I have "Heard" that they sometimes can be a pain in getting them fully engaged...they also need to go a full 9/10 of a turn to engage and require a little "rocking" of the vehicle to fully engage them also....Hitting the ARB switch would be much easier....
Yeah I was told that the 35 spline Warn hubs were actually for a rear axle application also. If anyone needs the Part # here it is for the 35 spline "Lock Out" hubs Warn Part # 62672
Need Steering?
Old 12-01-2002, 02:23 PM   #13 (permalink)
Member # 62
Didnt dana ever make a full time front 60? that warn crap is expensive
Jeff Neves
NE-RokToy is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 02:39 PM   #14 (permalink)
Member # 2800
Yep they did, and the spicer 35 spline stuff comes out to like180 once you get the dust cover snap rings and drive flanges.
It just seamed easy to order one part and get all you need, and as another not the warn stuff has a stout dust cover, and it would be my guess that it seals out mud and water much better than the hammer on cheasy spicer dust cap.
Ian-
Carpe Diem!
Old 12-01-2002, 02:59 PM   #15 (permalink)
Member # 1478
I have the Teralow hubs, but they just got put on a week ago, haven't beat on them yet (may not until spring, I hate winter wheeling personally).
I decided on trying the Tera's (which definitely are Milemarkers, comes with a little plastic Milemarker "hubber" thingy) after reading nothing but troubles on here regarding the Warns (as mentioned above by Shaker). Do a search, you will see what I mean.
I'm probably going to get slugs for when I'm wheeling (going hydro assist and possibly ARB).
Charly
Extinguish the light of rationalist authority and barbarous ignorance will be nowhere found.
Charly is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 03:32 PM   #16 (permalink)
Member # 13051
Warn tips
The 35 spline rear FF hubs use a machined ring for whatever reason. This ring causes the need to rock the rig back and forth while turning the hub to get it engaged. Just remove the ring and throw it away.
For the set screw issue.... buy the following from a hardware store:
1 short set-screw (about 3/16 inch)
1 spring (smaller in diameter than the set-screw)
1 BB (bearing)
Replace the Warn set screw with the BB/spring/set-screw combination. You'll have to trim the spring short enough that it allows the BB to slide out of the detent within the hub.
Or you could replace the outer dial with a 30 spline version. I don't think his has the postitive detents though.
CJ7 401fi, TF727 (3.11), Dana 300, 35 spline 60's, 39.5 TSL's on dubba-locks
dmeis is offline   Reply With Quote Quick reply to this message
Old 12-01-2002, 03:38 PM   #17 (permalink)
Member # 13051
slugs
Randy's Ring and Pinion has the Spicer drive flanges...and don't forget the caps...
Old 12-01-2002, 04:36 PM   #18 (permalink)
BadAZYj's Avatar
Member # 6815
Hmmm, seems like 6 of one 1/2 dozen the other, I guess Ill try the teralows and let you all know when they explode
Well this sucks...
Old 12-01-2002, 05:17 PM   #19 (permalink)
Member # 5482
this works for me...
i converted a closed knuckle m715 dana60 to 35 splines all the way across. i ended up with the stub axles sticking out 1/2 inch further than a regular dodge/chevy dana 60. plus the pattern to bolt it up is different.
so our answer.
we took 1/2 inch mild steel, and 35 spline spider gears. we used a hole saw with a bunch of oil and low rpms to drill the center hole out........
i have beating them,so far they are doing great
Mike
Just another guy on the Pirate4x4 board !
billyji is offline   Reply With Quote Quick reply to this message
Old 12-02-2002, 12:50 PM   #20 (permalink)
Member # 4406
Re: Warn tips
Yup...those stupid rings seem to negate the one main advantage of Warns (over the OE Spicers, anyway), their ease of use.
[i]
1 BB (bearing)
I thought about that, but was looking into another solution. The same thing can be accomplished with a vlier pin, its basically a set screw with a spring-loaded ball in the end. I haven't gotten around to finding one that fits yet, though.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 12-02-2002, 01:09 PM   #21 (permalink)
bigdude's Avatar
Member # 6007
Fucking Canadians
Skip milemarker or anyone who re-badges their stuff I sheared the outside "teeth" off the inner splined piece and so did others. If they are Milemarker and have the same design then you could have the same problem.
4-Seats of Fury
LS1, 700r4, Atlas 3.0, 2.5 SAWs, Reds
Lead Foot Syndicate
bigdude is offline   Reply With Quote Quick reply to this message
Old 05-26-2003, 07:44 PM   #22 (permalink)
Member # 1750
Bringing this post back to top for any new info.
I am sick of breaking my Warns and prefer not to use drive flanges YET !!!
Anyone use these with good results?
It seems that the warn 35 spline hubs don't fully engage into the slding mechanism, and the end of the gear shears. What good is a lifetime warranty if the shit can't stay together?
Thanks, Ricky...seeya...
401 LJ the " RUBINCON "
RickyR is offline   Reply With Quote Quick reply to this message
Old 05-26-2003, 08:15 PM   #23 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
Hubs are
Use driveflanges.
Move to southern Utah! Visit my website
Lance is offline   Reply With Quote Quick reply to this message
Old 05-26-2003, 08:17 PM   #24 (permalink)
Jason R's Avatar
Member # 11598
I don't know of any "stronger" hubs than Warn's, but Pig at Polyperformance.com makes a nice set of drive flanges.
Old 05-26-2003, 09:55 PM   #25 (permalink)
PIG
2indapink&1indastink
PIG's Avatar
Member # 4502
Yes, we got them done up. I have been working on the site all day and will post a link to the new improved drive gear page in a few hours.
USE CODE: PIRATE10 FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
COOL STUFF FOR YOUR BUGGY, JEEP, DODOGE 2500/3500
PIG is offline   Reply With Quote Quick reply to this message
