Member # 8054
KRC Power Steering Pump
Has anyone used these? What results?
http://www.speedwaymotors.com/KRC-CA...PUMP,4836.html
Broncoholic |
#2 (permalink) | |
Member # 100025
427W EFI,C6,atlas, D80s and a whole lot of work left to do |
#4 (permalink) | |
Member # 84132
A different personality started the first thread. He's so high he forgot he started the first thread a few minutes earlier. He's padding his post count, 3 posts per year just isn't cutting it anymore. He's hoping for twice as many responses. One of his co-workers posted the other thread while he wasn't looking, ironically they had the same exact question. Etc.
www.jaggedx.com www.crdesigns.com AEI Motorsports www.campbellent.com www.geiserbros.com |
#6 (permalink) | |
they are working great so far. Call krc and talk to Norm, He's good tech guy if you got any questions.The cast pump(s) will work fine if you have the correct pulley's to make sure you don't over rev the pumps. A 1 to 1 ratio is what you should shoot for.
07' Jim's Garage narrowed rockwell buggy |
Member # 76809
bumping this back to the top......so what is the general consensus on KRC aluminum pumps and how do they compare the a PSC p-pump? I'm running a matching PSC orbital and their 3x9 ram on a 60 turning 44" PBR's with a slightly modded p-pump on a 5000 lb truggy. The problem I am having is my steering is a bit sluggish. I have changed my pulleys around to speed the pump up and that helped but i still need more.
Any tech or suggestions? Last edited by OKMudn; 05-15-2012 at 08:14 PM. |
#8 (permalink) | |
Member # 8937
Jesse Haines Fabrication #199/4499 - Maxxis, PSC, Superior Axle and Gear, Trail Gear, Branik Machine Shop, Valley Transmission, High Angle Driveline, Warn, Sway-a-way. |
