Anybody use a chop saw to cut vinyl blinds - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-09-2011, 05:00 PM   #1 (permalink)
Member # 6957
Figured I'd ask here before I did it
Go to the hardware store and they have the cheaper blinds in either 43" or 46" wide and I need 45". They don't have a cutter so I would have to buy the next blinds up.
The next ones up come in either 44" or 51" and are 3 times the price. I need to do 2 windows and at $30 a piece this is just to damn much.
So anybody ever cut vinyl blinds with a chop saw
ironpig70 is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:02 PM   #2 (permalink)
Member # 64421
Do it you pussy
TheRedHorseman is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:09 PM   #3 (permalink)
Member # 71568
Send a message via AIM to gmcz7198 Send a message via Yahoo to gmcz7198
I've used a miter saw, multiple times. Just get the cheap ones and cut the difference equal on both sides.
gmcz7198 is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:11 PM   #4 (permalink)
Member # 87698
post pictures
80 cjunk7, with stuff--SOLD
new build... 90 yjunk, longer, wider, more stuff,
fasten your seat belt, it makes it harder for the aliens to suck you out of your rig
NRA LIFE MEMBER
beefdawg is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:11 PM   #5 (permalink)
Member # 6957
Taking it this is for wood and I have one of these also. What teeth per inch blade you use? The top rail is thin sheet metal.
Old 10-09-2011, 05:12 PM   #6 (permalink)
Member # 6957
Originally Posted by beefdawg View Post
post pictures
Will do
Old 10-09-2011, 05:36 PM   #7 (permalink)
Member # 108445
They cut them to size for you.
rocket flier is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:38 PM   #8 (permalink)
Member # 6957
Nope. They will not cut these as they don't hav the saw But if you spend 3x on the other ones they will cut them.
So I figured I'd cut them myself.
Old 10-09-2011, 05:43 PM   #9 (permalink)
Member # 42720
Yep no problem, done it many times. Cut throughout the aluminum was rail and blinds all at once. I just don't use my good blades in the saw when I do.
THE MEEK SHALL INHERIT NOTHING
www.helmutwatches.com
ChaseYJ is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 05:47 PM   #10 (permalink)
Member # 6957
What kind of blade and TPI do you use? Have several blades from ripping to cutting melamine to trim.
Old 10-09-2011, 05:48 PM   #11 (permalink)
Member # 194960
Chop saws work just fine. Switch from wood blade to cutting disk. Works like a charm
v1nc3 is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 06:10 PM   #12 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
I used my 4.5" grinder with a cutting blade to quickly cut through the plastic shed roofing stuff over the summer. Probably not as pretty, but it worked damn good. Could probably clean it up fairly easily with a quick pass with a file.
76 Scout, 85 Toy. 94 Cherokee ALL SOLD
Resident Web-Wheeler
budget76 is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 06:57 PM   #13 (permalink)
Member # 138168
i have also done it. if there is no metal in it, turn the blade backwards (doesn' matter on the teeth count) and go slow. if there is metal keep the blade the proper way, use the highest teeth count you have and go SLOW. if a tooth catches on the vinyl, it will rip it to shreds.
4x4orbust is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 11:11 PM   #14 (permalink)
Banned
Member # 200562
tried it...... get homo depot to do it
jillyjack is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 11:26 PM   #15 (permalink)
akpostal's Avatar
Member # 15230
I did it with a cordless Dewalt saw and a combo square. Just cut equal amounts from both sides.
COI
akpostal.com
akpostal is offline   Reply With Quote Quick reply to this message
Old 10-10-2011, 12:05 AM   #16 (permalink)
Member # 189225
Send a message via AIM to kastein Send a message via Skype™ to kastein
every home depot I've ever been to has the cutter and they even have shades in the $5 range (what I used last time, since it was an apartment I'd be staying in for like 6-12 months... just wanted the sun to stay out of my face in the morning.)
If you do it yourself use a sharp enough blade that it cuts instead of melting its way through, else you will be picking the blind slats apart by hand.
Not only can I fuck up a steel ball in a rubber room, I do so often - by accident.
kastein is offline   Reply With Quote Quick reply to this message
