#101 (permalink) | |
Im running a 72t on this build. We will see how it works.
Building high performance turbo diesel motorcycles. |
#102 (permalink) | |
Member # 90381
As long as you stay clear of the clutch basket, you should get by with a bruise on your ankle every now and then. You have some good skills, and the mind of a fabricator. Keep it up! |
#103 (permalink) |
Rough cut, bored, and installed bearings in rear hub. Hub will be cut to finished dimensions ( the large part that spaces pulley from rim) when tire and trans are centered and mounted.
Tires ordered. Need to source some buell front calipers and order rotor material.
#104 (permalink) |
Fistful of Boomstick
the 4 piston blast's or the 6 piston everything else? There are a bunch on ebay right now
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#107 (permalink) |
Now making the perimeter rotors. Layed out and center punched mount holes. Now i need to decide to cut them with the plasma or bridgeport. Heres a pic of a rear rotor mocked up for plasma cutting. Replace dial indicator with fixed plasma torch.
#109 (permalink) | |
I made the hub this wide (dropout to dropout) to minimize any deflection under load, keeping the bearings as far outboard as possible.
Building high performance turbo diesel motorcycles. Last edited by dethmachinefab; 05-18-2012 at 05:04 PM. |
#110 (permalink) | |
xPOLYMATHx
Are you doing it solely for styling or are you considering other reasons? Will they be linked via proportional valve and a single lever or independent like typical? Buell's were linked, weren't they?
Dirty deed done dirt cheap! and custom leather belts and such too. 1979 FSJ Chief almost for sale. Inquire within. Last edited by LucasFury; 05-18-2012 at 05:21 PM. |
#111 (permalink) | |
I don't know if some buells were linked, sounds scary to me.
Building high performance turbo diesel motorcycles. Last edited by dethmachinefab; 05-18-2012 at 06:10 PM. |
#112 (permalink) |
xPOLYMATHx
I may be mistaken about the Buells having linked brakes. I know Goldwings use a linked system for the foot lever, but the hand lever still controls the front alone. Motoguzzi used to do something similar as well.
I know some bobber builders that never build anything with a front brake, and I truthfully very rarely use my own so I'm debating on whether I want to attempt a linked system vs no front brake at all on an upcoming build (or series of builds). I feel like a linked system with something like 65f/35r ratio (possibly with a delay to the front) on a foot lever would work well for people who know how to downshift properly for decel in situations where heavy front braking would be dangerous. ..obviously not on "performance" machines or people who use a lot of front trail braking (I use rears), but no one is worried about cleaning up the handlebars on that type bike anyway. I was hoping I was gonna be able to steal ideas off you. ![]() I'm very anxious to see the finished product and can't wait to hear your thoughts on how it performs vs typical rotors.
Dirty deed done dirt cheap! and custom leather belts and such too. 1979 FSJ Chief almost for sale. Inquire within. |
#113 (permalink) | |
#114 (permalink) | |
xPOLYMATHx
#115 (permalink) | |
If dead set on empty bars, run 2 rear type masters side by side and a split pedal. Similar to how ag tractors have left/right brake. Simple and clean.
#116 (permalink) | |
xPOLYMATHx
![]() The split pedal idea is new to me. Are we talking two skinny pedals next to each other where there is a possibility of pushing both at the same time (on purpose or not) or front/rear where you would have to rock your foot to or fro and be forced to choose? If I had to choose I would probably always use the rear, in which case I'd be more likely to just not have a front at all.
#117 (permalink) |
Member # 21498
Linked brakes were come up with for the masses that bought a bike but don't really know how to ride.
So many accidents with people using rear brake only, so rear pedal operates rear and the front. On some of them Hoda used a front caliper with 6 pistons, two were noperated by the rear brake pedal, the other 4 by the front. Some bikes operate the rear some with the front lever. Biggest problem for people who ride is there are times when you only want front only or rear only as mentioned earlier. Nice build. I wish i had some skills, would feel great to make something like that.
[QUOTE=Roxywheels;12338636]Was this all a one sided conversation. I have a vagina and speak crazy but that bitch left me in the dust! :roxy:[/QUOTE] |
#118 (permalink) |
Member # 29037
Your hub reminds me of one a buddy and I machined out a block of steel for his drag bike back in the late 80s. It took forever on his Enco lathe because the out side of the steel had been hardened from the cutting torch. That and we were only able to work on it a couple of hours at night.
“I will not be wronged, I will not be insulted and I will not be laid a hand on. John Wayne “The Shootist.” Last edited by bigun; 05-18-2012 at 10:02 PM. |
#119 (permalink) | |
#120 (permalink) |
Cut the rear perimeter rotor today, rough cut with plasma contraption. Finished on rotary table. Here its siting on bolts to get an idea of how it looks. It will be much closer tward the middle. Standoffs are to be made after i get calipers. Rear is a 16" rim so its small. I also need to lay out all the vent holes.
#122 (permalink) | |
But cross drilled and safty wired allens would be badass.
Building high performance turbo diesel motorcycles. Last edited by dethmachinefab; 05-20-2012 at 07:27 AM. |
#125 (permalink) |
Member # 118558
How clean are you trying to make the bars? Hidden throttle and twist grip clutch?
I kinda like seeing cables and stuff on a bike, but if you're going for hidden, you should go all out. You do excellent work.
'96 XJ D44/D60, Clayton LA 6.5" 35's |
