Member # 163633
cant find on board air
im looking for a diagram of how to run lines in which order
for my onboard air. from my york. to tank. to arb. a cant find the diagram and i know its out there. io cant remember if its here or on ih8mud. iv been searching for over an hour with no luck. either way if u have the link please let me know thanks. |
#3 (permalink) | |
i win diesel!!1!
Member # 158768
x2 hopefully bob can fix it in the a.m. because i didn't laugh one bit.
web wheeler 4 life. Quote:
#5 (permalink) | |
Retro Wheeler
Member # 36
1985 4Runner SR5 not so stock. |
Member # 110491
That diagram is wrong. You're supposed to take out a spark plug and screw the input hose of the air tank into the spark plug hole.
norcaljeepers.co Last edited by cmarjeep; 04-03-2012 at 10:22 PM. |
Banned
Member # 68805
doesn't matter where the ARB regulator gets its air from..it's all the same system. I'd put the regulator at the manifold and put a cutoff between the manifold and the tank, so if you spring a leak between the mani and tank, your arb won't be disabled.
#12 (permalink) | |
Member # 34803
Shouldn't really matter where you tap in as the whole system should be presurized equally. I would use the least possible amount of tubing and joints based on location.
#13 (permalink) |
Member # 73218
i bout a fitting that attaches to the stem on my tire. anytime I need to fun air I just connect it to the tire and use the air from my tire.
youre thinking too hard.
[QUOTE=soilantgreen;10014492]Sorry, I couldn't hear you over the sound of your rig sucking. [/QUOTE] [QUOTE=TJDukit;12169111]No, I'm not a fag, I suck a dick at least once a year to make sure I still don't like it.:flipoff2:[/QUOTE] [QUOTE=CSR;14325560]I can't tell. Looks like him. I'd need to see his ass or wang to 100% certain! [/QUOTE] |
