What would you do (DD tech) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2012, 11:10 AM   #1 (permalink)
Member # 46933
So, the wife's Tahoe crapped out about 7 months ago. I parked it, and bought her an Excursion as I did not have the time to mess with it.
Fast forward to today. I pulled the head, and found that it had dropped a valve. The valve pierced the piston, bent 2 rods, and gouged up the head. The cylinder wall is fine though.
Here is my conundrum: Should I sell as-is, or fix and get more money/use out of it?
I don't really have the time to tear it down and put it back together. The KBB is about $8k (2002 LS) and I was thinking about putting it up for $4k needs motor. I can probably drop the pan, change the piston, and do a junkyard head for under $500, or get a junkyard longblock for a couple hundred more. It all comes down to time though. I don't owe anything on it, the interior is still nice (as is the body), but I am working on a gravel driveway, and need to get it done quick.
What would you do?
Oh, and Happy Zombie Day!
RedBullJeep: Once a head gets sloppy side to side, it makes the cradling a little less consistant.
Boheefus is offline   Reply With Quote
Old 04-08-2012, 11:26 AM   #2 (permalink)
Member # 211939
You can get a running takeout for pretty cheap. If its worth your time to replace the engine, then I would do it. If not, I would just junk it.
Killroy1942 is offline   Reply With Quote
Old 04-08-2012, 11:29 AM   #3 (permalink)
Certified E-Thug
montecarlo31's Avatar
Member # 117771
If that were mine I'd pull the engine and swap in a LQ9 or LQ4 depending on what I can find. Then I'd rock it for a couple more 100K.
My .02 cents. I am cheap and it sounds like a good core to me. You couldn't pick up a cheap DD for 1,200 (which is what you can get a LQ9 for and freshen it up).
montecarlo31 is offline   Reply With Quote
Old 04-08-2012, 11:30 AM   #4 (permalink)
Roc Doc's Avatar
Member # 20631
Send it to Texas. Camerogeeenyus has great plans to remedy these situations.
Buy my buggy.
Roc Doc is offline   Reply With Quote
Old 04-08-2012, 11:30 AM   #5 (permalink)
Member # 46933
Not a matter of being worth my time, just a matter of having time to do it.
Old 04-08-2012, 11:31 AM   #6 (permalink)
ky scrambled's Avatar
Member # 85771
buy a 6.0 liter Ferd
Play stupid games, win stupid prizes
ky scrambled is offline   Reply With Quote
Old 04-08-2012, 11:32 AM   #7 (permalink)
Member # 85771
So yer Tahoe stopped working and instead of fixing it you bought an Excursion?
Old 04-08-2012, 11:41 AM   #8 (permalink)
247pia's Avatar
Member # 174055
My thoughts
247pia is offline   Reply With Quote
Old 04-08-2012, 11:51 AM   #9 (permalink)
Member # 75114
I will give you tree fiddy for it.
keeptahoewhite is offline   Reply With Quote
Old 04-08-2012, 11:52 AM   #10 (permalink)
Member # 85771
keep outta here you goddamn lochness monster!!
Old 04-08-2012, 12:34 PM   #11 (permalink)
Beat95YJ's Avatar
Member # 22176
4bt. Always the go to answer.
Beat95YJ is offline   Reply With Quote
Old 04-08-2012, 12:47 PM   #12 (permalink)
Jules083's Avatar
Member # 123683
I'd probably find a complete motor, either junkyard, Craigslist, whatever, and swap the whole thing out. Drive it or sell it after that. It's way easier to sell a running vehicle than a blown up one. You said it yourself that it's worth 8k running, 4k blown up. Motor should be under a grand. That's at least 2k in your pocket, maybe 3 if you find the right buyer.
Originally Posted by Lance
Will there be changes? I don't expect many, if at all
Forums will not change, administration techniques will not change one bit.
Ads will stay in the same places they currently are.
Jules083 is offline   Reply With Quote
Old 04-08-2012, 01:20 PM   #13 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
Camarogenius's Avatar
Member # 49232
Send a message via Yahoo to Camarogenius
Don't you have teenagers rapidly approaching driverdom? Fix it, let them drive it, and use it as a tool to hang over their heads if they misbehave.
OH! and those should be sodium filled valves, so if the valve is in more than one pieces, toss it into a bucket of water for entertainment.
SECEDE!
Truth is treason in the kingdom of lies.
Camarogenius is offline   Reply With Quote
Old 04-08-2012, 01:20 PM   #14 (permalink)
PEBKAC
kc8ksg's Avatar
Member # 135367
This x2
With the amount of time you waste with lowballing craigslisters offering you $1500 you could swap a junkyard motor in it and have sold it for $7-8k.
kc8ksg is offline   Reply With Quote
Old 04-08-2012, 01:51 PM   #15 (permalink)
Member # 46933
Yup. We needed a bigger SUV any way. The event just made us go out and get one sooner.
I am still on the fence. $3k more would be nice, but my work schedule is quickly filling up, and I have to get the boat in the water too. The female child is going to get something else to drive. I still have a couple months on that.
Old 04-08-2012, 01:55 PM   #16 (permalink)
Member # 85771
you dont sound like a person who is need of 3 grand...sell it and move on since you have already made up yer mind.
Old 04-08-2012, 02:01 PM   #17 (permalink)
WiCK3D_SiX's Avatar
Member # 201740
Search Duraburb on youtube. This is what should be done.
Sent from my DROIDX
WiCK3D_SiX is offline   Reply With Quote
Old 04-08-2012, 02:24 PM   #18 (permalink)
supersize75k5's Avatar
Member # 29341
Gee there is only wiring, exhaust, emissions, trans hook up, motor mounts, the t-case if its a 4x4' rad hoses, and a slew of others.
So just how many dead projects are in your driveway that you underestimated
supersize75k5 is offline   Reply With Quote
Old 04-08-2012, 02:30 PM   #19 (permalink)
Member # 85771
I can answer that for myself and that answer is ...ALL OF EM
Old 04-08-2012, 02:45 PM   #20 (permalink)
intensesupernova's Avatar
Member # 44281
Send a message via AIM to intensesupernova
Is your time worth the extra couple grand you could get if you swapped motors?
intensesupernova is offline   Reply With Quote
Old 04-08-2012, 03:03 PM   #21 (permalink)
Member # 84067
Unless someone put in zo6 valves then no...no they are not sodium filled.
moggie is offline   Reply With Quote
Old 04-08-2012, 03:08 PM   #22 (permalink)
Certified E-Thug
Member # 117771
hummm 2002 Tahoe...let's see, oh yeah, same engine setup. So no he doesn't have to change anything, it's a direct swap. I can pull and reinstall a LSx truck engine (in a 4x4) in under 5 hours...ask me I've had to do it.
I'd do the swap no questions asked.....and I have zero projects incomplete.
BTW sodium filled is only on Z06 in that vintage LSx engine.
Old 04-08-2012, 03:10 PM   #23 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
what what what?!?!? cg is a fucking retard.... who would have guessed.
get what ever money you can out of it now before you have to spend anther $k repairing the front/rear axles, tcase, 4x4 controls, and front wheel bearings.
Old 04-08-2012, 03:22 PM   #24 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
you could pay a shop a grand to swap it, and still net $2k more in your pocket.
Mo is offline   Reply With Quote
Old 04-08-2012, 04:31 PM   #25 (permalink)
Member # 46933
Depends. I know that I can make a profit, if I swap motors, but it is all net anyway, as it has been paid off forever (we are the original owners)
See above. I have a couple of buddies with full on home shops. I was thinking of tossing them $500 and a case of beer to help me out.
I am a Yota guy, so I lack some of the special tools (fuel line releases, etc.) but I could do the work if time were no object. It really all boils down to aggravation factor at this point. The extra money would be nice, but is not necessary.
Thanks for the input. I still have no idea what I am going to do
