So, we have this jeep that makes a noise - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-28-2012, 10:36 AM   #1 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
Send a message via AIM to Roxywheels Send a message via Yahoo to Roxywheels
I know, surprise surprise And yes, this is tech and I don't care that this isn't the place for it and I don't want to post it in the jeep forums. I don't like it there
The stats...1995 4cyl YJ. it came to us very cheap, so that makes it tolerable, except for the fucking squealing noise that it randomly makes. It doesn't do it all the time and you can't make it do it when you want to hear it. it squeals when you are driving. It squeals when you are idle. It does seem to squeal more when you decelerate. The part that is maddening is that we can't quite figure out where the noise is coming from. When I first heard it I thought throw out bearing, but its so random that I don't think its that. Then Robert thought it was the pilot bushing, but now he's leaning toward something in the alternator. Its really not like a belt squealing sound...its almost like a high pitched vacuum squeal. Robert can't get it to squeal when its idling long enough to track it down.
Ok...tell me what it is Seriously, I know you can't help much but any ideas are helpful
I'm not a bitch, I just play one in your life
Roxywheels is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:41 AM   #2 (permalink)
Member # 9307
idler pulley...maybe.
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:41 AM   #3 (permalink)
Member # 3935
ScottFJ40's ghost haunting you.
When you hear that squeek you will thing of Scott.
SCOTT
southernfriedcj8 is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:42 AM   #4 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Serpentine belt tensioner pulley?
’94 GMC 6.5TD K1500 Yukon SLE / ’93 Chevy 6.5TD K2500
’85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:47 AM   #5 (permalink)
imafighterjet
krawlr's Avatar
Member # 13619
Send a message via Yahoo to krawlr
A pilot bearing will definitely stop if the clutch is engaged. A release bearing should change the sound with foot pressure.
I'm triggered, BOOM, reload!
krawlr is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:50 AM   #6 (permalink)
Runs Amok
s14sh3r's Avatar
Member # 181276
Ignore it. It's a Jeep thing
s14sh3r is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:50 AM   #7 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
It does it with the clutch in or out.
Old 05-28-2012, 10:59 AM   #8 (permalink)
Member # 86685
I have heard water pumps squealing before also.
s10er8 is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:01 AM   #9 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Muffler bearring.....
MY BUILD
04 Rubicant Ultra4
My precious.... 72 K5 Blazer
web wheeler...
DJ404564X4 is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:03 AM   #10 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
I had those changed before Robert got home
Old 05-28-2012, 11:03 AM   #11 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I'd agree. Fast way to check is to pull the belt and see if you can move the shaft.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:06 AM   #12 (permalink)
Member # 114810
My YJ has an occasional squeal like that from the distributor bushing. It gets dry and squeaks/squalks for a while, or sometimes just for a few seconds.
When it won't go away, I pull the distributor and lube the oil hole with gun oil or pb blaster. sometimes I have to lube it then spin the gear a while. You will feel it "free" up, as it will become easier to spin. frees it up for a while.
engnmonkey is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:07 AM   #13 (permalink)
Permanent Newb
Cooter!'s Avatar
Member # 176672
Like a "Tinny" squeak? A heat shield or exhaust rubbing on something?
Next time it does it, put your foot on the tailpipe tip and see if that changes it.
Nice, chit-chatting with you
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question.
Peterson's 4 Wheel & Off-road UA2014 Alumni.
Cooter! is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:09 AM   #14 (permalink)
Member # 39143
I've heard exactly that symptom & cause on a YJ.
I'd say just being able to turn the shaft wouldn't automatically rule it out, unless it spins smooth and feels nice and tight.
But hey, could be the power steering pump, alternator, or any other pulley, too.
I've fucked guys like you in the face and up the ass.
locotaco85 is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:10 AM   #15 (permalink)
Member # 58373
Even easier, pull the belt and start the engine. Still squealing, it isn't an accesory.
Dodge_man is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:10 AM   #16 (permalink)
Runs Amok
s14sh3r's Avatar
Member # 181276
Sounds hot
Old 05-28-2012, 11:25 AM   #17 (permalink)
Blame Canada's Avatar
Member # 5176
Turn the volume control knob to the right, to eliminate the squeal. Keep turning, until it disappears.
I keep my post count low by posting in chit-chat.
STOLEN!!! -->'80 CJ-7 w/ 258 I-6,T-176,D300, '94 YJ tub, '83 toy axles front & rear, Smirffield front axles, w/3.90's, 'YJ rears up front, and a bunch of home-grown patches, all sitting on BFG 35" MTs.
Post #411
Blame Canada is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:27 AM   #18 (permalink)
Newbie
D'Mann's Avatar
Member # 41611
Bad brake booster did that on mine..... but mine's the old 4.2...
D'Mann is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:31 AM   #19 (permalink)
Member # 34639
Had a 2000 grand Cherokee alt do that. Drove me nuts. The bearing in the rear of case had gone bad.
Just trying to keep my sanity in modern america
oddcarma is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:41 AM   #20 (permalink)
theytookmyname's Avatar
Member # 145344
Originally Posted by s14sh3r View Post
Sounds hot
theytookmyname is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:47 AM   #21 (permalink)
Member # 5060
Clockspring.
Roxy queen of the double standards.
Move this sH|t to tech.
Maine Jeepah is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 11:51 AM   #22 (permalink)
Overbear's Avatar
Member # 20114
Send a message via AIM to Overbear
Its a jeep, sell it and buy a toyota, problem solved
Eddie Oh is a scammer with the
website.
“Christianity neither is, nor ever was a part of the common law.”-Thomas Jefferson, letter to Dr. Thomas Cooper, February 10, 1814,
When I'm the voice of reason, it's a pretty good indication that someone's doing it wrong.
Overbear is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 12:02 PM   #23 (permalink)
drydocker's Avatar
Member # 34052
I had a customer's 4.0 make a noise like that. The intake bolts had loosened, and the metal intake manifold gasket was acting like a kazoo. Do the 4 cylinders use metal intake gaskets?
drydocker is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 12:11 PM   #24 (permalink)
Member # 119162
Twice now I have had customer's Jeeps in here with the same symptoms. In both cases, I found the intake to be cracked. Temperature can cause the crack to open, and the vacuum being pulled makes one heck of a racket. Look very closely at the intake, to the extreme front and rear. I have also seen too many cases where the stud holding the manifolds fatigues and just snaps off. Look to see if they might be missing. Once again, they are at the extreme ends of the manifolds. Good luck!
Yes, I do have an addiction to Jeeps, and uncontrollable urges to play in the dirt.
millerlight is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 12:19 PM   #25 (permalink)
Member # 99624
Im putting my money on idler pulley bearing.
replace those... they arent expensive, so its easy.
Alternators usually WHIRRRR instead of squeek.
You should be able to tell if the sound is coming from the front of the engine or the rear just by listening.
When in doubt, get a wooden rod and put it on the front of the engine when it is running (WATCH OUT OF THE FAN AND PULLEYS!!!) Then compare the noise level to the rear.
If you are cautious, you can take the wooden dowel and put it on the back part of the alternator housing (NOTE I SAID TO USE WOOD DOWL NOT METAL!!) listen for noise. Now compare to the AC compressor, then to the steering pump, then to the idler pulley (put the dowel on the bolt, but be careful damnit!)
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
