OSB under laminate flooring? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-12-2012, 06:51 AM   #1 (permalink)
ndsgr's Avatar
Member # 60349
Title basically sums up the question.
My wife decided she wanted all new flooring on our main floor. I'm doing tile in the kitchens and bathrooms, laminate in the living room. Upon tearing up the kitchen to put down backer board, I discovered the living room needs to come up at least 1/4". Can I use OSB for this? I'm not trying to cheap out at this point, but is there a significant benefit to using plywood, especially since there is already OSB there?
I am also putting down the vapor barrier/foam pad stuff under the laminate.
ndsgr is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 07:14 AM   #2 (permalink)
spork2367's Avatar
Member # 66259
do it right and put down 1/4" hardwood plywood underlayment
For the best deal on 8 lug disc brakes click here--> www.lugnut4x4.com
spork2367 is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 07:21 AM   #3 (permalink)
Resident Beekeeper
CJesse7's Avatar
Member # 36707
Send a message via AIM to CJesse7 Send a message via Yahoo to CJesse7
this
A government big enough to give you everything you want, is a government big enough to take everything you have.
My Reverse Flow BBQ Pit Build
http://www.pirate4x4.com/forum/gener...pic-heavy.html
CJesse7 is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 07:27 AM   #4 (permalink)
Member # 214801
Don't forget to plane the seams of the OSB that is already down too!
rednekYJ is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 07:31 AM   #5 (permalink)
spork2367's Avatar
Member # 66259
I use a belt sander to keep from just ripping it apart. Otherwise, you need an EXTREMELY sharp plane.
Old 06-12-2012, 07:33 AM   #6 (permalink)
ndsgr's Avatar
Member # 60349
Will do. Is $20 for a 1/4x4x8 sheet sound about right?
EDIT: What do I use to secure it? Screws and an adhesive?
Old 06-12-2012, 07:47 AM   #7 (permalink)
Member # 214801
Crown staples, lots of em.
Old 06-12-2012, 07:59 AM   #8 (permalink)
spork2367's Avatar
Member # 66259
Yeah, it's not cheap.
Or ring shank nails.
Old 06-12-2012, 08:03 AM   #9 (permalink)
Member # 180139
For laminate glue and screws would work fine if thats easier for you, but the staples are best, staple with the grain so it doesnlt pop out chunks, and staple every 6" around the edges and then a row every 1' spacing about 6-8".
Thats what we do when preping fo tile, so for a floating floor should be mint, also you should lay your sheets perpendicular to the origanal floor sheeting
97 dodge, cummins, 2.5 tons, 52" r1's
cumminsbogger is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 08:06 AM   #10 (permalink)
ndsgr's Avatar
Member # 60349
Thanks for the help guys!
Kind of a different topic, but regarding tile: I jacked up a bit, I think. I pushed a little too hard on one room's tiles. They all seem secure, but what can I expect in the future? Just some cracked ones or loose ones? For the rest of the rooms, I'll use the rubber mallet and piece of wood trick.
Old 06-12-2012, 08:13 AM   #11 (permalink)
Member # 214801
Luan is an acceptable underlay product for floating floors, That said Luan should not be $20 a sheet. $10-15 a sheet at my local Menards. Fawk Home Depot, Menards beats them every time.... If you really want to get serious look into some 5ply 1/4" birch.
Old 06-12-2012, 08:13 AM   #12 (permalink)
Member # 180139
Ive got a question about your first post, why does the living room need to come up in the first place? Lower than the tile? Reason im asking is the lamanite should be lower than the tile
Old 06-12-2012, 08:26 AM   #13 (permalink)
Member # 134764
Not necessarily lower than the tile, but within 3/16's or you will have problems with the transitions.
f.allen is offline   Reply With Quote Quick reply to this message
Old 06-12-2012, 08:37 AM   #14 (permalink)
ndsgr's Avatar
Member # 60349
The living room is currently white carpet. We have two kids and cat. It doesn't stay white. If anyone has any ideas aside from raising it, I'm all ears!
Here is the transistion to the kitchen (put in the backer board on left and a tile sample or right as well as some of the old laminate for measurements):
Here is the transition to some existing hardwood at the entry way (note carpet foam is blocking part of the ruler).
Here is the fireplace tile (in living room):
Old 06-12-2012, 08:47 AM   #15 (permalink)
Member # 180139
Ic what your saying, normaly what we do in our houses is use 1/2 plywood subfloor for the tile and for the transition we use shcluder (sp) transition , so the tiles a half inch higher than our laminate and the laminate slides right under our shcluder (sp?) We obviously tile then do hardwood or laminate
Old 06-12-2012, 09:02 AM   #16 (permalink)
Member # 134764
If your using a T-cap transition piece between the tile and laminate transitions, the closer to level you are the better. But, within 3/16 on either side will work - I have to deal with this a couple of times a month (flooring guy) and the customer is usually happy with this.
Old 06-12-2012, 09:04 AM   #17 (permalink)
Member # 180139
Id look into some differnt transitions you might find a step down that matches you laminate too , your still going to have to put on in might be able to save a step
Old 06-12-2012, 09:48 AM   #18 (permalink)
Member # 214801
There will be a T-mould transition that will work for any height/flooring difference. Ya just gotta find it, and sometimes get a little crafty with the table saw.
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
