#52 (permalink) |
Rig Wrecker
Member # 38193
You can have 13 receptacles on a 20 amp circuit. I think its only 8 (without checking my book) of 15 amp.
"History is the lie commonly agreed upon" --Voltaire |
#54 (permalink) | |
Not that it matters to me, everything in this house is 12ga wire, damn near every circuit has a 20A breaker behind it. |
#55 (permalink) |
Member # 25416
So the plugs and lights in a bathroom need to be on their own circuit? I'm remodeling a bathroom right now, and pulled 12/2 for everything, which is better than it was before. They had two bathrooms and a master bedroom on one circuit.
#56 (permalink) | |
Member # 6726
The original design however was for a carport with no outlets. The builder enclosed it but never updated the electric to reflect a garage.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR] "He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill |
#57 (permalink) |
Member # 198851
All this code requirements are for work being inspected and or you're doing it for money.
On your own house you can do as you please within reasonable limits.The limits being the correct size wire on the correct breaker or fuse and proper outlet devices. And most important is good workmanship on wire joints and terminations. If you run a few extra things on the bathroom circuit and it's done correctly,no big deal. However,keep in mind,if there a fire or personal injury and the cause is determined to be building electrical....An insurance company can limit their damage payments if they find shit faced wiring that you were aware of. |
#58 (permalink) | |
Member # 3184
Confused now? sorry!Best idea is to run a 12/2 home run to each bathroom for it's plugs. If more than 1 plug in a bathroom then you can load out of the first gfi to the second plug. Don't waste $ on a 20A gfi ![]() Run the fan and lights off the local (15A) lighting ckt. In Ca (at least) you need a fan now whether there's an operable window or not. I like to put them on timers, people seem to use them more if they don't have to remember to turn them off.
2000 Toyota Sienna, 1995 BMW 525iT, 1985 CR350R, 2001 CR125R, 2006 KX65 Last edited by fourlofirst; 07-16-2012 at 05:45 AM. |
#59 (permalink) | |
Member # 3184
Start loading up circuits, then the next guy buries a j box or two, then... Slippery slope
2000 Toyota Sienna, 1995 BMW 525iT, 1985 CR350R, 2001 CR125R, 2006 KX65 |
#61 (permalink) |
Boats 'n' Does
Member # 24296
My house burned down just reading this thread.
92 FJ80 stock 74 FJ40 in pieces 88 S-15 350,700, 203/205, tons, 44's 06 Tundra...it's white 94 4runner Limited 07 Caliber...it's black 06 Craftsman LTX2000 deck set on 4. |
#62 (permalink) |
Member # 32677
I've spent the last 48 hours pulling romex so I can get every outlet in my house on it's own breaker, this afternoon I'm going to start driving my 8 new ground rods just to make sure I have everything covered.
#63 (permalink) | |
Member # 25416
#64 (permalink) |
Member # 61545
If you want to be real safe, have every outlet on a separate circuit and install a sub panel in every room to hold all the breakers you will need and have a 500 amp main service. (3 phase of course!)
#65 (permalink) |
Member # 3184
So you're the reason I gotta put in $40 AFCI breakers on everything not GFCI'd or dedidacted huh?!?!
#66 (permalink) | |
Boats 'n' Does
Member # 24296
They make a combonation AFCI/GFCI breaker now.
#68 (permalink) | |
Member # 3184
You shaddup!
#69 (permalink) | |
![]() ![]() Now, if you (or any of us) were thinking ahead, you would have driven those 8 new ground rods while your ground was saturated. |
