Carson trailer issues - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2012, 03:55 PM   #26 (permalink)
Member # 27674
Send a message via Yahoo to morp
did Carson ever do anything for you about it ??
morp is offline   Reply With Quote Quick reply to this message
Old 08-07-2012, 03:55 PM   #27 (permalink)
Member # 27674
but they should last more than less than 1000 miles
Old 08-07-2012, 03:56 PM   #28 (permalink)
Member # 27674
I agree that they should last only 3-5000 miles, but under 1000 worn out, that's just wrong
Old 08-07-2012, 04:02 PM   #29 (permalink)
Member # 27674
the whole story
we bought this trailer for our club TDS to haul the Sweepstakes Jeep, we figured we would sell this trailer after we gave the Jeep away and recoup the monies.
Anyway we bought the trailer just over 3 months ago, used it for about 1000 miles hauling the jeep around, we checked the wheel bearing grease and filled them up, when we checked we found that the rear tires were almost bald, like one to the wear bars and the other not far from it. But the fronts were normal.
So I took it back to Carson and the checked it out and are claiming that it is within their tolerances and that the tire pressure was 8-10 pounds low. We never checked the pressure due to it being a new trailer and that it should have the proper pressure from the factory.
I had our club front end man check it out and he thinks that the spindles on the axle are a degree or two out and it is dragging the tires sideways down the road.
Anyway Carson is trying to get out of their warranty by saying the tires were low so that is what caused the wear.
I spoke with Allied, who supplies the wheels & tires to them and they say they are nuts, that no way could 10 lbs. cause the tires to wear that much in 1000 miles. And all it would do is lower the carrying capacity 100 lbs per tire, not wear them out.
That is where we are currently, also the wiring is messed up from the factory, when you put the brakes on the clearance lights come on, but they don't come on when the tail light are on.
So I don't think much of Carson at this point.
Old 08-07-2012, 04:05 PM   #30 (permalink)
Member # 27674
it suppose to have a full 1 year warranty, but it seems that they spend more time trying to get out of it rather than fixing the problem
Old 08-07-2012, 08:53 PM   #31 (permalink)
Wilson's Avatar
Member # 7233
Originally Posted by robert-r View Post
welp.... my carson trailer came with bias ply tires.
part of the low price...
they don't last long.
the screw, imho.
get some good quality radials.
Couldn't agree more, I would burn through bias tires every year (probably around 1000 miles, maybe a bit more) especially the rears. After some head scratching and looking at my other, heavier trailer that was going 3+ years on the original tires (pj that came with radials), I switched to radials. 3 years later, I'm about to replace them.
Old 08-08-2012, 12:08 AM   #32 (permalink)
dieselboy740's Avatar
Member # 168108
Friend bought a trailer and didn't notice for a few weeks that the rims were different on the front and rear axle. They won't do anything about it. Nor did it come with a spare yet it has a spare mount.
'97 f-250 project, boat sides, 3/4 link, caged, psd, back halved, dove tailed, fox co/ bumps, etc....
'94 f350 cclb drw 7.3idi-t
'93 Volvo 940 fake rally car #trophyvo
'94 international 4700 toter build
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 08-08-2012, 10:07 AM   #33 (permalink)
Member # 75114
Originally Posted by morp View Post
we bought this trailer for our club tds to haul the sweepstakes jeep, we figured we would sell this trailer after we gave the jeep away and recoup the monies.
So i took it back to carson and the checked it out and are claiming that it is within their tolerances and that the tire pressure was 8-10 pounds low. we never checked the pressure due to it being a new trailer and that it should have the proper pressure from the factory.
i had our club front end man check it out and he thinks that the spindles on the axle are a degree or two out and it is dragging the tires sideways down the road.
Anyway carson is trying to get out of their warranty by saying the tires were low so that is what caused the wear.
I spoke with allied, who supplies the wheels & tires to them and they say they are nuts, that no way could 10 lbs. Cause the tires to wear that much in 1000 miles. And all it would do is lower the carrying capacity 100 lbs per tire, not wear them out.
So i don't think much of carson at this point.
wtf???
keeptahoewhite is offline   Reply With Quote Quick reply to this message
Old 08-08-2012, 10:30 AM   #34 (permalink)
Member # 3007
Stupid thread is stupid
Bones is offline   Reply With Quote Quick reply to this message
Old 08-08-2012, 10:42 AM   #35 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Seriously? You had to make that many threads about this?
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
Old 08-10-2012, 01:57 AM   #36 (permalink)
White Shark's Avatar
Member # 39791
Gotta stay up on pressures and watch your equipment. When I was hauling at or near capacity, I would check my tire pressure on a daily basis, always 75 PSI Max on the bias ply tires. I had a lot of flats from hauling out to the dumps, and Les Schwab treated me like royalty since I swapped out for their tires as the originals wore out. I don't know about their auto haulers, but their dump trailer was better than any of the others on the market with the exception of Big Tex, and maybe one or two others.
I shopped and researched like crazy prior to buying the trailer, and roofers and landscapers swear by the Carson box dump trailers. Then again, you probably didn't spend almost $7000 on those autohaulers, did you? The dump trailer alone was 3600 lbs empty and built for serious abuse, and it never gave out, even when abused.
__
/_/
White Shark is offline   Reply With Quote Quick reply to this message
Old 08-10-2012, 05:32 AM   #37 (permalink)
Rock Agnostic
daddytall's Avatar
Member # 74936
Trailers come with cheap tires, especially cheap trailers. Besides that, even the big 3 auto manufactures refer you to the tire company for warranty issues there.
Maybe if you spent as much time researching and preventive maintenance as you did on these threads you wouldn't be in the situation you are in now. "We never checked the pressure due to it being a new trailer and that it should have the proper pressure from the factory. " is about the stupidest thing I have read here in a long time.. What the gvw of the trailer and what does it actually weigh with the Jeep and all the ancillaries included? Actual weight, not "I think" it weighs.
Is this really fatdan460 trolling again?
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is online now   Reply With Quote Quick reply to this message
