Mama Bought a tractor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2012, 09:31 AM   #1 (permalink)
Member # 41424
My wife wanted a little tractor for moving dirt from one side of our property to the other on a seemingly continuous basis, so she went and bought herself a little Kubota BX2360. 23 hp 3-cyl diesel, front end loader and 48" gannon box with ripper in the back.
Her toy, but I will end up caring for it, any advice on maint and such from folks who know? I know, read the manual... but not everything is in the manual..
Old age is the most unexpected of things that can happen to a man.
- Leon Trotsky
WLD_OTZ is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 09:35 AM   #2 (permalink)
Dieselmh's Avatar
Member # 6417
Send a message via Yahoo to Dieselmh
Do the recommended fluid and filter changes, and other than a safety switch here and there, it will be running long after you're dead. I have a 35HP and Dad has an older 28HP model. They've both been pretty abused, and still perform almost like new. My advice, if you can't keep it covered, at least keep the seat flipped up and covered when not in use.
Dieselmh is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 09:38 AM   #3 (permalink)
Member # 15397
It's a tractor, make sure it has oil in all the right places. Don't let her ever run out of fuel. During extended periods of time make sure you can fill 3/4 new fuel to top off. Inspect all hoses and fitting after any oppsies. If running through high grass clean the radiator often. Those kubotas have there own grass catcher that they call a grill.
Red90YJ is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 09:38 AM   #4 (permalink)
Member # 14143
Send a message via AIM to Airpup26
Filtration is key. Just laid one to rest last year, but it was abused hard for close to 12 years.
Looking for a new rig.
Airpup26 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 09:38 AM   #5 (permalink)
Member # 41424
Cleared a spot in the garage. worth more than either of her cars, so it gets tucked in neat and tidy. She even washed it after she moved some dirt for the first time last night.
- Leon Trotsky
Old 11-16-2012, 09:41 AM   #6 (permalink)
Member # 41424
This one is kinda cool, it draws air from the back of the cowl, and blows it out the front grill. I explained to her about the fuel bit. I also ordered a skidplate because I heard that the trans fan is delicate and in harm's way(and it is).
- Leon Trotsky
Old 11-16-2012, 09:44 AM   #7 (permalink)
Member # 5371
Send a message via MSN to rockota
Looked at the 2350 when I bought my JD. The location of the air intake was something I really liked on the Kubota... my JD has a screen that I have to clean often to prevent the front-mounted radiator from clogging.
Does the 2360 have the proprietary 3-point still? That was the biggest detractor for me (well.. that and the ergonomics).
rockota is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 09:55 AM   #8 (permalink)
Member # 41424
I don't know about proprietary, but it is called a #1 3-point. I didn't like the position of reverse, but I guess it would keep you from hitting it by mistake. Everything else feels fine. Hydraulics are loud at full rpm's tho.
- Leon Trotsky
Old 11-16-2012, 10:04 AM   #9 (permalink)
Member # 5371
if it's a true cat-1, great... when I looked at them in 09 they were closer to a 1/2... they couldn't accept cat-1 (or cat-3) implements.
Old 11-16-2012, 10:09 AM   #10 (permalink)
Member # 41424
how can I find out? I will search dimensions now..
got it, 3/4" top pin, and 7/8" bottom pins..
- Leon Trotsky
Old 11-16-2012, 10:13 AM   #11 (permalink)
Member # 5371
you need to know the width of the bottom arms - that's (IIRC) the biggest issue.
Old 11-16-2012, 10:41 AM   #12 (permalink)
Member # 41424
found one reference, 26" wide, checked some implements, and they were all 23-25" so I think it is a cat 1.
- Leon Trotsky
Old 11-16-2012, 10:43 AM   #13 (permalink)
Member # 146531
You lucky son of a gun.
I just looked at these. Honestly I think they are more comfortable than the NH, Massey and JD. The new Kubota 70 series are out now with some improvedments I want one but honestly cannot justify it for my property. I also want to look at the new Mahindra Max.
"The Founding Fathers knew a government can't control the economy without controlling people."
Ronald Reagan -October 27, 1964
Date added for moron proofing.
Jamtoy is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:45 AM   #14 (permalink)
Member # 25230
With you don't mind me asking, what did that set you back? Next year or two I'll be in the market, that looks like the perfect size.
southern k5 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:48 AM   #15 (permalink)
Runs Amok
s14sh3r's Avatar
Member # 181276
That box on the back makes my neck hurt just looking at it
s14sh3r is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:57 AM   #16 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
That statement right there is absolutely cool...
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 11:07 AM   #17 (permalink)
Member # 41424
Delivered to our front door- $14,100 and change.
we chose this over the B2320 because it fits through our 48" gates with everything attached.
- Leon Trotsky
Old 11-16-2012, 11:08 AM   #18 (permalink)
Member # 41424
how cum?
- Leon Trotsky
Old 11-16-2012, 11:14 AM   #19 (permalink)
Dieselmh's Avatar
Member # 6417
how cum?
Go spend a few hours leveling some dirt with it and you'll find out.
And here's a little hint, if that front end loader has a "float" mode, you'll find that it's WAY better for leveling dirt than the box blade. I use the box/scarifiers to loosen up the dirt, then turn around and use the FEL to put the dirt where I want it and level it.
Old 11-16-2012, 11:19 AM   #20 (permalink)
Member # 41424
it does, and I will!
I know I need to level a spot to put up a 40x16 awning to park toy hauler under, I will be learning all sorts of new things...
- Leon Trotsky
Old 11-16-2012, 12:21 PM   #21 (permalink)
Member # 75496
I've got basically the same tractor with the hoe, the BX25. It is an awesome little machine. General maintenance is as you would expect, I haven't done anything else to mine. My only complaint is the power to weight ratio. That little hoe can lift some amazing things (I've pulled at least 30 stumps) but could do a lot more with some more weight. The FEL is the same way, I picked up a large pine stump with the FEL and driving across the yard on a little slope and the back tires lifted off.
I highly recommend being very careful with it for awhile. It has more power than I expected for its size and that can put you in a pickle pretty darn quick.
And, as said above keep an eye on the fuel. It drinks so little, it's easy to forget about it.
Congrats on the purchase.
onemoretry is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 01:18 PM   #22 (permalink)
Member # 41424
Thanks! That is some good info right there! We were told never to operate the FEL without the box, and I guess we know why..
- Leon Trotsky
Old 11-16-2012, 01:24 PM   #23 (permalink)
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Never realized how pricey those things were. I guess if it's all the bigger you could have to fit through your gates then carry on, but you could buy a real tractor or a real loader for that kind of price!
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 01:31 PM   #24 (permalink)
Dieselmh's Avatar
Member # 6417
Not new with a warranty, you can't. And when I was shopping, it seemed like you were either going to get something almost new for just a couple of grand less, or something beat to shit for a lot less money.
Old 11-16-2012, 01:43 PM   #25 (permalink)
ndeepoffroad's Avatar
Member # 79902
Buy one of these. Teach your wife to use it. You can't use it enough. Pins and bushings are $$$$$.
Milwaukee Tool | Grease Guns | M12 Cordless LITHIUM-ION Grease Gun
5th Annual Rally in the Valley
April 28-May 1, 2016
ndeepoffroad is offline   Reply With Quote Quick reply to this message
