How to disable Event Data Recorder.... - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2013, 11:01 PM   #76 (permalink)
Bitter old man
plym49's Avatar
Member # 162771
Originally Posted by 1uglyranger View Post
No he isn't
I have had the popo ask me to retrieve and record said data for them. Unless you know a cop that has some fancy equipment that I don't have.
If you don't want the data recorded, unplug the ORC. Your air bag light will illuminate, and the vehicle will drive just fine. You will not have air bag operation (that may save your life) and a couple other previously mentioned things, but at least "the man" won't know how fast you were going when you hit that light pole in the mall parking lot.
Even on a CAN bus vehicle, unplugging an ORC, or OCM will not affect the way it runs.......
If you don't like that..... buy a CJ7
We've already concluded that at this point in time there is no practical way to prevent the EDR from recording, short of a ORCectomy, as you describe. But the interest was in preventing recording, not defeating air bags.
The only possibility so far is installing a doppelganger (and inoperative) ORC, stub harness and OBD connector. Then you can hide the functioning originals, and anyone attempting to download events from the doppelganger (that sits in the stock location) will come up dry.
EDIT: I do drive one of those. The investigation is on behalf of an interested aquaintance.
plym49 is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 11:07 PM   #77 (permalink)
Member # 48279
Out in the distance the faint sound of a crumpled tinfoil hat being thrown to the floor in anger will be heard by no man.
End thread.
grenade inspector
_nailhead_ is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 11:13 PM   #78 (permalink)
Bitter old man
plym49's Avatar
Member # 162771
Guess the tinfoil got ripped by the nail in your head.
Old 05-17-2013, 11:22 PM   #79 (permalink)
Hardcore Web Wheeler
Whitetrash303's Avatar
Member # 102426
There is a European automotive hacking forum that deals with mostly cloning OEM automotive software. I have seen those guys share hacks for clearing crash data and such. The bad news is that it's based towards Euro market cars, I don't think I've seen anything Jeep related over there. However those guys do a ton of stuff with MBZ, might be a good place to check.
Pm me if you want a link.
The Answer to 1984 is 1776
Whitetrash303 is offline   Reply With Quote Quick reply to this message
Old 05-18-2013, 12:33 AM   #80 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Will it be possible to open it up and modify in a way that it will communicate but won't "save" the data because its memory components are missing or modified?
You can't say that you have wheeled hard till you have broken something or gotten stuck.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 05-18-2013, 07:13 AM   #81 (permalink)
Bitter old man
plym49's Avatar
Member # 162771
I wonder if it would still spit an error code.
But its a good thought as perhaps there is just one memory write pin that needs to be opened.
Old 05-18-2013, 07:16 AM   #82 (permalink)
Bitter old man
plym49's Avatar
Member # 162771
You make a good point; the various h@cker spaces will probably be diving into these units soon enough. Not really interested in reflashing chips but perhaps if anyone else is interested in that type of approach they could PM you.
Old 05-18-2013, 07:41 PM   #83 (permalink)
Member # 189225
Send a message via AIM to kastein Send a message via Skype™ to kastein
Did you really just use an @ symbol instead of an A in hackerspace?
So elite.
PS: lifting a write pin will almost certainly result in the controller throwing some sort of a code indicating it can't write to its memory. Something like the P0601 code thrown by some dodge PCMs when their internal data storage flash chip can't be communicated with by the main MCU in the PCM after attempting 3 (or 6, I forget) serial bus requests. This isn't the 80s where you just rip shit out and the computer blindly keeps going like nothing happened, not realizing that it's sending data into the void.
Not only can I fuck up a steel ball in a rubber room, I do so often - by accident.
kastein is offline   Reply With Quote Quick reply to this message
Old 05-18-2013, 08:00 PM   #84 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
Damn you guys are making me scared to get rid of my 93 Dodge diesel.
It needs no hot wires to run. Wire the fuel solenoid open, roll the tires over, dump the clutch and it is running.
The penalty for punching someone in the mouth is way too high in our society.
Always take a poison word as a promise.
SilverZuk is offline   Reply With Quote Quick reply to this message
Old 05-18-2013, 08:05 PM   #85 (permalink)
Bitter old man
plym49's Avatar
Member # 162771
Yup, that's why every vehicle I own is pre-OBD2, and most are not even computerized.
