How to disable Event Data Recorder.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2013, 06:22 PM   #1 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
...on a 2013 JK?
And where is it?
Will an ice pick thru its icy little heart do the trick?
plym49 is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:23 PM   #2 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
you watch Terminator? Have fun
But why?
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:29 PM   #3 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
But why?
Select one that best answers the question:
A. Why not?
B. Provides no value to the driver or owner and could be a liability.
C. Because it is a free f-ing country and that includes the freedom from unwarranted surveillance.
D. Because it is there.
E. Because you don't own it if you can't open it.
F. Other: (250 characters max)
Old 05-16-2013, 06:30 PM   #4 (permalink)
Member # 189225
Send a message via AIM to kastein Send a message via Skype™ to kastein
Is it a separate module from the ECU, or built in? I thought they were built in.
Not only can I fuck up a steel ball in a rubber room, I do so often - by accident.
kastein is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:38 PM   #5 (permalink)
usmcdoc14's Avatar
Member # 13344
A. Why not? because when you wrap it into a walmart entrance concete plater it will tell the cops you were doing 55 instead of the 10mph you were supposed to do while crawling at the mall
B. Provides no value to the driver or owner and could be a liability.only if you plan on driving like a retard, it could also be used to protect you in court as well
C. Because it is a free f-ing country and that includes the freedom from unwarranted surveillance. and voiding warrentees
D. Because it is there. not sure its where you want it
E. Because you don't own it if you can't open it. don't think you can open it
I think its still part of the ECU. have fun with that. I have not dove into the pentastar ECU to see if it was even something you can get at. You want me to ask on JKO for you?
Old 05-16-2013, 06:45 PM   #6 (permalink)
Member # 104517
Does just unplugging it not suffice?
If you want to do it and not get the 10th degree if/when it's found later, I would:
1. disconnect it from the vehicle
2. find an appropriate 120v outlet (preferrably one next to your panel since you may trip the breaker several times. Also, a GFCI or Arc Fault breaker/outlet may trip quick enough to protect it.)
3. plug said outlet into random ports on the box until you release the magic smoke, while not electrocuting yourself in the process. 300v rated rubber gloves recommended.
4. put it back and pretend nothing ever happened.
This is assuming it's not needed to run the jeep. I would suggest unplugging it and making sure everything still works before destroying it.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:51 PM   #7 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
That all makes sense and you know, cables sometimes are bad from the factory.
Where is the unit? Is it a separate black box?
Or is it a feature built into the ECU that is accessed using the OBD connector?
Old 05-16-2013, 06:53 PM   #8 (permalink)
Member # 81214
sell JK, buy a CJ8 :shrug:
Never Monday is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:54 PM   #9 (permalink)
F2504x4's Avatar
Member # 85205
Mechanical Forensics: Event Data Recorders & the CDRTool
[QUOTE=Administrator;15106961]And exactly why its better I work in the backround and not meddle what makes pirate pirate. [/QUOTE]
F2504x4 is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 06:56 PM   #10 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
Would appreciate any insight you can provide.
Old 05-16-2013, 06:59 PM   #11 (permalink)
Get stuck's Avatar
Member # 189224
The one where you called Doc a TROLL is better noob.
Get stuck is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 07:00 PM   #12 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
It was, wasn't it?
Old 05-16-2013, 07:00 PM   #13 (permalink)
Member # 106845
Send a message via AIM to flatlander757
It's stored in the ORC(occupant restraint controller)... AKA your airbag module.
Been that way since 2005.
Chrysler Airbag Control Module (ACM) Data Reliability
edit: On TJs they are located dead center in the dash on the floor(in front of shifter). Every other Chrysler vehicle I've worked on has it there too(Caravans, Rams, Durangos, etc)... so it's probably there in the JK as well.
It basically records G forces and monitors your seat belts and wheel speeds, steering angle, throttle position, brake switch on or off(some vehicles will actually measure brake PRESSURE applied... forget if JKs are capable of this or not... guessing not), and based on all the inputs calculates the yaw rate and wheel spin and whatnot.
-Tony
flatlander757 is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 07:02 PM   #14 (permalink)
Member # 104517
I'm assuming it's a separate box since he asked if he could icepick it!
I really don't know as the newest jeep I've worked on has been a buddies 98 XJ. I'm just suggesting a convenient way to kill it without making it look too obvious. Even if they crack it open to find it smoked they really wouldn't be able to place the blame on him for tampering with it, just assume a voltage regulator failure or a short that had been fixed without knowledge the box was damaged.
R.I.P. Jason Payne
Old 05-16-2013, 07:03 PM   #15 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
Does that module control airbag deployment or only provide supplemental control (like passenger side deactivation)?
If the former, can it be swapped out with a controller from a pre-EDR model?
Old 05-16-2013, 07:05 PM   #16 (permalink)
Window Locker
bigbroncojeff's Avatar
Member # 43837
Do it.
Fold down the middle row of pins in the far right connection.
Or this
[IMG]http://2.bp.blogspot.com/__GakOwcozm8/TK6fziFAHQGIANTPITCHER
RIP SPRING CREEK OFF ROAD
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
Last edited by bigbroncojeff; 05-16-2013 at 07:06 PM. Reason: stoopid jiant pitcher
bigbroncojeff is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 07:11 PM   #17 (permalink)
Member # 106845
It controls everything... on top of that it is run on the CAN bus system so disable it and it will fuck with every other module in the car... The PCM, the BCM, WCM, CCN, and other bullshit modules will throw a fit because something is missing from the CAN Bus.
No way to remove it without gutting the entire vehicle and starting with a shell.
-Tony
Old 05-16-2013, 07:17 PM   #18 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
What about the picture in the above post? I presume that is the back of the ECU - do those pins provide an EDR readout, are they dedicated for EDR functionality, or do they also tie into the airbag controller?
Old 05-16-2013, 07:22 PM   #19 (permalink)
usmcdoc14's Avatar
Member # 13344
disable/remove event data recorder on a 2013 jk - JKowners.com : Jeep Wrangler JK Forum
check there and see if anyone has any input
Old 05-16-2013, 07:25 PM   #20 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
Thank you. Will report back if anything shows up there.
In the meantime, any MoPar techs that can chime in? Where do the police plug in their EDR readers? A dedicated plug or the OBD connector?
Old 05-16-2013, 07:30 PM   #21 (permalink)
Window Locker
Member # 43837
Not familiar with the controller network on JKs.... but most can bus setups know when a module is missing.... some times it'll soft code and somtimes it can shut the entire network down. Sometimes controllers are on legs and sometimes it's a daisy chain system... keeping up with all of the different brands of forklift systems is a task and a half.
Old 05-16-2013, 07:44 PM   #22 (permalink)
Member # 106845
Guy... I WAS a Mopar tech. Granted back in 2007-2008... but I have experience with the Star Scan.
The guy that responded it's possible to remove the crash data w/ the Star Scan is full of shit. It might be able to possibly extract or erase the crash data... but it sure as hell has no capability of keeping the module from reading data in the future.
The star scan can basically change a few data parameters, calibrate the passenger seat weight sensors, clear codes, show what modules are communicating with what, and reflash any of the modules with PRE WRITTEN FLASH FILES FROM CHRYSLER THEMSELVES. Unless you are a computer programmer, good luck writing a file for the ORC to NOT store crash data.
You need to sell the damn Jeep if you want to get rid of it.
Or wire in a small explosive to go off right on the ORC when the airbags deploy
-Tony
Old 05-16-2013, 07:53 PM   #23 (permalink)
I'mnot sexy&Iknowit
plym49's Avatar
Member # 162771
OK, so the EDR data is physically housed in the ORC, correct?
And where do the investigators plug in to read the EDR data?
Old 05-16-2013, 07:53 PM   #24 (permalink)
usmcdoc14's Avatar
Member # 13344
sounds like a good reason for a LS swap
Old 05-16-2013, 07:55 PM   #25 (permalink)
Member # 106845
I don't THINK it will take the whole network down, I know it will store hard codes in the BCM and PCM for sure... mostly U---- codes for CAN Bus communications. It will very possibly go into limp mode.
All the OP has to do to test it is disconnect the module and see what happens. See if it lets him drive like normal.
Bottom line is you are not getting rid of the ORC without losing the air bag functionality, traction control, and ABS for sure.
-Tony
