How does CTIS work? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2013, 03:44 PM   #1 (permalink)
Member # 16468
How does CTIS work?
Wondering how central tire inflation works in a solid axle. This is the closest I've found, and for a portal it looks like a fairly simple setup.
How do they do it in a solid axle without external air lines?
1969 Jeep M715 6x6 6BT/NV4500/NP202.5 D60/70/70
1963 Jeep J300, 4BT/NV4500/NP200/D60/60
Mikel is online now   Reply With Quote Quick reply to this message
Old 09-15-2013, 04:50 PM   #2 (permalink)
fart_plume's Avatar
Member # 188473
When I first read the title, I thought you were asking how CLITS work.................
fart_plume is online now   Reply With Quote Quick reply to this message
Old 09-15-2013, 05:10 PM   #3 (permalink)
DirtyComanche's Avatar
Member # 53453
Generally CTIS doesn't work.
There's multiple ways to attempt to make it work for a solid axle. Normally it's just as simple as there being a couple extra seals between the hub/spindle, and that area is pressurized via a drilled passage in the spindle, and the hub is drilled/tapped to allow an air line to be attached to it at the pressurized area. Or something like that.
I burn slow like pissing drunk with gonorrhea.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 05:15 PM   #4 (permalink)
crashhawk's Avatar
Member # 115887
If can remember I'll post up a schematic from the shop tomorrow. But the simpler set ups work just like you posted.
God hates a coward.
Nolite esse canis praecisae
crashhawk is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 05:20 PM   #5 (permalink)
Member # 53453
The schematic he posted is from the H1, or HUMVEE? It works that way, and can work that way, because the output gear in the portal box is supported from both ends and can be drilled for an air passage. You can't do that (easily) with an axle shaft that uses u-joints, as it flops around in there a bit too much Probably could make something like that work with CV joints if you wanted to, but I think it would be making an unreliable system even more unreliable.
Old 09-15-2013, 05:33 PM   #6 (permalink)
clastic's Avatar
Member # 180649
Sounds like a job for mogger. Oh wait
Not even a hopped up Cummins could pull OP's head out of his ass but at least it'd get 30mpg trying.
Crispins 2016
clastic is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 07:51 PM   #7 (permalink)
Member # 207000
Out of all the army junk I've driven, every rig was inop. Or rendered inop. Because of sealing issues. It seems like a good system in theory, but like most in life, real world conditions prevail
donald kerabatsos is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 07:56 PM   #8 (permalink)
Member # 53453
If it makes you feel any better, the systems on the MAN, Tatra, Kraz, etc, trucks are apparently fairly reliable.
It's just the N. American stuff that doesn't work
Old 09-15-2013, 08:13 PM   #9 (permalink)
Member # 207000
We had a pretty reliable system. Us standing at each tire for a goddanged hour airin' them back up to 60 psi with a friggin' airchuck.
I guess that's why we never aired down for ops. Airing up super singles on a five ton is a bitch
Old 09-15-2013, 08:24 PM   #10 (permalink)
Member # 685778
That whole area is a medical mystery.
ProjectWin is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 08:24 PM   #11 (permalink)
Member # 10867
Depends on the junk. The M939-series was junk CTIS. The same system was used on the early LMTVs.
The OSHKOSH system was pretty pimp. Eventually the axle seals would fail or the main diaphragm would let go, but that was after over a decade of military service. Once the system would be refurbed, it would work great for another 10 years or so.
[QUOTE=Mrs.CSR;14024539]You were good[/QUOTE]
DRTDEVL is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 03:01 PM   #12 (permalink)
Member # 16468
Btt :d
Old 09-16-2013, 03:08 PM   #13 (permalink)
Extended Member
Member # 69765
the more or less ghetto way to get it done and not compromise axle strength.
~ Kyle
2003 Montero
2006 Montero
Follow my adventures on Instagram:
Kyle_T is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 03:11 PM   #14 (permalink)
Provience's Avatar
Member # 138976
Originally Posted by Mikel View Post
Btt :d
Trucks 2.5 Ton M1078 Maintenance Manuals
edit: pictures in the -24p
http://trucks25tonv1-2.tpub.com/TM-9...65-24P_390.htm
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
Old 09-16-2013, 04:45 PM   #15 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
I have seen busses done this way also.
I swear sometimes this place should be called "Autism on bath salts".
:tank:
Old 09-16-2013, 04:57 PM   #16 (permalink)
coolcruiserfj40's Avatar
Member # 40057
Guy down the street with an h1 has four flats atleast once a week
Me have A.D.D
coolcruiserfj40 is offline   Reply With Quote Quick reply to this message
