(Spinoff) Epoxy Grout - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2013, 11:36 AM   #1 (permalink)
Member # 8150
Send a message via AIM to mtnbikeboy
Why all the hate for epoxy grout in Roxy's thread? I helped grout a house where they used epoxy grout in all the dirty areas (laundry, etc) and it went fine. I made sure to only do it one little tub at a time, and I used a rubber margin trowel instead of the big one. It was definitely more of a PITA to clean; I just did it by touch. If the tile felt smooth and clean, I knew I had gotten it all.
I can definitely see that if one isn't careful, it can get away and there's a big mess left for a pro to fix. Maybe having done masonry flat work gave me a leg up?
'73 Commando 304, 4bbl, Th400
mtnbikeboy is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 11:46 AM   #2 (permalink)
I should be working
Jam Master Jay's Avatar
Member # 18829
It's the only way to go in kitchens and restrooms. It is a bitch to clean up though. I've never done it myself but I've built a ton of commercial kitchens and the ones that have quarry tile always have epoxy grout.
I wish the previous owner of my house had sprung for it in my kitchen, or at the very least sealed the grout. What was white grout is stained yellow-brown and won't even come clean with bleach or scrubbing. I'm going to have to grind it all out and regrout it.
Ride 'Em Cowboys!
Jam Master Jay is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 11:47 AM   #3 (permalink)
In GOD we trust. USA
NoJoke's Avatar
Member # 15480
+1 for spectralock
<-- AVATAR for Concealed Carry Weapons permits in the U.S. over time: No issue / May issue / Shall issue / Constitutional carry- No restrictions / FROM 1986 to today
NoJoke is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 11:48 AM   #4 (permalink)
Member # 42720
The only way for a pro to 'fix it' is tear it all off and start over.
There are special strippers for that, just need to get it from a tile wholesaler not a hardware store.
THE MEEK SHALL INHERIT NOTHING
www.helmutwatches.com
ChaseYJ is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 11:53 AM   #5 (permalink)
Member # 8150
I understand that. I just didn't find it as difficult as your advice seems to indicate. Maybe the homeowners/handypeople I've been around are above average as well.
I'm genuinely curious, and having worked in the building trades (masonry), am always interested in a good train wreck story.
Old 10-23-2013, 01:32 PM   #6 (permalink)
Lurking since 1956
papee's Avatar
Member # 1041
Send a message via MSN to papee Send a message via Yahoo to papee
I used it in my bathroom and I have to say now that I've used it I won't use anything else. A vinegar and water mixture cleans the tiles nice. You just have to be sure to keep rinsing your sponge. It can get sticky but overall it's just a better product.
I made it through the password change of 6/16
95 YJ 4.0 HO
Mildly modded
Yes I still wheel
papee is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 01:50 PM   #7 (permalink)
Member # 167824
We just finished two bathroom remodels, and the tile guys used epoxy grout, stuff works great.
I was talking to one of the tile guys, and he said it's the best stuff to ever hit the market, no mixing, easy to clean, saves time.
There were a few spots on the tile where some grout didn't wipe off, showed it too the tile guy, and he scrapped it right off with a razor blade, said if I find anymore to just scrape it with a blade.
Best part was, the dipshits designing one of the bathroom forgot to add a floor drain, and the project manager didn't care enough to inspect the plans, so after the tile guy was finished I said "where's the drain?" he said "wasn't on the plans" so I did some calling, got the project manager in there, he had an oh shit moment, forcing the tile guy to comeback 3 days later and bust out 4 tiles so the plumbers could add a drain, and even with all the hammering, and the not so great subfloor, NON of the grout cracked.
97 Ranger, DD
85 F250, SOLD
85Diesel4x4 is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 05:25 PM   #8 (permalink)
roundhouse's Avatar
Member # 16751
other than taking about 10 times as long to do, epoxy grout is great.
Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?[Alan Keyes]
For some, Freedom matters, for most, prosperity suffices.[Fred Reed]
74Bronco EFI 5spd
roundhouse is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 05:38 PM   #9 (permalink)
bigbadchev84's Avatar
Member # 68938
I used it in our kitchen, Other than being suprised at how little is actually in the small tubs I liked it. We cut auto body filler spreaders for body filler in half instead of a trowel. Made cleanup alot easier since I was able to keep it pretty close to the grout lines. Lots of sponges and rotate them out frequently.
72 k5 400/350/205 8" lift 4.56s 38" Toyo M/Ts
87 k5 383/400/203/205, 52s 5.13 60/14bff 39.5 rockers
bigbadchev84 is offline   Reply With Quote Quick reply to this message
Old 10-24-2013, 06:07 AM   #10 (permalink)
Member # 8150
These anecdotes are my experience as well.
ChaseYJ, HighLuxx what are your horror stories that make you suggest eschewing it?
Old 10-24-2013, 06:11 AM   #11 (permalink)
Member # 3511
I used it in the tub and shower, once you get used to the really short working time it wasn't hard to deal with. Can't beat the finished result.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 10-24-2013, 06:12 AM   #12 (permalink)
Member # 3511
No mixing? How do you have an epoxy grout without mixing?
Chuck P
