home heating oil question? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-20-2003, 09:45 AM   #1 (permalink)
R O
Member # 5921
I think there may be more than a normal amount of water in my oil tank.
Can I use methylhydrate or some other chemical to break down the water molecules?
OS,you out there?
R O is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 10:14 AM   #2 (permalink)
Member # 12499
The water is all on the bottom-can you drain the water from the bottom?
Adding some methanol will work to allow you to burn the water, but I'd try to drain the water.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 10:28 AM   #3 (permalink)
unimogken's Avatar
Member # 11745
I pumped my tank out with a cheapo pump then separated and poured the good stuff back in.
Later, Ken
1 Mercedes Benz Unimog 404s
unimogken is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 11:15 AM   #4 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Call Esso at 1-866-749-ESSO (3776) maybe they can tell you how to do it.
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 11:32 AM   #5 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Re: home heating oil question?
Originally posted by R O
OS,you out there?
They make a water seperating filter, but I'm on natural gas so.....
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 12:21 PM   #6 (permalink)
Member # 7340
Toss a few bottles of HEET or Isopropyl (sp)
[COLOR=BLACK] You picked a fine time to leave me loose wheel [/COLOR]
Chad H is offline   Reply With Quote Quick reply to this message
Old 12-20-2003, 12:29 PM   #7 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Originally posted by ChadH
or Isopropyl (sp)
Bad advice. Depending on were you buy your I.P.A. it can contain as mush as 70% water on it's own!
BUY MY BOAT
Old 12-20-2003, 12:40 PM   #8 (permalink)
Member # 7340
Ok , so dont buy the versions with 70% water
Just trust me and use it......
Old 12-21-2003, 09:16 AM   #9 (permalink)
R O
Member # 5921
HEET,like the stuff for sore muscles?
Where's the easiest place to find isoproply?
OS-
Old 12-21-2003, 09:18 AM   #10 (permalink)
Member # 12499
Gee, I guess nobody liked my idea of methanol, which will work better than Isopropanol.
Old 12-21-2003, 10:07 AM   #11 (permalink)
R O
Member # 5921
How come?Can I use racing fuel methanol?That I can get easily.
I'm open to whatever works better than having to pump it dry and seperating the water out.
The only outlet on the bottom of the tank is for fuel.It leaves about 3inches of whatever in the bottom.I'm worried that there is too much water.
Old 12-21-2003, 10:17 AM   #12 (permalink)
Member # 9821
If you've got enough water in your tank that it's causing a problem I don't think alcohol is gonna fix it. Think about it, if you have a 250 gal tank with the pickup a couple of inches off the bottom and you're drawing water there could be as much as 5 gallons of water in there. Your best bet (if it's an above ground tank) is to crack the drain and let it run untill the water drains off. A bottle of Heet after your drain it off to get whatever's stuck to the walls wouldn't hurt.
:edit: Since you don't have a drain get yourself a filter with one.
I'm pimping ScottFJ40's
so he owes me a dollar.
[color=orange] Two wrongs don't make a right but three rights make a left.[/color]
[color=yellow]I before E except after C except in words like neighbor and Budweiser.[/color]
[color=lime]May clinging breasts always come to your aid in the kitchen.
[/color]
ForestCam is offline   Reply With Quote Quick reply to this message
Old 12-21-2003, 10:17 AM   #13 (permalink)
Member # 324
http://www.goldeagle.com/heet/
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote Quick reply to this message
Old 12-21-2003, 10:29 AM   #14 (permalink)
R O
Member # 5921
It's not drawing water. I'm concerned about any water causing the tank to rust out prematurely.
So it looks like that HEET stuff is just methyl-hydrate right?
Old 12-21-2003, 10:37 AM   #15 (permalink)
Poseur SUV
Member # 610
Methanol = Methyl Hydrate = Methyl Alcohol = Wood Alcohol Same same.
Paul Gagnon
"No Brain, No Pain"
