My dryer died, how can I fix it - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-06-2004, 10:00 PM   #1 (permalink)
Member # 13707
My dryer died. It is still spining, but I have no hot air. Is there a dead heating element, or a blown resistor???
It is a whirlpool, and a little old. I can't buy a new one cause I don't got that kind of money.
I already thought about tying some rope from the roll bar to the tailgate and just driving around, but my wife didn't like that idea.
Toyoda is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:04 PM   #2 (permalink)
Buddha's Ghost's Avatar
Member # 334
I'm assuming it's electric.
Could be the element, a bad limit, a burned wire, thermostat, thermal fuse.
Buddha's Ghost is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:05 PM   #3 (permalink)
Member # 9821
It's either the heating element or the high limit switch, if you take the back off they're both in the same place. Use an ohm meter and check across the connections on the high limit and there should be resistance. If the high limit checks out ok check for resistance across the heating element, if there's none then the element's blown or you may just be able to visibly see a break in the coil.
Tell your wife to clean the lint filter a little more often and do a fawking search! I completely covered this a little while ago when 's dryer died.
I'm pimping ScottFJ40's
so he owes me a dollar.
[color=orange] Two wrongs don't make a right but three rights make a left.[/color]
[color=yellow]I before E except after C except in words like neighbor and Budweiser.[/color]
[color=lime]May clinging breasts always come to your aid in the kitchen.
[/color]
ForestCam is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:06 PM   #4 (permalink)
Damage, Inc.'s Avatar
Member # 20298
Usually the elements go bad. It's a rather simple process and most appliance places sell replacement elements. Take the top off, lift out the drum, and voila **, you're looking at the element.
** Ease of disassembly not typical. Expect to spend endless hours cussing and cut fingers.
I didn't read what he said, but he's right. - BHC
Damage, Inc. is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:08 PM   #5 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
when mine stopped doing that,it turned out one of the input vents was clogged with lint and stuff because the cover had broken.
It just wouldnt heat up, unclogged it and it works great now
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:13 PM   #6 (permalink)
Member # 20140
Try Here
Mud Soup is offline   Reply With Quote Quick reply to this message
Old 04-06-2004, 10:14 PM   #7 (permalink)
Member # 13707
do a fawking search
I honestly never thought to search the pirate 4x4 bb for a dryer problem.
I will check it out tomorrow, and I will search, and see what I can do.
Old 04-06-2004, 10:15 PM   #8 (permalink)
Member # 23252
Originally posted by Mud Soup
Try Here
shoot, ya beat me to it. I was going to suggest that, as I've rebuilt my dryer from them. and they ship their parts incredibly fast. repairclinic.com rocks !
"I don't [I]try[/I] anything. I just [B]DO[/B] it.
wanna try me?"
wickedkewl is offline   Reply With Quote Quick reply to this message
Old 04-07-2004, 07:52 AM   #9 (permalink)
RE:Todd's Avatar
Member # 422
Check the entire exhaust hose for clogs. That's what happened to mine, air wouldn't flow because of a clog in the flapper door to outside.
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
RE:Todd is offline   Reply With Quote Quick reply to this message
Old 04-07-2004, 07:56 AM   #10 (permalink)
Lurking since 1956
papee's Avatar
Member # 1041
Send a message via MSN to papee Send a message via Yahoo to papee
The first thing you should check is to make sure you have 220 volts. Power to the element side. The other ideas are good from there.
I made it through the password change of 6/16
95 YJ 4.0 HO
Mildly modded
Yes I still wheel
papee is offline   Reply With Quote Quick reply to this message
